This isn't original, is it? Also, While the engine is out...
Atx67beetle
Atx67beetle is offline
PostPosted: Mon Mar 18, 2013 2:39 am    Post subject: This isn't original, is it? Also, While the engine is out... Reply with quote
I'm working on my first bug (67) and first resto project. I'm planning to start a thread on my build, but haven't made time for that yet.
A couple of engine questions
1) My engine appears to be a 1600 with an engine code beginning with AE.
Am I correct in thinking that this is from a 1972? Beetle?
2) I drove the car home (almost 100 miles) when I purchased it. The engine seemed to run fine. I noticed some oil spots on the driveway after parking it over night, but I think that it might have been gear oil, as both rear axle boots were ripped. I plan to change the oil, valve job, and remove the engine tins for cleaning and paint. With that having been said, what else should I do with the engine while I have it out? Is there an easy way to see if the rear seal is leaking? Should I take it to my local VW shop for a once over, compression test, any thing else? Any suggestions would be much appreciated!
"It should not be the the aim of the motor industry simply to bring out new models, but rather to produce and sell."
Heinrich Nordhoff
andk5591
andk5591 is offline
PostPosted: Mon Mar 18, 2013 3:54 am    Post subject: Reply with quote
One piece of advice - make note of places that have crud before you clean the engine. Helps identify leaking areas. And before you even pull it, I would have a leakdown test done and a general "health assessment."
Theres threads that have a laundry list of what to do when you have it
Here's one:
http://www.thesamba.com/vw/forum/viewtopic.php?t=539221&highlight=pulling
D-Dubya Manx clone - 63 Short pan,1914.
There's more, but not keeping them...
Atx67beetle
PostPosted: Mon Mar 18, 2013 1:55 pm    Post subject: Reply with quote
I saw that thread, but I'm not looking to do a minor engine overhaul unless it needs it. With most vehicles I can understand the, "while you have the engine out" idea, but the vw engine is so easy to remove, I don't see the logic in doing a minor overhaul, just because the engine is out of the car. But, if there are internal engine repairs needed, I would prefer to do them now if it will save me $ in the long run. Is this more of a stitch in time saves 9 sort of thing?
Heinrich Nordhoff
vw_partsguy
vw_partsguy is offline
PostPosted: Mon Mar 18, 2013 3:21 pm    Post subject: Reply with quote
The engine is a 1600 Dual port which makes it a 72 and later type. If it runs well and don't knock or smoke. I would just clean it up, paint a few pieces of tin and pulleys, oil cooler seals, seal up the engine compartment and roll it. -Louie
2018 MK7.5 GTI “Pearl”
2017 MK7 GTI "Sparrow"
2000 Eurovan "Chuggs"
1997 Jetta Jazz "JJ"
2002 Jetta Variant "Jazzy"
1967 Beetle "Buddy" Deceased
1989 Golf GTI Montana green Deceased
1967 Beetle "Mr Blue" Deceased
Michael Fischer
Michael Fischer is offline
PostPosted: Mon Mar 18, 2013 3:32 pm    Post subject: Reply with quote
I would change out the intake boots. They look like they are toast. And I would invest in some real plugs for the vacuum ports. And get the correct breastplate for the motor so you can hook up the preheat. Do you have the 2 small deflector tins that go under the breastplate? Should probably put better quality fuel line on it too.
andk5591
andk5591 is offline
PostPosted: Mon Mar 18, 2013 4:17 pm    Post subject: Reply with quote
Say that to me again after you have reinstalled the engine and got it running again Laughing
I know that guys can drop these engines and reinstall them in under an hour in the dark on the dunes while drunk on their butts. And maybe thats always been my problem Laughing . Not drunk or sandy and I have light.
Not a "pro" but am at the point where I honestly dont remember how many engines I have pulled and installed. At least 1/2 were done solo. The only time its been totally uneventful, fast and easy is with a bare pan.
Some of the folks on the thread I submitted go a "little" overboard IMHO, but thought you should have some ideas. I just did 2 top end rebuilds in the last couple months plus cosmetic freshening, new main seal, tranny input shaft seal, oil cooler seals since I saw evidence of a leak. You want to make sure your tranny mounts are in good shape to.
