RockStock Samba Member
Joined: November 26, 2004 Posts: 3924 Location: England
Posted: Tue Mar 12, 2013 12:03 pm Post subject: |
Steering wheel looks good!
How easy is it to change the colour to ivory?
Steering column OD is 32mm. Taken from a 54/55. _________________ -StockRocks- |
das20v Samba Member
Joined: July 04, 2006 Posts: 147 Location: Garden Grove, Cali USA
Posted: Tue Mar 12, 2013 3:26 pm Post subject: |
j.pickens wrote: |
I have an accurate stl file of the semaphore switch knob I can post to you, if it helps. |
That's pretty cool! Do you have this setup at home? Yours is a filament type?
As far as the knob goes, I wouldn't need the file...but I could use just diameter and height dimensions...my final output will be 1/16 scale...so that knob will be SMALL! |
das20v Samba Member
Posted: Tue Mar 12, 2013 3:36 pm Post subject: |
2Pack wrote: |
That looks awesome!
I don't know how far you want to go with the details, but you may want to pick a production date. The steering tube for example was skinny, then fat in '51, then skinny again as I read on here somewhere. |
I think I'll stick with 1952. I am making extensive use of StatusVW's restoration images...BTW....I do not have access to an actual Barndoor, so everything I am making is based off of images, specs and documentation...and of course you guys!
As I was asked (not sure by who at this moment) about 3D model file availability when I am done, I just want to point out that FIRST AND FOREMOST, I want this to be a quality model. The original plan was to make masters in 1/16 scale from a 3D print, then cast resin and vacuform parts from those masters....which is ultimately cheaper for making duplicates. The other thing is that 3D prints have stepping and cannot get extra-fine crisp or really smooth detail (yet), so once I get the 3D printed parts, they will get the sanding, priming and final details that arent possible in 3D print...then I will make copies off of that. So it may be possible that this will eventually be a kit (for those interested). When it comes to that point, I am sure that I can offer a nice discount for those who helped me out. |
das20v Samba Member
Posted: Tue Mar 12, 2013 3:52 pm Post subject: |
RockStock wrote: |
Steering column OD is 32mm. Taken from a 54/55. |
Thanks for the dimension!!!
Ivory? Like this??
das20v Samba Member
Posted: Wed Mar 13, 2013 1:39 am Post subject: Brake & License Lamps |
Added these two little goodies to the rear engine lid. The brake lamp has a fluted lens, but in 1/16 scale, I have doubts that 3D printing can bring out that detail. Nonetheless, I modeled it. Looks convincing!
mcdronkz Samba Member
Joined: December 09, 2005 Posts: 446 Location: The Netherlands
Posted: Thu Mar 14, 2013 8:15 am Post subject: |
Wow, magnificent modeling work! How long have you been working with SolidWorks? I'm learning polygonal modeling right now to complement my photography which proves to be a real challenge, but this looks much harder to me so loads of respect for that. |
das20v Samba Member
Posted: Thu Mar 14, 2013 8:51 am Post subject: |
mcdronkz wrote: |
Thanks mcdronkz. I have been using Solidwoks since 2007. By far, it is the most user friendly 3D CAD software I have ever used. It is capable of some amazing results. I learned how to use it by following it's own included tutorials, and got the basics down in a few days of goofing around. Once you learn the basics, the sky is the limit! |
Patty B. Samba Member
Joined: July 14, 2005 Posts: 2181 Location: Brampton, Ontario, Canada
D-train Samba Member
Posted: Fri Mar 22, 2013 1:52 am Post subject: |
i want one an its not done!! _________________ shiny paint doesnt make it worth any more |
das20v Samba Member
Posted: Fri Mar 22, 2013 10:47 am Post subject: |
@Patty B.: yes, there are many graphics at that site, but more or less just general arrangements. For this project, actual part dimensions will get more accurate results (wherever possible). Thank you.
@D-Train: Thank you. It will be a while.
ANyhow, I have been working on the dash pod and speedo. It's almost ready to post. Maybe today or tomorrow I will show it. |
das20v Samba Member
Posted: Fri Mar 22, 2013 12:45 pm Post subject: Dash Pod |
Here is the Dash Pod. Missing is the dentent for the steering column and the mounting holes. The backside will be blended into the front frame, so I didnt worry too much about the countours yet, they will be defined later.
