msinabottle Samba Member
Posted: Fri Apr 05, 2013 10:10 pm Post subject: Winston Wehabilitated: Of Human Bondo-age... |
I went to visit a friend of mine in the hospital today... Actually, he'd been sent off to a specialist. This is Larry, the cooperative Frame Guy, hired by Les at Wheels of Time to see what could be done about that driver's side rear quarter damage:
He was working on Winston in his nice little shop and was very agreeable about letting me talk to him about where we stand right now in the repairs, and in taking these photographs.
When I called Les today, I told him that I had been working on the assumption that no news was good news, and that after somewhat... frenzied... communications in the past, I had been leaving him alone to do what he does in relative peace. When I said, 'No news IS good news, right?' Les responded, 'Not really.'
The news is MOSTLY good! There was much less rust than any of us thought there would be, the passenger's side is even partly in pre-primer, ecce:
The problem is here, right where the T-bone damage that the orginal bodycreatures had done with lots and lots and lots and lots of Bondo:
The Bondo is gone. It is all gone. Les does not like Bondo. He doesn't want to use Bondo. Maybe a little metal glaze, but... No Bondo. Not if it can be avoided. I hear Vanagon purists cheering for Les. Let's all cheer!
yaaaaaaaaaaaaaay!
You will soon be 'boo-ing' me.
The problem is, as Les explained over the phone, and in person when I went to see him in person after Larry explained it to me at his shop. is that Winston was hit... quite hard. He took it. He survived it! Part of that is because the hit came right on a supporting stanchion. And... that's the problem.
As you can see, they've already had to cut into him to push out where the earlier, sloppier repairmen slathered in the Bondo. They haven't had any luck pulling out that last near-inch or so where Winston's structural stanchion was pushed in by that long-ago, unknown impact. You can see a wide declivity right at the seam, and Larry and Les were getting rather grim on how to push that last bit out to flush.
Les suggested various options. Rather than the failed studs, which had worked... REALLY WELL... on so many dents I shall not regret never seeing again... They were considering welding a substantial plate onto the area and REALLY PULLING. Larry discussed dismantling Winston's interior with all my lighting nods...
And pushing from the inside OUT. I stood there for quite a while looking at the small declevity and said...
Quote: |
"Why don't we just weld a metal plate over that, crease it to duplicate the seam, and leave it at that?" |
BOOOOOOOOOOOOOOOOOOOO!
(I would have put the 'Boooooooooooo' in orange, but in Winston's current state, gray seemed more appropriate.)
See, I TOLD you you'd be booing me. I don't mind that. You could lighten up on the rocks, though...
Anyway--it would keep Winston from being further cut open. It would keep his a bit stripped, but still nice interior from further abuse. It would not be noticeable when done. It would not be Bondo. It would be sealed, and some kind of anti-corrosion material (I plugged zinc) used.
Wheels of Time was working on a vehicle with an even older pedigree than Winston's:
That's a Model A Ford, I'd have posted the pictures, but Everett has been known to get snippy if it doesn't have a VW on it somewhere. I teased the bodymen about not working on my van. I talked to Les. I talked to Scott, shop and project foreman. I drooled over a Chrysler Airflow. I'm still drooling. GAD, what a machine...
But that's where we are. Larry will drive Winston back over to Wheels of Time Monday, and they'll see how well they can smooth out that small portion of his Driver's Side rear quarter. Than it's more metal work, then it's body rubber, I suppose... then... PAINTING
I'd say we're close to half-way through this whole thing. Winston looks like fun, but is coming along and the news is mostly good.
Thought you'd all appreciate the update. And the pictures.
many ways, but never, never, never in silence."
luVWagn Samba Member
Joined: February 21, 2008 Posts: 1340 Location: Snoqualmie (WA)
Posted: Fri Apr 05, 2013 11:14 pm Post subject: Re: Winston Wehabilitated: Of Human Bondo-age... |
Ah, quality takes time, but Winston is going to go beyond a "full recovery" - more like the $6M dollar m(v)an at the end of this!
Did you change your seats, or is it just the lighting? I thought you'd done brown tweed Sew-Fine seats? _________________ '91 Syncro 16 Reimo Hightop Conversion, eTDI |
Summers420us Samba Member
Joined: June 14, 2010 Posts: 759 Location: Amissville, Virginia
Posted: Sat Apr 06, 2013 5:41 am Post subject: |
If'n you don't mind me asking... what was the quote? My 88 is in similar shape to the old Winston. |
JPrato Samba Member
Joined: December 15, 2006 Posts: 791 Location: Livonia, NY
Posted: Sat Apr 06, 2013 6:10 am Post subject: |
You really need a new quarter panel from classic VW to fix that right. Probably pretty pricy for the panel and a lot of work to take the old out and put the new in. Just a wild guess, $1,500 to $2,000 just to get and replace the quarter panel? So, a little bondo is OK in this instance. Not much else you can do........ _________________ Joe
87 Syncro Tin Top project
84 Westy, 2.5L Subaru power
06 Subaru 2.5 turbo in waiting
46 Cessna 140 |
nemobuscaptain Samba Member
Posted: Sat Apr 06, 2013 6:24 am Post subject: |
I don't know why you are hesitant to remove the interior. You will have to do it anyway when he welds or risk burning the thing.
