llamas1 Samba Member
Joined: July 27, 2003 Posts: 237 Location: Houston, TX
Posted: Mon Aug 11, 2003 5:20 am Post subject: Engine heater? |
I was changing the oil in my new bus for the first time this weekend. As I got underneath I saw this strange contraption. At first I thought it was some kind of thermostat because there were two wires coming from it. After I removed and cleaned it I found that it was labeled an engine heater. Not only that I traced the wires back up into the engine compartment where the other end was a 120v plug that was tucked away behind the battery. Anybody ever use this engine heater?
I live in Houston so I left it off after my oil change.
Chillkoot Samba Member
Joined: May 09, 2002 Posts: 556 Location: Big Lake AK
Posted: Mon Aug 11, 2003 6:07 am Post subject: |
I have used ones like it in alaska.. not for my A/C stuff.. that is a pretty common oil drain heater.. Hell you live in an apartment in alaska in all the carport they have plugs.. It is a lot better to plug your car in, thinner oil at start up compared to oil that is often below 0 _________________ While we all hate POH ... Don't be Apathitic to CURRENT owner hacks.
Fiberglass is for boats... Rustoleum is for your lawn mower! |
AlaskaWesty Samba Member
Joined: August 10, 2003 Posts: 81 Location: The End of the Road
Posted: Mon Aug 11, 2003 10:08 am Post subject: |
Boy I tell you, I lived in Houston (Spring) for 12 years before moving to Alaska and never once gave thought to an engine block heater there. Heck, I did not know they made 'em for the buses. Cool. Now at -20 I can see it but the coldest Houston ever got was in the 20's for like a day. Makes you wonder where that old bus has been!
If you are going to just chuck it let me know!
Paul
[email protected] _________________ '78 CEII Westy - RIP |
jeremysmithatshawdotca Samba Member
Joined: February 11, 2002 Posts: 2530 Location: Edmonton, AB
Posted: Mon Aug 11, 2003 12:55 pm Post subject: |
Isn't the element supposed to be inside in the sump? A lot of cars just won't start in the winter here if they're not plugged in, not enough juice to try and move the thick oil around in the morning. Not my vw though, started right up at -35 without being plugged in in Feb. this year! Jeremy |
bljones Resident Wit
Joined: February 08, 2002 Posts: 2377 Location: ontario canada
Posted: Mon Aug 11, 2003 1:50 pm Post subject: |
old school block heaters are a fairly common item in this area. On water cooled cars, the element is inside the block, but all of the air cooled models i have seen mount the same way, to the drain plate, and the heat conducts through the case. _________________ OG JHC
Author of Original Rant #1
"It stingd itself to dead... now that is control on you"
2% |
chabanais Samba Member
Posted: Mon Aug 11, 2003 4:01 pm Post subject: |
Zee Germans did not hov this teknology in Stalingrad... _________________ "I spud therefore I yam." |
chillz1 Samba Member
Joined: August 03, 2002 Posts: 869 Location: Where You Least Expect
Posted: Mon Aug 11, 2003 8:28 pm Post subject: |
I had one on a fastback parts car I purchased. I tried it during some winter mornings (if you can call it winter here in New Mexico) and it seemed to work very well. Any engine will benefit from warm oil upon startup, especially in a colder climate. |
