mariusstrom Samba Member
Posted: Sat Apr 06, 2013 9:45 pm Post subject: Oil Leak at Fuel Pump |
Howdy - While adjusting the carb today on Felix, my '67 Beetle, I noticed a smidge of oil coming up from the bolts around the fuel pump on my stock 1500sp.
Anyone have any ideas why it would leak through the bolt points? The bolts are appropriately tightened.. _________________ Marius Strom Otto: 1988 Vanagon Syncro Westy Camper
[SOLD] Felix: 1967 Deluxe Beetle |
mkmaxit Samba Member
Joined: June 02, 2007 Posts: 626 Location: Clear Spring Maryland
Posted: Sat Apr 06, 2013 11:07 pm Post subject: |
Sometimes its just a matter of replacing gaskets.
Sometimes when you take off the nuts and pump
you will find the studs are actually loose, not tight themselves.
You can clean threads best you can with rag and use
a thread sealant. Like locktite but there is a tube that
is designed to seal threads. Just make sure enough thread
for nuts if studs go in deeper. Looking at photo studs can
go in a few threads deeper to tighten them if loose. One
and half threads past nut is what is required.
Use new gaskets and only put a little sealant on gasket
that is on bottom against block. None on top gasket its
not needed.
HOpe that helps. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
Posted: Sun Apr 07, 2013 10:30 am Post subject: |
Thanks, Everett. Standard washers or wavy washers there for a '67? I'll get them ordered up and put in place too.
EverettB wrote: |
This is sort of a different topic but it looks like you don't have a washer under that nut either.
I don't know if that will affect the sealing but there should be a washer there. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31380 Location: Hot Arizona
Posted: Sun Apr 07, 2013 10:51 am Post subject: |
Lockwasher/wavy washers.
Don't overtighten, you break that plastic flange (which might break anyway when you try to remove it). Just saying to warn: you could make a little problem into a bigger one here if the plastic flange breaks when you try to remove it. Maybe someone here knows if there's better or worse chance of breakage there if flange removal is tried with the engine hot.
Anyway: remove the pushrod before removing the plastic flange, and note which way it is pointing.
Has anyone ever tried the nuts with rubber seals for an oil seepage issue like this? _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Dangermouse Samba Member
Joined: November 23, 2005 Posts: 1266 Location: Beautiful New Zealand
Posted: Sun Apr 07, 2013 4:26 pm Post subject: |
You could try using Dowty washers here (available from hydraulics places). I've used them with success where studs may be weepy...
_________________ Do not follow me, for I may not lead. Do not lead me, for I may not follow. Do not walk beside me either; actually just bugger off and stand over there will you. |
