Door Latched Don't Work?
gonebaby
gonebaby is offline
PostPosted: Tue Mar 05, 2013 6:06 pm    Post subject: Door Latched Don't Work? Reply with quote
Anyone ever have problems with the latch catching? all 4 doors don't shut? anyone?
MRJEL
MRJEL is offline
PostPosted: Tue Mar 05, 2013 6:08 pm    Post subject: Reply with quote
Time to clean and lube the latches.
Brake cleaner then WD40, LPS or lithium spray will all work.
Semper_Dad
Semper_Dad is offline
PostPosted: Tue Mar 05, 2013 8:09 pm    Post subject: Reply with quote
The rotating latch part on the door has 2 positions. A half latch, and a full latch. Sometimes when messing with the latch they get into a half latch situation. Door won't shut and latch.
Try and roll the latch to the full latch position. Then pull the outside trigger and watch them roll to the unlatch position. Sometimes they need a little help. If they do need help it's time to clean and lubricate.
74 VW Thing - Walküre
78 GMC Motorhome - Valhalla
"Patina" my ass, that's rust
Recovering Split Bus Addict
World 181 Registry Map:
http://bit.ly/1axDF1r
Gitm registared boys!
Officially, there are only 112 181s in the world
Ferretkona
Ferretkona is offline
PostPosted: Tue Mar 05, 2013 8:10 pm    Post subject: Reply with quote
I had to remove mine once a year and clean and lube.
When I first bought mine I did not know how to unlock and lock the handles. Doh!
74 181 Thing
2008 Ford Sport Trac V8 4x4
2008 Ford Escape V6
Rev. Scott
Rev. Scott is offline
PostPosted: Tue Mar 05, 2013 8:13 pm    Post subject: Reply with quote
Slamming door syndrome, thanks kids! Battling this on the two rear doors myself. cleaned, lubed, adjusted, etc. grrrrrrrr!
"I haven't seen one of those since I was shootin' at 'em!"
Ferretkona
PostPosted: Tue Mar 05, 2013 10:25 pm    Post subject: Reply with quote
I had a extra right and left latch so they were always available clean for a swap.
74 181 Thing
2008 Ford Escape V6
gonebaby
gonebaby is offline
PostPosted: Wed Mar 06, 2013 6:43 am    Post subject: Reply with quote
after work im going to clean and lube them up I think like Semper Dad said they arent latching all the way. thanks guys...
Joe 20
Joe 20 is offline
PostPosted: Wed Mar 06, 2013 8:22 pm    Post subject: Reply with quote
Mine work fine in the warmer weather and don't want to latch in the colder weather. I just chalk it up to the metal body expanding/contracting.
Semper_Dad
PostPosted: Wed Mar 06, 2013 8:39 pm    Post subject: Reply with quote
Or the grease , dirt and gunk being less viscous in cold weather. I used to have the same problem until I removed them and dropped them into an ultrasonic sink. Blew them dry, lubricated, and reinstalled them. No problems since. Just for the record though, It had looked like the PO had done a respray to the doors and left the latches in while doing it. Evil or Very Mad
gonebaby
gonebaby is offline
PostPosted: Wed Mar 06, 2013 8:41 pm    Post subject: Reply with quote
Semper what is a ultrasonic sink?
Semper_Dad
PostPosted: Thu Mar 07, 2013 6:43 am    Post subject: Reply with quote
It's basically a parts cleaner with a build in vibrator.
http://www.harborfreight.com/25-liter-ultrasonic-cleaner-95563.html
gonebaby
gonebaby is offline
PostPosted: Thu Mar 07, 2013 7:39 am    Post subject: Reply with quote
Awesome going to hf this weekend to pick up a sandblaster cabinet so Ill buy one of those too. Do they sell the powder? And i throw the whole door handle in it at a time? Rob
Joe 20
Joe 20 is offline
PostPosted: Thu Mar 07, 2013 9:19 pm    Post subject: Reply with quote
Semper, mine are clean.
euromog
euromog is offline
PostPosted: Fri Mar 08, 2013 7:53 am    Post subject: Reply with quote
I dipped mine in a bucket of carb cleaner over night. The old grease almost turns into a soft plastic it seems like. The carb cleaner gets into places you can't scrub. Then lube with something other than a WD40 like product that will actually stay and not evaporate. I use Wurth HHS2000.
DerrickfromNC1
DerrickfromNC1 is offline
PostPosted: Tue Nov 14, 2017 10:28 am    Post subject: Reply with quote
The rear door on my Thing will not open and the rotating latch is in the closed position as it should however it will not release when the inside or outside door handle is used. Is there a trick to getting the latch to release to the half position. No amount of prying will get it to release and I want to avoid removing the hinges so l won't have chipped paint on the hinges and hinge screws.
74 Thing
74 Thing is offline
PostPosted: Tue Nov 14, 2017 10:58 am    Post subject: Re: Door Latched Don't Work? Reply with quote
Dumb question but is the door locked.
From memory I think it is opposite of a "normal" car-black knob up is locked and black knob pushed down is unlocked.
DerrickfromNC1
PostPosted: Tue Nov 14, 2017 11:10 am    Post subject: Re: Door Latched Don't Work? Reply with quote
I'm a new 73 thing owner and I didn't know the rear doors could be locked! Now where is the black knob? Someone have a pix?
Thanks
CraigInPA
CraigInPA is offline
PostPosted: Wed Nov 15, 2017 8:21 am    Post subject: Re: Door Latched Don't Work? Reply with quote
The black knob is the handle one uses to open the door from the inside of the car.
kubelmann
kubelmann is offline
PostPosted: Wed Nov 15, 2017 10:47 am    Post subject: Re: Door Latched Don't Work? Reply with quote
