'67 Subaru Powered Fastback (It's Alive!)
Bliss13
Bliss13 is offline
PostPosted: Sun Mar 24, 2013 11:46 pm    Post subject: Reply with quote
FastyinaField wrote:
The DOHC 2.5l is only 165hp, not 190. They also have a pretty poor headgasket reputation. The bad headgaskets often lead to bad rod bearings because people will run the engines until they stop from massive overheating when the headgaskets go. The engine will fire back up after it cools off and a shop replaces just the headgaskets, sending a hurt engine back out to blow the rest of the way up shortly after.
They are a good engine, they just have a bad reputation due to the headgaskets. Replace them preemptively with the updated ones from Subaru and it will be a great engine for you.
These engines make up to 200 hp stock when matched up with this ECU. That's pretty well documented. This one was put on the dyno and made 190 hp. I read up on the head gasket issue while I was considering this car. A lot of them get over 100,000 miles before this happens. I'm hoping that mine were changed when this swap was done. It's something I will be keeping a close eye on. Thanks for the "heads" up Laughing
1970 Sundial Camper
1973 SubaBeetle
1986 Vanagon Syncro
vlad01
vlad01 is offline
PostPosted: Mon Mar 25, 2013 3:33 am    Post subject: Reply with quote
leaky gasket? no probs, replace with MLS gasket they will never leak again.
vlad01
vlad01 is offline
PostPosted: Mon Mar 25, 2013 3:35 am    Post subject: Reply with quote
supaninja wrote:
I would get a spare trans before that one splodes Wink
Then figure out what you want to do for the long term, 901 or 091. Type 1/3 trannies are just too fragile (that should get some panties in a wad, hehe)for that power and especially that tq.
easiest option.
http://www.subarugears.com/
some type 3 love right here Cool
http://www.subarugears.com/Builds/Chris%20Type%203/Chris.html
supaninja
supaninja is offline
PostPosted: Mon Mar 25, 2013 6:00 am    Post subject: Reply with quote
Good catch Vlad, the scooby tranny seems like a no brainer.
http://i5.photobucket.com/albums/y163/chucky1974/ninja.gif
Nick
Megasquirted Type 4 powered Notch http://www.thesamba.com/vw/forum/viewtopic.php?t=427890&postdays=0&postorder=asc&start=0
Blog of Doom http://supaninjanick.wordpress.com/
View user's profile Send private message Send e-mail Yahoo Messenger Facebook Classifieds Feedback
Bliss13
Bliss13 is offline
PostPosted: Mon Mar 25, 2013 7:06 am    Post subject: Reply with quote
easiest option.
It almost seems too easy! like, no major mods or cutting. I need to look into this a little more, but it definitely seems like the way to go. Wow, that guy did some serious tube minipulation on that notch. Gives me some great ideas.
1970 Sundial Camper
1973 SubaBeetle
1986 Vanagon Syncro
vlad01
vlad01 is offline
PostPosted: Mon Mar 25, 2013 5:59 pm    Post subject: Reply with quote
it is too easy, thats why Jake is now using them now.
And if Jake does then you know its good.
vlad01
vlad01 is offline
PostPosted: Mon Mar 25, 2013 6:05 pm    Post subject: Reply with quote
what do you mean good catch? I thought this was industry standard when doing a suby conversion.
always thought "wtf?" when people were using adapters and doing all this crap to run suby engine with porsche box. why when you got this?
and then people say Aussie's did nothing for the vw community. Rolling Eyes
now vws can be strong and powerful and no longer fragile.
isn't that right Tram Wink
Mr. Unpopular
Mr. Unpopular is offline
PostPosted: Tue Mar 26, 2013 1:22 am    Post subject: Reply with quote
vlad01 wrote:
And if Jake does then you know its expensive.
Fixed that for you.
And while all of you australians think anything subaru is god's gift to the motoring world, it's not the solution to every situation.
The gears are expensive, and subaru trans are not bulletproof. Now maybe with a stock non-turbo motor in 2wd it may hold up, but it's not like swapping in a mendeola or anything.
