mtnride1 Samba Member
Joined: March 30, 2011 Posts: 194 Location: la quinta, CA
Posted: Mon Mar 12, 2018 10:50 am Post subject: Re: Which speakers do you have in your doors? |
I have 2 6" kenwood speakers in each door. I removed the 4" ones in the back and took out my woofer and amp to. The pooch did not like the bass or the tunes when he is trying to relax in the back when I'm driving. I am still happy with this setup.
_________________ 87 westy 2wd (NED) |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Mon Mar 12, 2018 1:03 pm Post subject: Re: Which speakers do you have in your doors? |
mtnride1 wrote: |
Really I don't care about your speakers when I see that door panel!
That's great! _________________ This free advice is worth exactly what you paid for it.
visibleink Samba Member
Joined: May 03, 2002 Posts: 1668 Location: Austin, Texas
Posted: Sat Sep 22, 2018 11:18 am Post subject: Re: Which speakers do you have in your doors? |
Aryana wrote: |
JBL GTO 329
Perfect fit inside the stock grill housings after prying out the anemic stock speakers and gluing in the good ones. Totally stealth and they sound awesome.
I'm following your lead on this....but how did you get the stock speakers out?
I see other people cutting the plastic and glueing back together?
Heat gun? _________________ Been on the samba so long I remember petting that dog to see VWs, WYHI, and green bug girl.
<-- Helga, she slammed her dub in '53 and adjusted valves with her teeth |
Aryana Samba Member
Joined: November 09, 2015 Posts: 568 Location: Southern CA
Posted: Sat Sep 22, 2018 11:28 am Post subject: Re: Which speakers do you have in your doors? |
Flat blade screwdriver to break the surrounding support and then just pry it out. |
DeadSetMonkey Samba Member
Joined: April 15, 2010 Posts: 532 Location: Denver, CO
Posted: Mon Oct 01, 2018 7:38 am Post subject: Re: Which speakers do you have in your doors? |
Might be slightly off thread.
But, i need a quick nudge int he right direction.
I have a 1990 with power mirrors and power windows. Stock.
Someone give me a quick step by step on getting the door dissasembled so I can get a new set of speakers in? The Bentley is a bit sparse on direction here.
many thanks _________________ ----------------------------------------------------
'90 Syncro Westy 2.5Subi Turbo, BFGs 215/75/15 Rheins |
Posted: Mon Oct 01, 2018 7:48 am Post subject: Re: Which speakers do you have in your doors? |
DeadSetMonkey wrote: |
many thanks |
The speakers screw into the housing, if you are using the stock speaker grills you can just unscrew them.
Otherwise remove both door handles, door crank (pop off the plastic to expose the screw), lower vent. Then carefully pull on the door trim panel. It's just held in which clips. Be gentle and don't force anything. _________________ Been on the samba so long I remember petting that dog to see VWs, WYHI, and green bug girl.
Posted: Mon Oct 01, 2018 7:49 am Post subject: Re: Which speakers do you have in your doors? |
Aryana wrote: |
PS this worked perfectly. Glad I didn't have to cut the grills like others have. _________________ Been on the samba so long I remember petting that dog to see VWs, WYHI, and green bug girl.
Aryana Samba Member
Posted: Mon Oct 01, 2018 7:55 am Post subject: Re: Which speakers do you have in your doors? |
Right on, glad it saved you some time. |
GalaxyVortex Samba Member
Posted: Fri Jun 28, 2019 11:13 pm Post subject: Re: Which speakers do you have in your doors? |
I put 6 1/2" two way speakers in my front doors and they sound great! (Polk DB652.) They fit into the original openings wihtout any cutting sheet metal at all! I did have to cut the "ears" off the speakers for a better fit. I moved the window crank tube behind the sheet metal and mounted the speakers with two screws. I kept the original door cutouts so it still looks stock. I cut the fronts off of the old speaker grills and glued them back on the door panels. The speakers sound twice and good and even after losing about 25% of the surface area due to the smaller opening, I am still WAY ahead. I can hear music and understand speech on the radio when I am heading down the highway.
_________________ Hi-fi, Vintage stero & politics |
erste Samba Member
Joined: March 29, 2013 Posts: 1110 Location: San Francisco
Posted: Fri Feb 19, 2021 11:51 pm Post subject: Re: Which speakers do you have in your doors? |
I did something similar to the last poster a few years ago, but got some new 6.5” drivers and tweeters and have been looking at alternative mounting options (not behind the door panel) and came across this thread.
Pics of the current setup:
erste wrote: |
MB Quart 6.5" woofers with a notch cut in them so they can mount to the door. The only mod to the van was drilling the holes to mount them.
