Kblack1101 Samba Member
Joined: August 05, 2020 Posts: 162 Location: Wisconsin
Posted: Mon Aug 21, 2023 10:53 am Post subject: Re: Which speakers do you have in your doors? |
Chilepines wrote: |
No photos of the bracket - thought about that after it was all back together.
Cut the corner off the outlet cover. The outlet cover is not flat - flattened that with a vise and pliers. Drilled through it to mount to the door, with a few washers to fill the recess/gap at the edge, then lined it up a drilled a pilot hole and used a self-tapping screw to mount the speaker.
Along with the photos from above, this concept is clear enough. Thank you! _________________ 1964 Beetle
1977 Westy - SOLD
1985 Westy weekender |
Chilepines Samba Member
Joined: October 11, 2022 Posts: 143 Location: New Hampshire
Posted: Sun Aug 20, 2023 2:11 pm Post subject: Re: Which speakers do you have in your doors? |
Kblack1101 wrote: |
Nice job. Do you have a photo or a drawing of the bracket you can share? |
_________________ White 89 Westy with 2004 Subaru EJ25 - Betty |
Posted: Sat Aug 19, 2023 9:54 pm Post subject: Re: Which speakers do you have in your doors? |
Chilepines wrote: |
I used that to attach a bracket that I cut from a stainless steel light switch plate. |
Nice job. Do you have a photo or a drawing of the bracket you can share? _________________ 1964 Beetle
1977 Westy - SOLD
Posted: Wed Aug 16, 2023 1:52 pm Post subject: Re: Which speakers do you have in your doors? |
Took a cue from GalaxyVortex and mounted Polk DB652 6.5 inch speakers in the existing speaker location. Used a slightly different approach and did not need to modify the door or speaker at all.
There is an existing hole to the rear of the speaker opening. I used that to attach a bracket that I cut from a stainless steel light switch plate.
The speakers sound awesome compared to the 4 inch that were there before! _________________ White 89 Westy with 2004 Subaru EJ25 - Betty |
lloydy Samba Member
Joined: September 15, 2010 Posts: 715 Location: cheam surrey
Posted: Fri Oct 22, 2021 1:54 am Post subject: Re: Which speakers do you have in your doors? |
Thanks, ill just check when i get the van back, im just too eager! as for sound deadening, i agree i already have some in there when i fitted some 5.25" focals in the top location.
as for the comment about wind noise, yes these vans can get noisy. i found the biggest change for me wasnt all the sound deadening, it was fitting a sub, really does cancel out a lot of external sound. Hence me now deciding its worth fitting better audio.
Its really interesting seeing the 6.5"s fit in those door pods, that looks a really good idea and something i may now invest in..
Vanlife Geek wrote: |
lloydy wrote: |
i have this exact set up ready to fit when my van is back from paint, do you have any pics of the 'minor modification' you had to make to get the 6.5" in? i was thinking of spacing the speaker out a little so it fitted
I wish I could remember what I cut out to make the bottom speaker fit, but it's been many years. I just remember to get it to fit, there was a small piece of the door innards that was preventing it to fit, so I cut it out. It didn't look like it would lessen the strength of the door, I reasoned at the time. I'm sure I was right. Since you already have the exact same speakers, you'll see the spot that needs trimming once you get the door panel off and start placing that speaker where it goes. As I recall, there was really only one place it would fit, with some trimming. I can't even remember what I used to trim the metal. Do'h... sorry I can't be of more help. I should have taken pictures as I installed them.
While the door panel is off, you might also consider putting some sound mat on the inside of the doors while the access is good. I definitely thought it was worth doing. |
_________________ 16" syncro multivan pop top AHU TDI
“Give a man a fire and he's warm for a day, but set fire to him and he's warm for the rest of his life.” |
erste Samba Member
Joined: March 29, 2013 Posts: 1110 Location: San Francisco
Posted: Thu Oct 21, 2021 9:16 pm Post subject: Re: Which speakers do you have in your doors? |
oldskewlsk8ter wrote: |
I’ve been running some cheap power bass components in some universal ABS speaker pods I installed on the ABS door panels. I like the staging but wanna upgrade to Focal soon.
