Which speakers do you have in your doors?
Yondermtn
Yondermtn is offline
PostPosted: Sat Aug 09, 2014 10:52 am    Post subject: Reply with quote
I was getting a crackling at higher volume from all four of my stock speakers.
I figured the speakers were old and/or not up to the power of the newer head unit. 50w x 4
I installed a pair of 4" Pioneers in my front doors and I still have the crackling. I discovered that the crackle is more pronounced and at a lower volume when I have the fader set either to front or back. If I have the fader set further to the front those speakers crackle and when I set them to the rear the rears crackle.
Anyone know how to diagnose this? I have another pair of Pioneers to install in the rear but would like to know what the problem is before I install them.
1977 Westfalia 2.0FI 4spd
1990 Multivan 2.1 Auto
narendra.vw
narendra.vw is offline
PostPosted: Sat Aug 09, 2014 7:48 pm    Post subject: Reply with quote
I have replaced OE speaker with Sony 5 1/2” Speaker.
Details.
OE speaker’s woofer & magnet coil removed.
¾” wood spacer , clamped in two places & screwed directly in the third.
Sony 5 ½” is screwed to the wood.
OE speaker cover in it’s original place
sam_
sam_ is offline
PostPosted: Tue Sep 01, 2015 8:59 pm    Post subject: Reply with quote
Hope this is a good thread to post this question. Would this be a potential location for a speaker (with a spacer most likely)? Thinking of putting a 5 1/2 there with a separate tweeter. Wondering if someone has a trim panel removed and can tell me how clearance there is to the window? Would the back of the speaker need to be protected from water?
Thanks
syncrodoka
syncrodoka is offline
PostPosted: Tue Sep 01, 2015 9:07 pm    Post subject: Reply with quote
The glass mounts maybe 1/4" deeper than the vertical metal bar just to the right of the circle which is the window regulator.
kamzcab86
kamzcab86 is offline
PostPosted: Mon May 02, 2016 12:37 pm    Post subject: Re: Which speakers do you have in your doors? Reply with quote
Bumping this back up to add my new front door speakers. The original Blaupunkts were shot; replaced them with Rockford-Fosgates:
Plug-n-play in my '90. They just barely clear the dash.
~Kamz Anxious
2016 Golf GTI S
jwallis
jwallis is offline
PostPosted: Mon May 02, 2016 1:27 pm    Post subject: Re: Which speakers do you have in your doors? Reply with quote
I have 4" polks specifically because they claimed to produce decent bass from a 4" speaker. Not impressed, guess I fell for it. I'm sure Bose could do it... for $200 each...
Anyway, put a Blaupunkt - GTb 8 A under the back seat and I can't say enough good about it.
TheVanTracker.com - Kill Switch + GPS Tracker + Door-open alerts, made specifically for the Vanagon!
50+ YouTube videos - brakes, bearings, CV joints, 1.9/2.1 cooling system, mods, Bostig and more...
ThankYouJerry
ThankYouJerry is offline
PostPosted: Mon May 02, 2016 6:40 pm    Post subject: Re: Which speakers do you have in your doors? Reply with quote
[pics]
Cool Which model # are those Rockford-Fosgates? How do they sound?
1990 Multivan - "Ohana"
1.8T, Auto w/3.27 R&P + Peloquin TBD
kamzcab86
PostPosted: Mon May 02, 2016 7:12 pm    Post subject: Re: Which speakers do you have in your doors? Reply with quote
ThankYouJerry wrote:
[pics]
Yeah, that'd probably be helpful, eh? Embarassed
Rockford-Fosgate Prime R14X2
I'm no audiophile; I just wanted speakers that would fit, look kind of OEM in the doors (went with Pioneers for the rear), and produce sound good enough to hear with the windows down on the highway. So, with that said, compared to the blown "tinny" originals, they sound great! Very Happy
~Kamz Anxious
2016 Golf GTI S
greebly
greebly is offline
PostPosted: Mon May 02, 2016 7:43 pm    Post subject: Re: Which speakers do you have in your doors? Reply with quote
5 1/4" woofers in kick panel. They are identical to the woofers in the front door lower panels. It is a poly cone MCM # 55-1205.
Custom 2 way crossover under rear seat connected directly to existing factory wiring connector.
With 4" coaxials in the overhead AC stock location
3 way crossovers in front.
Tweeters installed at corners of dash up front, these have stands and are amiable.
4" speaker used for stock upper door panel is a MCM # 54-730 which is a enclosed back 4" midrange.
4 inch in stock location as a midrange and 5 1/4" woofer in lower location.