I am working on the speedo face right now. I actually made a nice representation of the Veigel Speedometer, but after a few trial printings in 1/16 scale, it is just basically a black dot, so I am simplifying the features so it looks "right" in 1/16 scale....when I get it into the 3D model, you will see it is very simple and vaguely like a Veigel, but oh well.
Anyhow, here is my latest update. I hope you all like it. Suggestions are always welcome!
EverettB Administrator
Joined: April 11, 2000 Posts: 69813 Location: Phoenix Metro
Posted: Fri Mar 22, 2013 4:42 pm Post subject: |
Very nice work.
My pod feedback (sort of nit-picky so ignore if you like):
The semaphore switch has more of a threaded ring that holds it in place:
Also the key slot is not a full slot left to right:
Also the hardware that attached the pod in place on the sides are bolts.
They look smooth in your diagram. _________________ How to Post Photos
das20v Samba Member
Posted: Mon Mar 25, 2013 1:09 am Post subject: Update 3/25/2013 |
Thanks Everett, your feedback is useful and welcome.
I have to remind myself that even those 1/16th scale is somewhat considered as a larger scale in model cars, many fine details cannot be reproduced...and those that are are just not visible anyway. Nonetheless, I will try my best to get visible details correct as best I can, and see how they turn out after 3D printing. I have a feeling that I will need to go back and manually add some details the get lost in printing. So here it is, the dash pod...revised and this time with the simplified speedo face. Remember also that this speedo face is a scaled version, made to "look right" when shrunken down 16X.
And here is a test-print onto clear film next to a US Dime...the sharp eyed folks will realize that the spedo face is reversed in this picture...also rotated.
Thats about all for now. I will revisit the steering wheel and fix the horn button, then off to building the chassis framework. Stay tuned! |
Posted: Mon Mar 25, 2013 2:00 am Post subject: |
Love it!! Will u make a rhd version too? _________________ shiny paint doesnt make it worth any more |
2Pack Samba Member
Joined: September 20, 2005 Posts: 807 Location: Virginia
Posted: Mon Mar 25, 2013 1:17 pm Post subject: Re: Update 3/25/2013 |
The circle above the fuse holder is a cigarrette lighter right? If so, that is cool, but not stock. Just so you know. _________________ Please buy my Treasure |
das20v Samba Member
Posted: Mon Mar 25, 2013 2:21 pm Post subject: |
2Pack...are you sure? I got this out of the '52 owners manual, and referenced the part number from the VW parts list.
Anyone else have anything difierent to confirm this socket as factory original or not?
das20v Samba Member
Posted: Mon Mar 25, 2013 2:35 pm Post subject: |
D-train wrote: |
Love it!! Will u make a rhd version too? |
I am thinking about that already. If I make a kit, I might offer parts to make either LHD & RHD, it shouldn't be that difficult...dash pod, floor panel(s), pedals and steering box assy....or something like that. At least it isn't a full-width dashboard and center console, mirrors and the whole 9 yards. It should be do-able. |
Anchovy Samba Member
Joined: August 05, 2000 Posts: 2922 Location: San Diego, CA
Posted: Mon Mar 25, 2013 3:24 pm Post subject: |
The early dash pod 50-52, like you are going for, should have a radius for the steering column like shown on Tonny's site here:
Also, the "cigarette socket" is actually a DIN plug socket, so smaller than a US cig. socket, and aluminum in color. |
das20v Samba Member
Posted: Mon Mar 25, 2013 4:02 pm Post subject: |
Anchovy wrote: |
Outside Ø20.87mm is what I have for the DIN socket, and have it set as an aluminum finish, but the picture I posted it looks dark gray in display for some reason. Does that size seem right? It should be a near exact dimension.
For the steering column, I will add the detent and mounting holes later when I set the coulmn into the pod. I don't have the exact geometry yet, so it is easier for me to make a cavity into the pod using the column itself (make sense?)...either case, I will get to that later, including the clamp bracket and bolts. I am eager to get that part done, but it's a hassle to go back and rearrange bad geometry if I get it wrong. I kind of mentioned this back on 3/22, but it is hard to explain. No worries though, I appreciate your input. [/quote] |
2Pack Samba Member
Posted: Mon Mar 25, 2013 7:32 pm Post subject: |
You're way ahead of me. I never knew about the DIN socket. Glad I found out now before I stuck my cigarette in one. _________________ Please buy my Treasure |
