MikeGatch Samba Member
Joined: April 01, 2009 Posts: 445 Location: Valparaiso IN
Posted: Sat Mar 23, 2013 1:37 pm Post subject: Picked up a 2016 for $500 |
So, I just got back from driving 200 miles round trip to look at a super beetle north of chicago. I was interested in the whole car, but it was pretty rough. The engine is a 2016 Have some receipts from MOFOCO for machine work etc as well as another place I forget the name of.
It has a pretty large diameter exhaust system on it, guy said he wanted it to breathe, but a webber progressive sat atop the engine with no preheat, so that will have to go. It turns over smooth with what feels like a TON of compression and the oil was very clean.
I have a pair of 36 drlas that probabvly need a rebuild, a pair of webber 40s that are up at MOFOCO, and the 34 icts That I am currently running on my tired tired engine.
I know guys have run stock carbs on big engines, and it's an option short term, but I am wondering if I'd be able to get this engine running temporarily using my icts.
I know anything shy of double barrel duals isn't going to be ideal, but I'm wondering if it would be worth the effort to run it with the icts for awhile and get the 40s rebuilt for this engine and the 36s rebuilt for the 1915 I'm building, well, it's up at MOFOCO as well. I had them assemble the short block and open up the case and heads. They had their hands in this engine in 89. Which may or may not be a good thing =P
Edit: Info provided on engine is this.
2016cc, stroker II counter weighted crankshaft, engle cam 286' duration, 410 lift, 042 cylinder heads with 40mm intake, 35.5mm exhaust valves, HD springs, high volume oil pump, lightened flywheel. _________________ Daily Driver: 73 STD Beetle.
Road tripper: 82 diesel westy vanagon. (Won't idle work in progress)
Adequately powered road tripper: 73 campmobile.
Bugs with no legs. 1 72 standard and 2 super verts.
Quokka42 Samba Member
Joined: December 02, 2010 Posts: 3117 Location: Melbourne, Australia
Posted: Sat Mar 23, 2013 2:07 pm Post subject: |
You probably go it cheap because of the missing 1cc...
Yes, it will run with the ICTs. I use them for the fact they will start and run just about anything. If you have a decent cam they will idle rough and may be poortly off the mark, plus you are aware the engine will run out about 4500 rpm or less?
But they will run, and once you get on the cam you will be surprised how well 'till they run out. _________________ There has only ever been one man who was perfect, and they nailed Him to a cross. |
Posted: Sat Mar 23, 2013 2:16 pm Post subject: |
Haha, well, I've never run anything bigger than a 1641, sooooo this thing should surprise the hell out of me then. I'm going to swap engine tomorrow morning, drive around for a bit then have to go to indianapolis all week for work. Blah! _________________ Daily Driver: 73 STD Beetle.
Bugs with no legs. 1 72 standard and 2 super verts. |
Posted: Sun Mar 24, 2013 5:01 am Post subject: |
Oh yeah, did I mention I picked it up with my bug? _________________ Daily Driver: 73 STD Beetle.
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Sun Mar 24, 2013 10:50 am Post subject: |
I bet it was fun putting it in there! |
Sigurd Samba Member
Joined: April 18, 2006 Posts: 2639 Location: Rockford, IL
Posted: Sun Mar 24, 2013 12:46 pm Post subject: |
That's impressive! |
mark tucker Samba Member
Posted: Sun Mar 24, 2013 2:18 pm Post subject: |
should of put it in the front & added some extra shafts for an awd bug.dont hurt your self getting it out. |
66brm Samba Member
Joined: January 25, 2010 Posts: 3676 Location: Perth Western Australia
Posted: Sun Mar 24, 2013 5:45 pm Post subject: |
I've found that if you have a longblock you need to get home pull the passenger seat, and slip it onto the backseat, the longblock then sits on the floor between the seat rails, I've also transported my toolbox like that occasionally. _________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote: |
I am an expert at fitting things in holes, been doing it a long time |
Posted: Sun Mar 24, 2013 7:45 pm Post subject: |
I strive to allways build my motors so you dont need any extras on the road, sofar it has worked out just fine. |
bugninva Samba Member
Joined: December 14, 2004 Posts: 8858 Location: sound it out.
