MagmaJctAz Samba Member
Joined: November 26, 2011 Posts: 289 Location: Mesa, AZ
Posted: Sat May 30, 2015 12:44 pm Post subject: |
jpjohns wrote: |
vwracerdave wrote: |
I buy my Mahle piston/cylinder sets from a vendor that will open 20 sets at a time and then repackage them by matching weights. I've gotten 4 that were dead on the same without any further machining. He does charge a few dollars extra to do this. |
Me too, now I'm curious. |
Thread resurrection?
My current set I've been running for several years now I bought from Aircooled.net. I don't know if they still pick through sets and match the weights.
Wow, I did a quick search to verify my memory, and they've got a TON of P&Cs! Check them out, I'll let you find them!
http://vwparts.aircooled.net/SearchResults.asp?Search=+piston+cylinders
Regards,
Mike _________________ 1974 Super Beetle. Owned since 1995. Daily Driver. Turned over odometer twice!
1971 Fastback. Check out my Fastback resurrection thread!
http://www.thesamba.com/vw/forum/viewtopic.php?t=627711&highlight= |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
Posted: Sat May 30, 2015 12:48 pm Post subject: |
ralf wrote: |
flyboat wrote: |
Who's the vendor? |
wondering too |
Might be Berg (pick-of-the-litter).
Max _________________ 1967 Type-3 Fastback
Home Stretch https://www.thesamba.com/vw/forum/viewtopic.php?t=767836 |
nsracing Samba Member
Posted: Sat May 30, 2015 6:58 pm Post subject: |
If it looks like Swiss cheeze, they used a drillbit to put ten million dimples on there. It will work but those dimples can hold oil by capillary action and really offset the balance job.
And endmill cut is cleaner and cuts flat will be my choice.
Stock Mahles can be out as much by 5 or so grams. but 20 grams is a LOT to take off. You gotta be creative w/ the cuts without hurting the integrity of the pistons.
That is a nice SouthBend lathe pictured up there. Matching bed stop and taper attachement too. NICE! |