5.25”s in the rocky mountain westy door pockets. Tweeters on the dash with double sided tape.
This time around I’m probably going to see if the RMW door pockets can be modified for 6.5”s, or make a new panel to replace it. Tweeters will hopefully be more integrated, but still on the A pillars. Going to lose the 5.25s and try to run a proper 3 way active system instead of splitting the signal to the 6.5s and 5.25s like I’ve been doing.
The kick panels and lower door card mounting options in this thread gave me some ideas. thanks for that!
jimf909 Samba Member
Posted: Sat Feb 20, 2021 12:09 am Post subject: Re: Which speakers do you have in your doors? |
MB Quart 6.5" mid-range drivers in the door..l
Tweeters on the dash...
Crossovers under the passenger seat...
Amp under the driver's seat. Still needs more cowbell. _________________ - Jim
Abscate wrote: |
Abscate Samba Member
Posted: Sat Feb 20, 2021 4:21 am Post subject: Re: Which speakers do you have in your doors? |
Morrison’s are good, either Jim or Van. _________________ .ssS! |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
1971BugGuy Samba Member
Joined: October 16, 2004 Posts: 426 Location: Ontario, CANADA
Posted: Mon May 03, 2021 3:11 pm Post subject: Re: Which speakers do you have in your doors? |
I am running Kicker DSC350 speakers in stock speaker grills. I cut out the factory speakers with my dremil and installed the Kickers with a bit of JB Weld putty. I am also running Ford Taurus window cranks which have at least twice the clearance of Vanagon cranks. I don't really need the clearance but I think they are a little more attractive.
_________________ Only a fool or a child would judge a project before it reaches its completion.
1971 Super Beetle
1986 Vanagon Westfalia Weekender |
Posted: Mon May 03, 2021 4:33 pm Post subject: Re: Which speakers do you have in your doors? |
1971BugGuy wrote: |
Your interior is only just a little bit more attractive! _________________ This free advice is worth exactly what you paid for it.
Posted: Sun May 16, 2021 12:28 pm Post subject: Re: Which speakers do you have in your doors? |
Steve M. wrote: |
1971BugGuy wrote: |
Your interior is only just a little bit more attractive! |
Haha! Thank you. It's been a long and arduous task and it isn't yet complete. It's a "spare time" task and spare time, for me, is at a premium. _________________ Only a fool or a child would judge a project before it reaches its completion.
1971 Super Beetle
Crankey Samba Member
Posted: Mon May 17, 2021 7:26 pm Post subject: Re: Which speakers do you have in your doors? |
I have 6" Focal in MDF panels fitted in the stock location and an old alpine powered sub between the front seats. |
Vanlife Geek Samba Member
Posted: Tue May 18, 2021 6:36 am Post subject: Re: Which speakers do you have in your doors? |
I installed the Focal Access 165 A3 6.5-Inch 3-Way Component Speaker Kit, https://amzn.to/3v3aKkw. This kit comes with 6.5" woofers, 4" midranges, and tweeters which I mounted at the corners of the dash. It also comes with a pair of crossovers which I mounted under each seat. The 6.5" speakers took a minor modification of the door metal to fit. I used acoustic foam speaker baffles behind all the speakers in the door. This is my third Westy and third speaker installation and this time I got it right. I'm blown away by the quality of the audio these speakers produce. I can't imagine what the higher end Focal's must sound like. The grills for the 4" speakers will "auto fit" the contours of the dash upon closing the door.Slim Speaker Baffles - 6.5": https://amzn.to/33WdRyG, 4": https://amzn.to/2QqUj2i _________________ Vanlife Geek
Current:
1986 Syncro Westy
Previous:
1983 Westy
1981 Westy
1972 Bug (Last year you could buy a new one for under $2,000)
1965/66 Bug (2 bugs from a junk yard combined to make 1 functional bug)
1959 Bug (Pre Gas Gauge Era) |
Posted: Tue May 18, 2021 7:47 am Post subject: Re: Which speakers do you have in your doors? |
Mine are 2 way in the door. Not too exciting to look at, probably best that way.
@1971BugGuy, nice door panels ! |
jAndrew Samba Member
Joined: October 11, 2020 Posts: 306 Location: Atlanta, Georgia
Posted: Tue May 18, 2021 8:39 am Post subject: Re: Which speakers do you have in your doors? |
Like one of the previous posters I bought the cheap Rockford Fosgate R14x2.
I was pleased not to have to remove the door panel, the old pioneers came right out and the new ones went right in without any changes.
The sound, well, it's just okay. When I redo the door panels as it gets new paint i will upgrade to something better but for the price they are fine. _________________ '89 Syncro Doka |