Very nice solution.
I posted on the last page about fitting 6.5”s in the stock upper location. I’ve changed it around since then and modified the Rocky Mountain Westy door pockets to fit 6.5”s. No more speakers up at the stock location.
pbrown Samba Member
Joined: July 15, 2008 Posts: 443 Location: Seattle, WA
Snoww_ Samba Member
Joined: September 25, 2015 Posts: 73 Location: California
Posted: Thu Oct 21, 2021 5:03 pm Post subject: Re: Which speakers do you have in your doors? |
I've got a '91 Carat that came with Polk speakers stock and I wanted to stick with the brand but modernize.
I went with the DB522 when I replaced the door panel with and ABS version, the DB692 in the rear AC housing, and made a center console around the auto gear select for a DB1042 .
Amp and wiring are under the driver seat with the aux battery, sounds great! _________________ 1991 Tiico Vanagon Carat
1961 Baja Bug |
Vanlife Geek Samba Member
Posted: Thu Oct 21, 2021 4:36 pm Post subject: Re: Which speakers do you have in your doors? |
Red Ryder wrote: |
Obviously a lot of audiophiles here! Having a good sound system to enjoy nice tunes while camping may be desirable, but I find that road noise at 65 mph cancels out most of the advantages on the road. |
For me personally, I don't use the car stereo much while camping. The amp uses too much power and I prefer using earbuds with my phone, tablet, or laptop while camping. A powerful amp and quality speakers are great for overcoming the road noise, and I like to listen to it loud when driving on road trips. Mine still sounds great at 65 with the windows down. I know it's loud when I see the rear view mirror vibrating in sync with the subwoofer. Good tunes while driving make the miles fly by and I'm often surprised at how much time has passed when rocking out to some of my favorite albums... "Damn, I'm there already?!" _________________ Vanlife Geek
Current:
1986 Syncro Westy
Previous:
1983 Westy
1981 Westy
1972 Bug (Last year you could buy a new one for under $2,000)
1965/66 Bug (2 bugs from a junk yard combined to make 1 functional bug)
1959 Bug (Pre Gas Gauge Era) |
Red Ryder Samba Member
Joined: June 26, 2021 Posts: 952 Location: Northern California
Posted: Thu Oct 21, 2021 4:19 pm Post subject: Re: Which speakers do you have in your doors? |
Obviously a lot of audiophiles here! Having a good sound system to enjoy your favorite tunes while camping may be desirable, but I find that road noise at 65 mph cancels out most of the advantages on the Highway of life!
Also wondering how many negate the purpose of the original plastic moisture barrier after installing speakers in the doors… _________________ “Most everyone’s mad here. You may have noticed I am not quite all there myself.” — Cheshire Cat, Adventures of Alice in Wonderland
“Scarlett” — 1990 Vanagon Carat Wolfsburg Edition
Tornado Red |
Posted: Thu Oct 21, 2021 2:47 pm Post subject: Re: Which speakers do you have in your doors? |
lloydy wrote: |
While the door panel is off, you might also consider putting some sound mat on the inside of the doors while the access is good. I definitely thought it was worth doing. _________________ Vanlife Geek
Current:
1986 Syncro Westy
Previous:
1983 Westy
1981 Westy
oldskewlsk8ter Samba Member
Posted: Thu Oct 21, 2021 1:48 pm Post subject: Re: Which speakers do you have in your doors? |
_________________ 1986 Hightop w/EJ25 DOHC & 4EAT auto
1965 Kombi project |
lloydy Samba Member
Posted: Thu Oct 21, 2021 11:52 am Post subject: Re: Which speakers do you have in your doors? |
I installed the Focal Access 165 A3 6.5-Inch 3-Way Component Speaker Kit, https://amzn.to/3v3aKkw. This kit comes with 6.5" woofers, 4" midranges, and tweeters which I mounted at the corners of the dash. It also comes with a pair of crossovers which I mounted under each seat. The 6.5" speakers took a minor modification of the door metal to fit. I used acoustic foam speaker baffles behind all the speakers in the door. This is my third Westy and third speaker installation and this time I got it right. I'm blown away by the quality of the audio these speakers produce. I can't imagine what the higher end Focal's must sound like. The grills for the 4" speakers will "auto fit" the contours of the dash upon closing the door.Slim Speaker Baffles - 6.5": https://amzn.to/33WdRyG, 4": https://amzn.to/2QqUj2i |
jAndrew Samba Member
Joined: October 11, 2020 Posts: 306 Location: Atlanta, Georgia
Posted: Tue May 18, 2021 8:39 am Post subject: Re: Which speakers do you have in your doors? |
Like one of the previous posters I bought the cheap Rockford Fosgate R14x2.