But you really want to know what you have first. Saves you time and money later.
Eric&Barb
Eric&Barb is offline
PostPosted: Mon Mar 18, 2013 8:33 pm    Post subject: Reply with quote
You need the rear lower cylinder tins and the tin pieces that seal the rear tin to the intake manifold heat riser tubes. Parts # 8 & 32.
Post images of the front side of the engine!
In Stereo, Where Available!
bugheadred
bugheadred is offline
PostPosted: Mon Mar 18, 2013 9:08 pm    Post subject: Reply with quote
i would change the tranny output shaft seal
Atx67beetle
PostPosted: Mon Mar 18, 2013 10:08 pm    Post subject: Reply with quote
Thanks for all the feed back! I would making far more mistakes if it weren't for all of the help of all you kind samba folks!!!
Here are a few more engine pics as well as a shot of my pan in its current state.
Here's a close up of the oil splatter.
Heinrich Nordhoff
dschup
dschup is offline
PostPosted: Tue Mar 19, 2013 5:21 am    Post subject: Reply with quote
Do you have the list that goes along with this?
Thanks in advance.
Eric&Barb
PostPosted: Tue Mar 19, 2013 6:44 am    Post subject: Reply with quote
Yes, the parts manual.
Looks like you are missing all the tin and seals in the top part of the diagram.
8a and 8b tin pieces are for the Thing which does not use the heat exchangers.
Also missing thermostatic flaps and thermostat.
Eric&Barb
PostPosted: Tue Mar 19, 2013 6:52 am    Post subject: Reply with quote
Would be good to get the 1967 only air cleaner and rear tin. Then get the preheat tubes for the carb to help keep icing away.
The rear tin you have now is for an early 1500 bus and hard to find. So a good item to sell or trade.
Need to get the rubber seals in the rear apron.
If you open the engine lid and can see right down to the pavement, you have an air leak that will cause a hotter engine.
Joel
Joel is offline
PostPosted: Wed Mar 20, 2013 2:17 am    Post subject: Reply with quote
Dump that 009 dist for the correct SVDA 034 one, the engine will perform 100x better
Eric&Barb
PostPosted: Wed Mar 20, 2013 3:04 am    Post subject: Reply with quote
The type 2 parts reference manuals are a good source of info for engine parts since the bus and beetle used almost the same exact parts.
The 1960s manual there will cover most of the diagram except for the upper doghouse tin shown.
http://www.oacdp.org/
dschup
dschup is offline
PostPosted: Wed Mar 20, 2013 5:15 am    Post subject: Reply with quote
Thank you, I've got a 1600cc engine that was in a buggy and I'm missing more tin than I thought.
Eric&Barb
PostPosted: Wed Mar 20, 2013 6:49 am    Post subject: Reply with quote
No problem.
#29 is the only stock piece that you could run without, all the rest you need. Sorting out between what you have now and need is the trick. For instance the pre-1968 rear and pulley tins can not be mixed up with post-1967 of those tins or gaps will occur.
Post some images of the engine or the tins you do have, and what VW are you installing it in.
Atx67beetle
PostPosted: Fri Mar 22, 2013 12:12 pm    Post subject: Reply with quote
Thanks for the replies.
Eric and Barb,
Should the engine tins be specific to they year of the car of the engine. From what I can tell, this engine is from 1972 or so. Shouldn't I use engine tins from that year? Or are the tins more specific to the body of the vehicle?
Joel,
I'm thinking of going to al electronic ignition system. Is that advisable? Is there one that you would recommend?
Heinrich Nordhoff
Eric&Barb
PostPosted: Sat Mar 23, 2013 8:21 am    Post subject: Reply with quote
You can use any of rear engine tins used for 1500/1600 engines, but you have such a mix of tins right now. Figure you might as well get the correct rear tin and air cleaner for 1967. That would give the engine a more correct look for the year of your VW.
Then later if you or the next owner decides to restore the engine those parts are already at hand.
As is you could run what you have now, but need to block off the hole in the rear tin (tin can lids and screw/bolt and nut will work), but then you would not have preheat for the carb. That will cause icing problems in certain weather conditions.
