p.e.i.vw Samba Member
Joined: February 18, 2005 Posts: 144 Location: Edmonton Alberta
Posted: Tue Mar 12, 2013 3:43 pm Post subject: So 23 Childs Cot Pole Bracket Pics |
Hey all, I did some searching but have had no luck, I am looking for pictures of where the brackets are located for the cot pole to hook into. Are the spilit pole ends similar to the bay window version? I have the brackets but no poles and am hoping to make them if I can get a couple of pics.
Any help would be greatly appreciated. |
bugcollections Samba Member
Posted: Tue Mar 12, 2013 6:13 pm Post subject: childs cot |
Are the SO-23 poles and brackets the same as an SO-42? SO-42 poles, cot and brackets are totally different than the bay window. |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Wed Mar 13, 2013 7:27 am Post subject: |
Those are exactly the ones I am looking for pics of HazetGuy. |
Kommercial Samba Moderator
Joined: December 28, 2000 Posts: 1154 Location: San Tan Valley, Arizona
vwboop Samba Member
Joined: April 04, 2004 Posts: 716 Location: Langley, BC
Posted: Thu Mar 14, 2013 2:27 pm Post subject: |
from Brandon's "Holy Grail Garage"
_________________ "Love and good roads" |
Posted: Fri Mar 15, 2013 7:14 am Post subject: |
So are those brackets the same as the cargo door strap brackets? They look the same, which means I have the wrong ones. |
Posted: Fri Mar 15, 2013 7:24 am Post subject: |
p.e.i.vw wrote: |
the brackets in the pic posted by vwboop are incorrect and do look cargo door check strap brackets. while they might work, the correct ones are aluminum.
grailoc Samba Member
Joined: March 25, 2004 Posts: 1441 Location: FRANCE and now QUEBEC city
vwboop Samba Member
Posted: Fri Mar 15, 2013 9:10 am Post subject: |
Yeah...sorry I don't know if those are correct. It was just a pic I came across when I searched. _________________ "Love and good roads" |
velvetgreen Samba Member
Posted: Fri Mar 15, 2013 10:35 am Post subject: |
I have one of the brackets that you are looking for PM if interested
btw good eye for jon furst that does indeed look like a cargo door check strap bracket- black paint is a bit of a give away |
Posted: Fri Mar 15, 2013 10:45 am Post subject: |
looking at the pics again seems like the so23 cot brackets are the same as the so42 except that you only require two of them for so23's and four for so42's
here is a pic pf the so42 bracket
Posted: Fri Mar 15, 2013 10:49 am Post subject: |
Looks like I am back on track again as I do have the aluminum ones. Thanks every one for your help. |
vwboop Samba Member
Posted: Sat Mar 16, 2013 9:42 pm Post subject: |
Just noticed the 60 at Colome Motors has that same black cargo door strap bracket. Same ones pictured in the link on the SO23 registry site _________________ "Love and good roads" |
earlywesty Samba Member
Joined: May 03, 2004 Posts: 2358 Location: In the woods, Ontario
Posted: Sun Mar 17, 2013 4:55 am Post subject: |
The cot pole ends are different than later westys and bay window. I had the measurements here from the pole I had on my old bus but somehow misplaced them. A friend and I were going to do a short run of the poles as so23westfalia.com has stopped business some time ago.
I will draw the end of the pole and try to get it posted here although I wont have the measurements. It is kind of an odd shaped end actually, not sure it needs to be this shape to work, I guess it depends if you are going for correct or just making it work. The pole part hangs down below the end 'clip' piece that hooks in the bracket.
There is a crappy pic in the gallery from my '55, sorry can't link here right now as the gallery seems to be down...will try later.
edit: crappy pics
Posted: Mon Mar 18, 2013 10:51 am Post subject: |
That would be great, I appreciate it. |
Posted: Mon Mar 18, 2013 3:31 pm Post subject: |
okay so my graphic skills suck but hopefully you get the idea. of course it should be symmetrical on each side of the 'clip' part that goes in the bracket. PM if you have questions.
Stocknazi Samba Member
Posted: Thu Dec 14, 2017 5:57 pm Post subject: Re: So 23 Childs Cot Pole Bracket Pics |
Anyone know the diameter of this cot pole? Is it the same diameter as a SO-42/early round bay pole? _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
Braukuche Samba Member
Posted: Fri Dec 15, 2017 3:06 pm Post subject: Re: So 23 Childs Cot Pole Bracket Pics |
StockNazi wrote: |
Anyone know the diameter of this cot pole? Is it the same diameter as a SO-42/early round bay pole? |
In the thread in tent poles it is mentioned that the cot pole was smaller diameter but no specifics.
I just ordered the hammock thing and need to make one myself so hopefully someone will let us know. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
Posted: Sat Dec 16, 2017 6:21 am Post subject: Re: So 23 Childs Cot Pole Bracket Pics |
Braukuche wrote: |
StockNazi wrote: |
I just ordered the hammock thing and need to make one myself so hopefully someone will let us know. |
The reproduction one in the pics above was smaller than a late cot I believe. I had kept the measurements at the time but have no idea what happened to them. |
