srfndoc Samba Member
Posted: Wed Apr 10, 2013 5:59 pm Post subject: Mystery motor with no case stamping |
Is there somewhere else I should look for any type of stamping on this case as so far I have found nothing:
Maybe something here?
Bus is a 67 SO-42 with an unidentified single port motor which I don't know the history of (other than it runs pretty well).
Thanks. _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
Harleyelf Samba Member
Joined: April 23, 2009 Posts: 1572 Location: Appleton, WI
Posted: Wed Apr 10, 2013 6:05 pm Post subject: |
Look for the words "Hencho en Mexico" - I had single port motor a few years back with no trace of a serial number. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Wed Apr 10, 2013 6:15 pm Post subject: |
Type 3 case?? Check if the dip stick tube is an added bolt on adapter.
Back in the day you could buy an engine case without any ID number from any VW dealer so it could be stamped with your old engine number. _________________ In Stereo, Where Available! |
Posted: Wed Apr 10, 2013 6:55 pm Post subject: |
No words that I can see and the dip stick looks normal:
Posted: Wed Apr 10, 2013 6:57 pm Post subject: |
That plate in the image bolted to the case is for type 3. You have a universal replacement engine case. _________________ In Stereo, Where Available! |
Posted: Wed Apr 10, 2013 7:04 pm Post subject: |
Good/Bad? Would it be equivalent to what the original case would be (H case)? or something later, maybe dual relief? I'm going to have it gone thru but would like to re-use the case if it specs out. _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
Posted: Wed Apr 10, 2013 7:20 pm Post subject: |
srfndoc wrote: |
Good/Bad? Would it be equivalent to what the original case would be (H case)? or something later, maybe dual relief? I'm going to have it gone thru but would like to re-use the case if it specs out. |
Depends on what your purpose is with the engine. Drag race?? Take it easy daily driver? Trying to get land speed record on the salt flats??
Slide underneath and count if you have single relief plug or dual?
Next time you have the fan shroud off look to see if the engine number is stamped on the case seam under it. _________________ In Stereo, Where Available! |
Ian Samba Moderator
Posted: Wed Apr 10, 2013 7:26 pm Post subject: |
looks like a crappy aluminum case. i would sell it or scrap it. _________________ All your Buses are belong to us.
Love and good roads!
IN LOVING MEMORY OF ROB CRESS 1968-2012
**ACHTUNG DO NOT USE AA BRAND PRODUCTS OR BUY ANYTHING FROM PACIFIC PARTS INTERNATIONAL IN CALIFORNIA** |
Posted: Wed Apr 10, 2013 7:38 pm Post subject: |
I'm too old to set any land speed records, just a weekend cruiser. Definitely dual relief so that's cool. _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
Posted: Wed Apr 10, 2013 7:46 pm Post subject: |
srfndoc wrote: |
I'm too old to set any land speed records, just a weekend cruiser. Definitely dual relief so that's cool. |
Then good and good then! For really good engine cooling for the bus is to add the DH shroud cooling, using 35 mm wide (inside measurement) cooling fan and modifying the shroud for installing 40% bigger type 4 cooler. _________________ In Stereo, Where Available! |