I was pleased not to have to remove the door panel, the old pioneers came right out and the new ones went right in without any changes.
The sound, well, it's just okay. When I redo the door panels as it gets new paint i will upgrade to something better but for the price they are fine. _________________ '89 Syncro Doka |
Crankey Samba Member
Posted: Tue May 18, 2021 7:47 am Post subject: Re: Which speakers do you have in your doors? |
Mine are 2 way in the door. Not too exciting to look at, probably best that way.
@1971BugGuy, nice door panels ! |
Posted: Tue May 18, 2021 6:36 am Post subject: Re: Which speakers do you have in your doors? |
I installed the Focal Access 165 A3 6.5-Inch 3-Way Component Speaker Kit, https://amzn.to/3v3aKkw. This kit comes with 6.5" woofers, 4" midranges, and tweeters which I mounted at the corners of the dash. It also comes with a pair of crossovers which I mounted under each seat. The 6.5" speakers took a minor modification of the door metal to fit. I used acoustic foam speaker baffles behind all the speakers in the door. This is my third Westy and third speaker installation and this time I got it right. I'm blown away by the quality of the audio these speakers produce. I can't imagine what the higher end Focal's must sound like. The grills for the 4" speakers will "auto fit" the contours of the dash upon closing the door.Slim Speaker Baffles - 6.5": https://amzn.to/33WdRyG, 4": https://amzn.to/2QqUj2i _________________ Vanlife Geek
Current:
1986 Syncro Westy
Previous:
1983 Westy
1981 Westy
Posted: Mon May 17, 2021 7:26 pm Post subject: Re: Which speakers do you have in your doors? |
I have 6" Focal in MDF panels fitted in the stock location and an old alpine powered sub between the front seats. |
1971BugGuy Samba Member
Joined: October 16, 2004 Posts: 426 Location: Ontario, CANADA
Posted: Sun May 16, 2021 12:28 pm Post subject: Re: Which speakers do you have in your doors? |
Steve M. wrote: |
1971BugGuy wrote: |
I think they are a little more attractive.
Your interior is only just a little bit more attractive! |
Haha! Thank you. It's been a long and arduous task and it isn't yet complete. It's a "spare time" task and spare time, for me, is at a premium. _________________ Only a fool or a child would judge a project before it reaches its completion.
1971 Super Beetle
1986 Vanagon Westfalia Weekender |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Mon May 03, 2021 4:33 pm Post subject: Re: Which speakers do you have in your doors? |
1971BugGuy wrote: |
Your interior is only just a little bit more attractive! _________________ This free advice is worth exactly what you paid for it.
Posted: Mon May 03, 2021 3:11 pm Post subject: Re: Which speakers do you have in your doors? |
I am running Kicker DSC350 speakers in stock speaker grills. I cut out the factory speakers with my dremil and installed the Kickers with a bit of JB Weld putty. I am also running Ford Taurus window cranks which have at least twice the clearance of Vanagon cranks. I don't really need the clearance but I think they are a little more attractive.
1971 Super Beetle
