agh19 Samba Member
Joined: June 22, 2010 Posts: 34 Location: Wake County, NC
Posted: Sat Apr 06, 2013 1:47 pm Post subject: Driver's door sort of locked, can't open |
The driver's door to my 67 is kind of locked and won't open either from inside or out. Can't lift the inside lock button, the outside pushbutton goes in all the way without resistance and the inside handle moves though about 40% of its travel and then hits a hard stop. I've searched the forum and the closest thread I've found for my situation is http://www.thesamba.com/vw/forum/viewtopic.php?t=455003 but I'm unable to trip the mechanism from inside the door (I have the door panel off). It's like the lock mechanism is stuck halfway. I've had the door latch out in the last year to fix the broken pin issue so the whole thing is pretty darn clean and it was working well until today. I could lock/unlock the door with the key and with the inside button. The interior button won't move at all now. I can turn the key in the outside lock but nothing's happening.
BTW, I blame my dog for doing something to the interior lock button while he was climbing from the back seat to the front while I was in the sandwich shop picking up lunch. He prefers to wait in the driver's seat.
Any help or suggestions will be gratefully accepted. |
lawn ninja Samba Member
Joined: January 02, 2006 Posts: 1009 Location: Round Rock, TX
Posted: Sat Apr 06, 2013 1:49 pm Post subject: |
Punch the dog repeatedly until he tells you what he did or if he knows who did it. Worked with insurgents. _________________ Jason
My 64 1500 S Notchback project here
My 58 sedan project here
My 63 Ghia here |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Sat Apr 06, 2013 4:42 pm Post subject: |
When was the last time you sprayed PB blaster in that lock mechanism?
When was the last time your dog had a good beat down? _________________
EverettB wrote: |
FU#5 |
diamondc00 Samba Member
Posted: Sat Apr 06, 2013 9:00 pm Post subject: |
This happened a couple weeks ago in my 67. I ended up pulling the front seats out, then pulling drivers door panel(while door was still closed) and pushed up on the lock from inside the door frame. Made sure it was all cleaned and lubed so this wouldn't happen to me again. It is fixable! |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Posted: Sun Apr 07, 2013 10:44 am Post subject: |
If it's not the actual exterior handle itself (or its components).....
Sounds like the same thing that happened to my former '67 Squareback. I needed to replace the lock mechanism. Not reproduced, but there are plenty available in the classifieds
_________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
Todd66 Samba Member
Posted: Sun Apr 07, 2013 2:48 pm Post subject: |
I believe you can get the newer ones and adapt them to the 67 easily. The one pictured is a 65-66. |
hitest Samba Member
Posted: Sun Apr 07, 2013 2:57 pm Post subject: |
...but even a replacement unit requires lube. _________________
EverettB wrote: |
FU#5 |
hsosa1 Samba Member
Joined: January 17, 2005 Posts: 1897 Location: Fontana
Posted: Wed May 03, 2017 11:27 pm Post subject: |
RareAir wrote: |
my issue is door won't open. The pin won't push in and, release
The lock. I been having issues with the mech I tried pushing it from the inside removed the door panel but it won't move . The pin. Somehow it's stuck. Any ideas _________________ Just Cruzin Sur Califas VW Car Club est♤1998 |