Finally an 8" Boss subwoofer installed under the passenger front seat.
wesitarz
wesitarz is offline
PostPosted: Tue May 03, 2016 3:15 am    Post subject: Re: Which speakers do you have in your doors? Reply with quote
4 inch Clarions and 6 inch JBLs
oldskewlsk8ter
oldskewlsk8ter is offline
PostPosted: Tue May 03, 2016 4:35 am    Post subject: Re: Which speakers do you have in your doors? Reply with quote
5.25" powerbass components, universal speaker pods mounted to door panels, crossovers under the dash.
1986 Hightop w/EJ25 DOHC & 4EAT auto
1965 Kombi project
Italjohn
Italjohn is offline
PostPosted: Fri Nov 11, 2016 3:23 pm    Post subject: Re: Which speakers do you have in your doors? Reply with quote
Love this tread, can someone please keep posting pictures Very Happy
View user's profile Send private message Visit poster's website Facebook Instagram Classifieds Feedback
VanAllen_84
VanAllen_84 is offline
PostPosted: Fri Nov 11, 2016 4:01 pm    Post subject: Re: Which speakers do you have in your doors? Reply with quote
Well, until I feel more comfortable with significantly hacking/modifying my Van, I opted to find a some speakers (JBL GTO 329) that would fit the original housing so that I could keep the stock look.
https://www.instagram.com/p/BLuQbJYjWx0/
I did the same with the rear speakers. The speakers do lack a bit of bass, but they are obviously better than the stock speakers. Eventually, I'll add some 6x9s under the rear bench and possibly a sub in the closet like @denwood did back on the first page.
1984 VW Vanagon Westfalia 1.9L Water-cooled (aka "Osmo")
figborg
figborg is offline
PostPosted: Fri Nov 11, 2016 4:10 pm    Post subject: Re: Which speakers do you have in your doors? Reply with quote
Blaupunkt Blue Magic CL 100 4-Inch 155-Watt Coaxial Speaker System. Purchased last year, now discontinued, installed last week. I will be using the stock grills.
Working on them now since I can't get any sound out of them. Some wires are not connected in the back of the dash. PITA but won't give up.
http://www.blaupunkt.com/id/nc/products/car-multimedia/speaker/products/single/9076/
-- PF
Providence, RI
1986.5 Westy camper (G year code, grey interior), 2WD, manual transmission, Subaru conversion by Vanaru. Spoiled rotten.
http://www.thesamba.com/vw/forum/viewtopic.php?t=662374
RCB
RCB is offline
PostPosted: Fri Nov 11, 2016 4:11 pm    Post subject: Re: Which speakers do you have in your doors? Reply with quote
Replaced to old 4" speakers with some Boston Acoustics. Two in the door and two in the overhead rear cabinet. Ran new wire and separate ground. For my taste they sound fine. Not sure if BA still make them but worth a look see.
pbrown
pbrown is offline
PostPosted: Sun Mar 11, 2018 8:47 pm    Post subject: Re: Which speakers do you have in your doors? Reply with quote
MBQuart 5.25" flush install. These fit amazingly well. I found a NOS set on eBay. I haven't installed the tweeter yet. These can be converted to coax or separates. The window crank clears the grill without spacers.
Patrick Brown
1986 Westy Syncro EJ25
Flickr --> https://flic.kr/s/aHsmQNUXEF
Aryana
Aryana is offline
PostPosted: Mon Mar 12, 2018 8:06 am    Post subject: Re: Which speakers do you have in your doors? Reply with quote
JBL GTO 329
Perfect fit inside the stock grill housings after prying out the anemic stock speakers and gluing in the good ones. Totally stealth and they sound awesome.
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Mon Mar 12, 2018 8:20 am    Post subject: Re: Which speakers do you have in your doors? Reply with quote
I just got done installing those exact speakers into a '90 MV. They just fit the opening in the doors, but I had to file out the openings in the rear cabinet. I chose them specifically because of the grilles. They're pretty inexpensive as well.
Casey--
'01 Weekender --> full camper
y u rune klassik?
Steve M.
Steve M. is offline
PostPosted: Mon Mar 12, 2018 8:25 am    Post subject: Re: Which speakers do you have in your doors? Reply with quote
$20.00 wonders at Bestbuy.
The window handle will hit them.
GoWesty has the bent window handle to clear them
https://www.thesamba.com/vw/forum/viewtopic.php?t=695535
2dogs1van
2dogs1van is offline
PostPosted: Mon Mar 12, 2018 10:01 am    Post subject: Re: Which speakers do you have in your doors? Reply with quote
I just installed the $20 speakers SteveM recommends. They sound great! I finally have bass up front. But I left off the plastic ring with "Kenwood" on it and my window cranks don't hit the speaker. And the speakers look ok without that ring. Best $20 upgrade I've spent on the van.
Page 4 of 6