Posted: Sun Mar 24, 2013 8:11 pm Post subject: |
66brm wrote: |
I've found that if you have a longblock you need to get home pull the passenger seat, and slip it onto the backseat, the longblock then sits on the floor between the seat rails, I've also transported my toolbox like that occasionally. |
the passenger side has hauled a couple engines over the years for me too.... _________________
[email protected] wrote: |
With a show of hands, who has built over 1000 engines in the last 25 years? Anyone? |
GEX has. Just sayin |
Bret Young Samba Member
Joined: August 26, 2006 Posts: 756 Location: Turlock, CA
Posted: Mon Mar 25, 2013 10:15 am Post subject: |
MikeGatch wrote: |
Oh yeah, did I mention I picked it up with my bug? |
Woo mid-engine! I know people love hearing the bark of Dellorto's, but right behind your head.....gonna sound awesome. :lol: |
Ian Samba Moderator
Posted: Mon Mar 25, 2013 10:19 am Post subject: |
MikeGatch wrote: |
SMART
Sounds, like you got a good deal. If it were me I would at least tear it down and put some new bearings in it. At least you will know what's in there.
Sell the progressive on craigslist for $75 and buy some bearings. _________________ All your Buses are belong to us.
Love and good roads!
IN LOVING MEMORY OF ROB CRESS 1968-2012
**ACHTUNG DO NOT USE AA BRAND PRODUCTS OR BUY ANYTHING FROM PACIFIC PARTS INTERNATIONAL IN CALIFORNIA** |
Arnolds64 Samba Member
Posted: Mon Mar 25, 2013 11:06 am Post subject: Webers. |
If you need to rebuild the Webers it is very easy. Weber Carbs Direct has a kit for 20.00 for each carb. Buy the Weber Book by Tomlinson. Run them and you will be happy.
Probably should pop the Oil Pump cover to see what Cam it has so you can then tune it to it. If you don't know who the people are can you really trust them? In fact I would pop a cylinder off to make sure it is what it is. Top of the piston should have the size of the piston. Should be able to see if the crank is Counter weighted and the case clearanced. Was sold a 1776 that was supposed to have C/W crank and it turnout to be stock and a 1641 to boot. The 2016 thing has got me wondering. As it is either a 2007 or 2017. 78 crank or a 78.4 which most are.
Do you have any Idea of the mileage? Really most folks don't hot rod a VW motor for a daily. Do a Compression Check and go from there. _________________ 64 Bug, White, 2017, Dual Weber 44's, Engle 130/Engle lifters, Home P&P'd 40X35 heads, CB 4340 nitrided crank, Eagle knock off H Beam 5.5" rods, Lowering Beam, Rancho Trans, Traction Bar. 225X60's rear, 145's front on Porsche Chrome Nipple Wheels. |
Posted: Mon Mar 25, 2013 4:25 pm Post subject: |
I just tossed it in my car since I am out of town all week for work to see if it would run. It seems to have ridiculous compression. It fired a few times and got hung up after a few minutes of cranking. My buddy showed up to pick me up for work this week and I had to walk away from it.
I have receipts but the are all from 89 and are mostly for machine work. Apparently MOFOCO did the shortblock.
Not sure what could have hung up the engine after cranking for awhile like that, but I put a wrench on it and it turned over. Didn't make a horrible sound when it happened, just a slightly peculiar one. I'll probably drop it and pull it apart. Hate to put the other engine back in since my oil is like liquid glitter in that one, but it still runs great. It just makes me nervous. _________________ Daily Driver: 73 STD Beetle.
Posted: Tue Apr 02, 2013 11:01 am Post subject: Updates? |
Got any updates. Curious to see what you find out. _________________ 64 Bug, White, 2017, Dual Weber 44's, Engle 130/Engle lifters, Home P&P'd 40X35 heads, CB 4340 nitrided crank, Eagle knock off H Beam 5.5" rods, Lowering Beam, Rancho Trans, Traction Bar. 225X60's rear, 145's front on Porsche Chrome Nipple Wheels. |
RailBoy Samba Member
Joined: March 10, 2008 Posts: 2904 Location: Virginia
Posted: Wed Apr 03, 2013 7:31 am Post subject: |
Thats a Great Photo, need that as an Avatar,lol.... RB _________________ [quote="smitty24"]"HELP, I ported my own heads and now have fire coming out my ass" .[/quote]
JasonBaker Samba Member
Joined: February 08, 2010 Posts: 1642 Location: Cleveland, TN
Posted: Wed Apr 03, 2013 8:05 am Post subject: Re: Updates? |
Arnolds64 wrote: |
Got any updates. Curious to see what you find out. |
X2 |
Dave T Samba Member
Posted: Sun Apr 07, 2013 6:14 pm Post subject: |
You bought that OOOHHHHHHHHHHHH good luck Dave T _________________ The best V W site on the planet! |
buck Samba Member
Posted: Sat Apr 20, 2013 9:55 am Post subject: |
I heard mofoco built quality motors. |
SBD Samba Member
Posted: Tue Sep 24, 2013 10:08 pm Post subject: |
Still kinda' wonderin' what you found out..... |
