singler3360 Samba Member
Joined: February 25, 2009 Posts: 1191 Location: Corvallis, Oregon
Posted: Sat Mar 02, 2013 8:10 pm Post subject: FAS muffler hanger kit - nice |
I installed a new muffler and tailpipe today using the FAS muffler hanger kit to eliminate any future cracked exhaust parts that can occur with inline 4 conversions. FAS shipped the kit from Maine to Oregon in 2 days. The engineering and quality seem very high.
The fully adjustable SS muffler straps hang from rubber dampeners that are attached to custom brackets connected to the engine cradle mount points on the body.
More pics here
https://picasaweb.google.com/116091365267664548782/FASTTEXHAUSTPIPE?authuser=0&feat=directlink#
Can't wait to finish the job tomorrow and see how it performs. |
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10347 Location: Sunshine Coast B.C.
Posted: Sat Mar 02, 2013 11:16 pm Post subject: |
Thanks for posting the pics and descriptions. Those SS clamps look familiar. I'd found and installed those same type for my swap a few years ago. They are very skookum.
I'll be curious to know if you find any transfer of exhaust noise to body. Likely you won't!
1988 West DIY 50º ABA
VE7TBN |
Posted: Sat Mar 02, 2013 11:30 pm Post subject: |
Vanagon Nut wrote: |
Neil. |
I'll listen for it and report back. |
Posted: Sun Mar 03, 2013 10:53 pm Post subject: |
Overall, exhaust noise inside the van is sharply reduced. Getting the adjustment of the hangers was much easier than I thought. Wish I had done this a long time ago. |
Posted: Sun Mar 03, 2013 11:24 pm Post subject: |
So your exhaust was mounted to the engine before?
Great to hear of the improvement!
VE7TBN |
Posted: Mon Mar 04, 2013 12:48 pm Post subject: |
Neil. |
One of the brackets was bolted to the oil pan. I'm not sure if bolting to the engine is true of all inline conversions or just the Tiico, but FAS has done a good job engineering a solution that mounts to the body. |
metropoj Samba Member
Posted: Mon Nov 16, 2015 6:26 am Post subject: Re: FAS muffler hanger kit - nice |
Thread resurrection as I try to get some ideas to solve my exhaust note issues.
What muffler are you using with the FAS hanger kit ?
FAS suggested the 1.9l for the kit. I picked up an Ernst 1.9 and I'm not overly happy with it's dampening capabilities.
It is not body resonance but rather a throaty sound from idle right through to the dreaded 3400-4200rpm range. I have an internal rattle in the muffler at 2800 and the highway range gives me a headache listening to it.
Making matters worse, I think something has possibly failed inside the muffler. At the 750km mark I now have an overall increase in noise that I don't think is related to intake or body resonance at this point. _________________ John.
86 TiiCo powered Westy. |
vwfreek61 Samba Member
Joined: May 31, 2004 Posts: 351 Location: Green Bay, WI
Posted: Mon Nov 16, 2015 1:29 pm Post subject: Re: FAS muffler hanger kit - nice |
I made a custom exhaust using rubber hangars similar to the FAS kit. The muffler I'm using is for an 80s or 90s Ford F150 along with a 9" long glasspack. It's not loud and sounds good, even running down the highway at nearly 4000 rpms (I have an automatic).
_________________ Kenneth
1964 Bug with Saxomat
1976 VW/Harley Trike Autostick
1987 Vanagon Westy w/Subaru EJ25 and reversed 4EAT |
rmcd Samba Member
Joined: October 29, 2010 Posts: 1348 Location: PNW - its a dry rain.
Posted: Mon Nov 16, 2015 9:39 pm Post subject: Re: FAS muffler hanger kit - nice |
vwfreek61 wrote: |
Where did you find a 9" glasspack muffler?
Thanks _________________ VW LT40 build. Like a Vanagon but 30% larger in every direction and 40% slower even in metric.
https://www.thesamba.com/vw/forum/viewtopic.php?t=749359&highlight= |
Posted: Tue Nov 17, 2015 5:27 am Post subject: Re: FAS muffler hanger kit - nice |
That's some nice work you did there, beauty.
Too bad the glasspack sits right where my CAT is ... I'll have to check out the muffler as a possibility. _________________ John.
Posted: Wed Nov 18, 2015 12:45 pm Post subject: Re: FAS muffler hanger kit - nice |
rmcd wrote: |
Thanks |
Summit racing: http://www.summitracing.com/parts/jex-a3509b
metropoj wrote: |
Too bad the glasspack sits right where my CAT is Smile ... I'll have to check out the muffler as a possibility. |
It took a few tries to get everything where I wanted it.
The glasspack probably provides about the same amount of noise reduction as the CAT would. _________________ Kenneth
icolquhoun Samba Member
Posted: Wed Nov 18, 2015 1:28 pm Post subject: Re: FAS muffler hanger kit - nice |
vwfreek61 wrote: |
rmcd wrote: |
Thanks |
metropoj wrote: |
The glasspack probably provides about the same amount of noise reduction as the CAT would. |
what manifold/downpipe are you using???
nice work! |
Posted: Wed Nov 18, 2015 8:19 pm Post subject: Re: FAS muffler hanger kit - nice |
icolquhoun wrote: |
nice work! |
I'm using the ABA dual outlet manifold with a custom downpipe. 1.75" primaries and 32" long if I remember correctly. I do design/drafting at a metal fab shop. So I just laid everything out, tacked it together, then brought it to work and one of the guys in the shop welded it up.
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3425 Location: Dartmouth, Mass.
Posted: Sat Nov 21, 2015 6:19 am Post subject: Re: FAS muffler hanger kit - nice |
I bought an Audi 80 manifold, but I am unsure of what to do for a down pipe. Should I try to get an Audi 80 down pipe (if I can even find one), even if it is just for the flange.
I finishing this until winter is over, but I figure if I should look for the 80 down pipe, I can start now. _________________ John - 86 Wolfsburg Westfalia "Weekender"
FAQ thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=525798 |
Posted: Sat Nov 21, 2015 8:31 am Post subject: Re: FAS muffler hanger kit - nice |
I would foregt the downpipe and just use the flange/and/or gasket to fab a flange and start the downpipe from scratch |