Just remove the interior and do the job correctly. It's so much easier to work a panel when you have access to it from behind.
I'm not clear on what needs straightening from your description but taking the thing to a shop (or votech center??? sometimes free) with a frame straightener could probably pull that back out. They won't charge you much for pulling on it for 10-15 mins and your body guy can finish the job after it's straightened. (Even if it's not the frame that needs straightened, they can pull on almost any part you need moved.) _________________ Ohio Valley Tribe, Full Moon Bus Club https://www.facebook.com/groups/294422277314227/
https://www.facebook.com/groups/FullMoonBusClub
RIP Bob Hoover https://www.thesamba.com/vw/forum/viewtopic.php?t=427791
Hoover Sermons: https://www.vwsage.com/images/vwsage/Bob%20Hoovers%20Sermons.pdf
Last edited by nemobuscaptain on Sat Apr 06, 2013 7:58 am; edited 2 times in total |
Bntbrl Samba Member
Joined: September 04, 2012 Posts: 436 Location: Seattle, Wa
Posted: Sat Apr 06, 2013 7:26 am Post subject: |
Looks good. I wouldn't worry about a little filler. I'd try to minimize it if at all possible like your metal man did. _________________ 1984 Vanagon Westfalia 1.9 wbx
www.DIYSeattle.com |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6247 Location: Portland OR
Posted: Sat Apr 06, 2013 9:04 am Post subject: |
Why do we have three seperate threads following this restoration? Combine them into one so we have the whole story! _________________ 89 Westy 2.1 Auto |
Posted: Sat Apr 06, 2013 9:08 am Post subject: |
PDXWesty wrote: |
Why do we have three seperate threads following this restoration? Combine them into one so we have the whole story! |
One thread wouldn't give the opportunity for clever tag-lines _________________ '91 Syncro 16 Reimo Hightop Conversion, eTDI |
Posted: Sat Apr 06, 2013 11:43 am Post subject: Thread Proliferation? |
I ask the Administrators--would it be better to have one HUGE thread, or the ongoing episodic ones? My thoughts were that it was better to have shorter threads that one could get to the end of quickly, rather than those long monster threads that take a long time to get to the 'new news' about a single project I'll cheerfully follow Administrators' thoughts.
The clever tag lines are to amuse and interest you. I enjoy them, and sharing my photos and stories with you, in repayment to those past and current posters who wrote stories and shared experiences that amused and interested me.
I prefer to minimize, if possible, cutting and welding in of new body panels. They are VERY hard to get right. I don't do all this reading on the Samba for nothing. If, say, Ben were close at hand, we might well do it his way, whatever that was, because of Ben's deep acquaintance with all things Vanagon.
Instead, we are doing it Les's way because of Les's deep acquaintance with vehicle repair and restoration. The man's rebuilt my Dart, a Cord, and a Chrysler Airflow among other automotive poetry. I pay him for his expertise, and find his judgement trustworthy, and his concerns honest.
Much welding has already been done on Winston without carbonization. Winston's interior has been heavily modified, for details, see the bulk of my approximately 3,000 posts. Removing it all and re-installing it all would not be straightforward, even for me. He's been heavily checked for rust, inside and out. Shop fees are $80 an hour. I prefer to leave his interior and aging interior fittings as unmolested as possible when, so far, there hasn't been a lot of need to remove things.
Larry's IS the frame pulling shop. Much pulling has been pulled. Winston is true in his lower frame. It's the site of the impact that has the declivity. The declivity is in such a place and in such a position that I'm thinking a bit of introduced metal, as opposed to filler, will cover it.
When all this is said and done, I shall post pretty much a FULL price breakdown. I've been saving receipts as I spend... and spend... and spend. Les's orginal estimate for his work was around $7K. It will be more. From the Bead Blasting and the new Body Rubber, I've got close to another $2K in it.
He's worth it to me. We're at the 'Have faith' stage.
?Waldo? Samba Member
Posted: Sat Apr 06, 2013 12:03 pm Post subject: |
I prefer one thread. It is much easier to review the last episode and equally easy to click to the last page. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76941 Location: Sneaking up behind you
Posted: Sat Apr 06, 2013 12:39 pm Post subject: |
Please use your existing topic: http://www.thesamba.com/vw/forum/viewtopic.php?t=547860
msinabottle wrote: |
I ask the Administrators--would it be better to have one HUGE thread, or the ongoing episodic ones? My thoughts were that it was better to have shorter threads that one could get to the end of quickly, rather than those long monster threads that take a long time to get to the 'new news' about a single project I'll cheerfully follow Administrators' thoughts. |
Which "administrators"?
In all the other forums people are asked to keep it in one topic so members can follow along the progress from beginning to end. _________________ Glenn
Member #1009
#BlueSquare |
