markz2004 Samba Member
Joined: November 13, 2007 Posts: 944 Location: Portland, OR
Posted: Sat Mar 23, 2013 4:43 pm Post subject: transmission trouble in Bend Oregon |
Van loaded headed to bend for skiing. About 90 miles north of bend when the transmission started to sound like a rock tumbler. With 275k on it I was hoping to drive really gently until cell phone coverage came back. I got another 5 miles when it felt like someone hit the drivetrain with a sledgehammer. BIG BAM then nothing.... we coasted to the side. Engine is being held back by the transmission and wont turn ovrr. The van rolls freely. Towed it to German transaxle. Used 90 of my AAA 100 mile tow.
They are closed. But I'll call on Monday and let them know about the van in their parking lot.
Ant thoughts, speculation or advice on what yo install? _________________ 87 Westy, 250k GW 2.4 - 2.0 , 16" wheels |
madspaniard Samba Member
Posted: Sat Mar 23, 2013 4:55 pm Post subject: |
Sorry to hear that. Manual or auto? _________________ 1991 Westy auto w/ Peloquin TBD
"The only difference between me and a madman is that I'm not mad” - Salvador Dali |
randywebb Samba Member
Posted: Sat Mar 23, 2013 4:56 pm Post subject: |
those are expensive sounds
may have been prudent to stop immediately when the "rock tumbler" noise started _________________ 1986 2.1L Westy 2wd Auto Trans. |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10251 Location: N. Idaho
Posted: Sat Mar 23, 2013 4:57 pm Post subject: |
From your description, sounds like the trans might be a writeoff, but you are fortunate to be in the exact driveway I'd want to be.
Automatic or manual? The engine being held makes me think automatic. So it rolls freely with clutch in or out (assuming here its a manual)?
DougM _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
Posted: Sat Mar 23, 2013 5:09 pm Post subject: |
Manual. Clutch pedal made no difference. _________________ 87 Westy, 250k GW 2.4 - 2.0 , 16" wheels |
singler3360 Samba Member
Joined: February 25, 2009 Posts: 1191 Location: Corvallis, Oregon
Posted: Sat Mar 23, 2013 5:15 pm Post subject: |
Mark, I hope you get it fixed quickly early next week. We're driving over Monday to Sunriver. I hope to see you and your van on the road in person by then. Keep us posted. |
tschroeder0 Samba Member
Joined: April 14, 2008 Posts: 2096 Location: Boulder CO
Posted: Sat Mar 23, 2013 5:34 pm Post subject: |
Man, I envy you. When mine did the same thing I was up in the yukon, had to ship a tranny from german trans...at least you werent far from home, my trans from them has been flawless, youre in a good spot for that to happen. Youll be back on the road soon.
Good luck! |
Posted: Sat Mar 23, 2013 5:42 pm Post subject: |
TBD time ? Gear ratio changes ? Or damn we didn't budget for this, just get it working again so we can get on with our vacation ? |
GWTWTLW Samba Member
Joined: April 22, 2008 Posts: 2174 Location: Portland, OR
Posted: Sat Mar 23, 2013 8:21 pm Post subject: |
Bummer Mark! Sorry to hear that. I hope the skiing is good at least... _________________ 89 Syncro Westy - GW 2.5, now with a double knob job
@gwtwtlw |
Syncrozilla Samba Member
Joined: September 11, 2004 Posts: 772 Location: Santa Barbara
Posted: Sat Mar 23, 2013 9:47 pm Post subject: |
Have you looked under the van? Could be a loose cv that came off. Seen that before
Edit; never mind I did not fully read the original post. _________________ Please do not message me on TheSamba. Use my email, [email protected]
Posted: Sat Mar 23, 2013 11:10 pm Post subject: |
Well, that IS different. Even if the trans gears were welded together, pushing the clutch in would disengage the engine and allow it to start as normal.
So your problem will be simpler and in the bell housing, perhaps (vs destroyed trans gears). Perhaps, I say cause I haven't gotten my head fully round it. But what if the clutch or flywheel completely self destructed and jammed the engine to a stop and broke the main shaft coupling (cheap)? So then the engine (flywheel jammed) would not turn over, yet the wheels/axles/diff/ring gear would spin and let the van roll around. That would be cheaper and faster to fix, so I'll be fascinated to see how this plays out.
Or, the engine let go and the bang broke the main shaft coupling. Similar to above with starter unable to move the lunched engine, but the Van will roll with clutch in or out because the main shaft is no longer connected.
Posted: Sun Mar 24, 2013 8:31 am Post subject: |
Doug,
Interesting thoughts.
The clutch has 25k miles on it and although I've owned the van for 5 years I have nothing to tell me the transmission is nothing but original. For as long as I can remember I will get the occasional 2nd gear crunch when cold. This tells me the syncro is worn. 1st gear will do similar on a much less frequent basis then the 2nd gear crunch. The CV joints are all brand new with less than 1k miles on the. The CV joints are good German put in by a reputable Portland shop.
Prior to the big bang, it shifted freely and sounded rough in each gear. 4th being the worst. Wonder if debris caused a tooth to chip and then continued to chip the leading tooth.
I just hope I can get some money for the core. _________________ 87 Westy, 250k GW 2.4 - 2.0 , 16" wheels |
Posted: Sun Mar 24, 2013 10:02 am Post subject: |
No it won't be a chip and then more chips. Something substantially large came off something and stopped the whole mechanism with enough authority that it broke something major. The tip is that the engine/trans are locked together and that something is preventing one or the other from moving. If I were there, I'd get a wrench on the crank bolt and try rotating the engine backwards just out of curiousity. It stopped while rotating forward. I'd remove the starter if there is no little slit in the bell housing to see the flywheel edge or gear teeth to see if the flywheel is crooked, moving/not moving with the engine, etc. Reversing the torque may cause the jammed item to fall out of the way and then you could learn more with the wrench. But you're there and Daryl would probablyl prefer to touch it just as you brought it versus adding more variables by playing with it. Me, I'd play with it but that's cause I like to poke things with sticks and it's an irresistible life long pursuit....
DougM
PS - it's a 30mm bolt if I recall, but you need a spanner that's got an angled head at juuuuuuust the right angle to reach it if your original heat shields are in place. I never found a combination of sockets and ratchets that would reach it with those shields in place. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16505 Location: Brookeville, MD
