txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Wed Apr 03, 2013 7:10 pm Post subject: Wiring Help Again |
Car - 54 Oval
Problem: horn
I have re-wired the horn with a simple push button switch, which isn't working. It must be something simple, so hopefully someone can help.
Original power wire goes to terminal on horn, reading 6 volts
Other wire runs from 2nd horn terminal to push button, which has two terminals. I then installed a ground wire to the 2nd terminal on the push button. When you push the button, the grounding should be complete and the horn work...right? |
Jeremy1984 Samba Member
Joined: November 03, 2012 Posts: 129 Location: Etowah,TN
Posted: Wed Apr 03, 2013 7:16 pm Post subject: |
usually the horn button would send a ground signal to trigger a horn relay, then the relay would send out a hot signal to the horn, with the horn being grounded. did you test your horn with just a hot and ground to make sure it is good? _________________ Rebel Wire Representative
[email protected] |
txoval Samba Member
Posted: Wed Apr 03, 2013 8:03 pm Post subject: |
I have not, but it did work before I stripped the car down.
Should the power wire go thru the switch then? Not the ground? |
0nebadbug Samba Member
Joined: October 01, 2009 Posts: 1087 Location: Rockford, Illinois
Posted: Thu Apr 04, 2013 3:33 am Post subject: |
If I'm reading the wiring schematic, 1954, the switch looks hot, not the ground as the button should just be picking up ground from the steering tube when the button is installed.
If it's still dead check the steering coupler ground strap and the the ground pickup on the the tube as well. _________________ ::: Slowoval ::: LaDawri Sebring ::: '61 Creampuff ::: Dust Storm '66 ::: |
txoval Samba Member
Posted: Thu Apr 04, 2013 6:17 am Post subject: |
0nebadbug wrote: |
If it's still dead check the steering coupler ground strap and the the ground pickup on the the tube as well. |
Onebadbug:
I completely removed the original horn wiring...wanted something simple:)
I'm wondering if the original ground wire (which I used) is not complete, meaning torn in between the horn and the button I installed |
Center Pin Samba Member
Joined: August 07, 2012 Posts: 74 Location: Langley BC
Posted: Thu Apr 04, 2013 10:48 am Post subject: |
Horns that sit often get stuck, try wacking it with the back of a screw driver while someone holds the button... earplugs are a good idea during the procedure.
Also any chance this horn grounds via the body? (IE not the original) |