All in good fun BTW. Very Happy
"In any racing engine, the nearer you are to it disintegrating, the better it's performance will be"
-Keith Duckworth, creator of the Ford/Cosworth DFV
Bliss13
Bliss13 is offline
PostPosted: Fri May 24, 2013 11:24 am    Post subject: Reply with quote
Car has been performing very well. It's really fast and sounds great with a stock muffler. It started running hot at one point, and after pulling the thermostat and wasting a bunch of time I figured out there was a loose bleed valve that had allowed air in the system. Still working on the plumbing one piece at a time. I've also gathered most of the turbo parts. . . more pics to come after I finish the radiator mounts this weekend (hopefully)
1970 Sundial Camper
1973 SubaBeetle
1986 Vanagon Syncro
POWER ON
POWER ON is offline
PostPosted: Tue Jun 04, 2013 11:23 am    Post subject: Reply with quote
Glad you like it Smile We too love it. Check this run at the Hilo drag strip. This is with auto trans and AC too.
http://s174.photobucket.com/user/brisonboy/media/IMG_1622_zps4dc1e1b8.mp4.html
Bliss13
Bliss13 is offline
PostPosted: Tue Jun 04, 2013 6:54 pm    Post subject: Reply with quote
Nice! What type of transmission are you running?
1970 Sundial Camper
1973 SubaBeetle
1986 Vanagon Syncro
POWER ON
POWER ON is offline
PostPosted: Tue Jun 04, 2013 7:01 pm    Post subject: Reply with quote
Vanagon with custon mounts. Was all by chance but worked out real well.
Thanks
Bliss13
Bliss13 is offline
PostPosted: Sun Oct 06, 2013 8:19 pm    Post subject: 1967 Subaru Powered Fastback (I'm back) Reply with quote
So I'm back at it. Getting the seats recovered now and next I want to stop the heat from coming in through the back seat. Deciding on either building a cover for the engine or building a firewall behind the seat itself with some kind of heat proof material stuck to it.
1970 Sundial Camper
1973 SubaBeetle
1986 Vanagon Syncro
W1K1
W1K1 is offline
PostPosted: Mon Oct 07, 2013 6:54 am    Post subject: Reply with quote
I found the ez cool from lobucrod works very well for noise and heat.
http://www.lobucrod.com/
http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
Bliss13
Bliss13 is offline
PostPosted: Mon Oct 07, 2013 3:54 pm    Post subject: 1967 Subaru Powered Fastback Reply with quote
Thanks, this looks like exactly what I need to put an end to long, sweaty trips. I ordered a roll and should have it before the end of the week.
1970 Sundial Camper
1973 SubaBeetle
1986 Vanagon Syncro
Bliss13
Bliss13 is offline
PostPosted: Fri Oct 11, 2013 10:15 am    Post subject: Reply with quote
Got my seats and door panels done
Nice stance, but bumpy. Drop spindles are in the works
1970 Sundial Camper
1973 SubaBeetle
1986 Vanagon Syncro
qoopwn
qoopwn is offline
PostPosted: Fri Oct 11, 2013 4:05 pm    Post subject: Reply with quote
So what tranny is in the car? The one from Subarugears or are you running a tranny with the kennedy adapter plate? Could you take some pictures of the mounts that hold the engine in? I'm trying to get some ideas.
Bliss13
Bliss13 is offline
PostPosted: Sat Oct 12, 2013 9:13 am    Post subject: Reply with quote
Stock tranny with Kennedy adapter
1970 Sundial Camper
1973 SubaBeetle
1986 Vanagon Syncro
Mike Fisher
Mike Fisher is offline
PostPosted: Sat Oct 12, 2013 9:18 am    Post subject: Reply with quote
What are your air pressures? You only need 20/24 lbs air pressure in the fronts/backs.
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Nate M.
Nate M. is offline
PostPosted: Sat Oct 12, 2013 9:43 am    Post subject: Reply with quote
Your interior looks fantastic!! Congrats!
That is one sweet looking Fasty you have there. I'll bet you have lots of fun playing with the H*nda fart-cars in your area. . . Twisted Evil
Keep up the good work!!
Regards,
Nate M.
Squarsche build
Heavy Metal Affliction feature
For heaven's sake, put a type4 and a Porsche 5-speed in there. . . It's the right thing to do!!
Page 4 of 8
