vanis13 Samba Member
Joined: August 15, 2010 Posts: 3092 Location: ABQ NM USA.... Except when not
Posted: Mon Dec 29, 2014 8:45 am Post subject: |
indytriple wrote: |
I put the following things in my 15" steel spare:
-1 Gallon Coolant
-1 Quart Engine Oil
-1 Quart ATF
-ATF Funnel
-12 Shop Rags
It doesn't show in this picture, but everything is placed within a heavy duty trash bag before being stowed away to keep everything clean, and to contain any potential leaks of fluids.
how does this fit with the shifter box that seems to extend into the center space in the tire? _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
indytriple Samba Member
Joined: April 27, 2009 Posts: 710 Location: Brownsburg, Indiana
Posted: Mon Dec 29, 2014 8:51 am Post subject: |
vanis13 wrote: |
indytriple wrote: |
-1 Gallon Coolant
-1 Quart Engine Oil
-1 Quart ATF
-ATF Funnel
-12 Shop Rags
how does this fit with the shifter box that seems to extend into the center space in the tire? |
It doesn't interfere with anything. Keep in mind that I have an auto tranny. This may not work with a manual. To fit the 15" spare I also had to remove the steel, upper restraining rods and install bolts and nylock nuts to create hinges for the clamshell. I also added as many spacers as possible between the clamshell and body at the mounting bolt to gain a little more space. _________________ "See The Glass As Already Broken."
87 Vanagon Westy Auto Bostig
www.bluegrassbicyclecompany.com
porterbrown Samba Member
Joined: February 25, 2005 Posts: 718 Location: Bentonville, AR
Posted: Mon Dec 29, 2014 8:52 am Post subject: |
For those that have had the clamshell vacant for a while, does anybody else have a terrible rattle coming from that area due to the clamshell being empty? I'm wondering if a rubber washer at the front bolt will do the trick. _________________ '90 Westfalia GL Automatic |
davevickery Samba Member
Joined: July 16, 2005 Posts: 2887 Location: Fort Collins, CO
Posted: Mon Dec 29, 2014 12:20 pm Post subject: |
The best simple solution I saw was someone used a spare tire (no wheel). They cut the top sidewall back so it was easy to access and stuffed odds and ends into the tire. Probbaly need to cut a few drain holes in the bottom sidewall too. I'm sure that would help with rattling too. |
DAV!D Samba Member
Joined: September 10, 2013 Posts: 979 Location: EL CAMINO
Posted: Mon Dec 29, 2014 1:10 pm Post subject: |
There was a topic awhile back, where someone built a water tank by plastic welding two jugs together and then mounted it inside the clam shell. Seems like a nice spot for an extra water tank if you need more water.
That LP tank looks pretty neat too, except the price tag and the fact that 11 gals is a lot of extra weight assuming you fill it up. _________________ 86 Syncro Build - Ecotec Motor Swap - Pop Top Conversion - Camper Build & Syncro Conversion |
MsTaboo Samba Member
Joined: June 02, 2006 Posts: 4087 Location: East Kootenay, British Columbia
Posted: Mon Dec 29, 2014 2:41 pm Post subject: |
porterbrown wrote: |
For those that have had the clamshell vacant for a while, does anybody else have a terrible rattle coming from that area due to the clamshell being empty? I'm wondering if a rubber washer at the front bolt will do the trick. |
Have you tightened the safety bolt down? I've been traveling with an empty clamshell for awhile now in my Syncro Westy with no rattles at all.
I put a regular sized spare in there for long off road trips, (have a decoupler) but leave it empty otherwise to save weight. _________________ Currently:
seventyfo Samba Member
Joined: February 13, 2007 Posts: 916 Location: Ocoee FL
Posted: Mon Dec 29, 2014 9:41 pm Post subject: |
I used a section of a fiberglass water tank and a big gray trash can lid with three lockable snaps. I carry most of my spares and recovery gear in it. _________________ 85 Vanagon GL Westy GW 2.2 (Rebuilt by YT)
"I don't know you well enough to care about your comments". Watkins Cravey |
syncroboi Samba Member
Joined: October 04, 2011 Posts: 40 Location: Boise, ID
Posted: Tue Dec 30, 2014 12:04 am Post subject: |
For me that rattle was coming from the springs/rods that hold the clamshell on. I removed them and got some bolts to re-attach the clamshell to use for storage. |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16501 Location: Brookeville, MD
morymob Samba Member
Posted: Tue Dec 30, 2014 7:36 am Post subject: |
Just some small parts, 2nd set belts,oil,etc in heavy water proof bag inside tire rim. |
Posted: Tue Dec 30, 2014 7:04 pm Post subject: |
Snow? Wazzat? _________________ 85 Vanagon GL Westy GW 2.2 (Rebuilt by YT)
Posted: Tue Jan 06, 2015 8:48 am Post subject: |
My recovery gear amounts to : a tow strap _________________ 85 Vanagon GL Westy GW 2.2 (Rebuilt by YT)
otiswesty Samba Member
Joined: November 21, 2006 Posts: 1730 Location: Portland
Posted: Tue Jan 06, 2015 12:12 pm Post subject: |
That's awesome! _________________ 1978 Sage Green P22 Westfalia
1989 T3 Syncro Single cab
Just a regular guy |
