syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12008 Location: Santa Cruz, CA
Posted: Wed Apr 10, 2013 11:25 pm Post subject: |
Since they are custom parts not adapted from an existing vehicle all replacement parts have to come from GW? rotors, pads and calipers? They don't even list replacement parts.
What do you do when you need a replacement part in BFE?
Easily attained replacement parts down the road is something that I always consider when doing upgrades- especially something vital to driving. |
Mundopacheco Samba Member
Joined: November 14, 2006 Posts: 439 Location: Durango, Colorado
Posted: Thu Apr 11, 2013 3:06 am Post subject: |
Smallcar's Big Brake Kit is 280mm with dual piston calipers for 599.00. It seems worth the extra 100.00, although they're out of stock.
How thick are the Smallcar rotors?
How fat would the GW rotors have to be to offset the benefit of dual piston calipers?
As far as the issue of GW new Big Brake Kit replacement parts availability, I'm sure we will hear something soon enough. Not here, of course, but something will appear on their site.
Miguel |
BillM Samba Member
Joined: June 18, 2004 Posts: 1381 Location: Stonington,CT
Posted: Thu Apr 11, 2013 4:25 am Post subject: |
The caliper bracket looks pretty thin in two spots. I know its a cast
part it just don't look that strong.
I also just don't believe that the pads and rotor are custom. Why would
the disk have all those other holes that slide over the studs?
If it wasn't made for multiple applications.
I also wonder if GoWesty is using SA hubs for 2wd or did
they have them copied (which is actually good news if
they will sell them seperatley).
I applaud GoWesty effort but they are not for me.. _________________ Bill M
87 Westy |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Thu Apr 11, 2013 10:23 am Post subject: |
The Van Cafe Audi kit may only be single piston but if its enough to haul down an Audi A4 on the autobahn...
The fact that I can run Zimmerman Sport rotors and Porterfield (or other) high quality pads makes the Van Cafe Kit a no-brainer, really. _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
outwesty Samba Member
Joined: June 06, 2006 Posts: 1074 Location: Tahoe City
carterzest Samba Member
Joined: January 22, 2008 Posts: 3842 Location: Eagle, ID/Sun Valley, ID
Posted: Thu Apr 11, 2013 11:02 am Post subject: |
Mundopacheco wrote: |
Miguel |
I am really happy with my SmallCar Big Brakes, though, I cannot answer your question on the thickness. BUT, I can offer you pictures of the boxes and pieces so perhaps someone more knowledgable can comment
Quote: |
SmallCar packed the brakes very, very well and they arrived in perfect shape. WOW o~ Monsters. I am very impressed!
_________________ Happiness=Portland, Oregon in the rearview mirror! |
danfromsyr Samba Member
Posted: Thu Apr 11, 2013 12:02 pm Post subject: |
and BAM, someone more knowledgable has spoken _________________ Happiness=Portland, Oregon in the rearview mirror! |
hans j Samba Member
Joined: May 06, 2006 Posts: 2715 Location: Salt Lake City UT
Posted: Thu Apr 11, 2013 12:48 pm Post subject: |
Even the larger A6 avant uses the 288x25 rotors. That's why I chose them when building mine, plus parts available all over the world!
And speaking of expensive brakes, all of the kits mentioned are way way WAYYYY cheaper than the Brembo with floating hat kit I have on my Audi... Building that car makes building a syncro westy affordable! _________________ 1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181 |
Phishman068 Samba Member
Joined: February 19, 2007 Posts: 1868 Location: Pittsburgh PA (ish)
rockfish Samba Member
Joined: February 13, 2007 Posts: 740 Location: Palo Alto, Calif.
Posted: Thu Apr 11, 2013 2:31 pm Post subject: Re: Hold The Phone - New Big Brakes! |
Syncronoid wrote: |
Audi Big Brake kit at VC is $695. Most vans, unless modified, have drum brakes on the rear. I've upgraded mine to larger, thicker drums. |
Definite advantage going w/ the VC (Audi) big brake kit in terms of procuring readily available replacement parts when required. _________________ 89 Westy
GW 2.5 5-speed trans
"It's what you learn after you know it all that counts."
- John Wooden |
Steve Arndt Samba Member
Joined: August 01, 2005 Posts: 1780 Location: Boise, Idaho
Posted: Thu Apr 11, 2013 4:02 pm Post subject: |
For a Syncro:
So the basics for a self sourced kit would be A4 Audi rotors, and G60 Corado Girling calipers? Any other things to know? Do those calipers bolt on directly or require spacing or adapters?
Steve |
Syncronoid Samba Member
Joined: January 21, 2012 Posts: 1111 Location: Stanford, CA and Bend, OR
Posted: Thu Apr 11, 2013 4:06 pm Post subject: Re: Hold The Phone - New Big Brakes! |
rockfish wrote: |
Syncronoid wrote: |
Definite advantage going w/ the VC (Audi) big brake kit in terms of procuring readily available replacement parts when required. |
Exactly why I went with the VC kit. _________________ '90 Syncro Westy w/GW2.5L |
D Clymer Samba Member
Joined: December 22, 2005 Posts: 2978 Location: Issaquah, WA
Posted: Thu Apr 11, 2013 4:20 pm Post subject: |
In fairness to GoWesty, it's important to keep in mind that none of the other vendors selling front vented brake upgrades disclose in their ads what the original source of their calipers are. In all cases, that is something that has subsequently been figured out by sharp and resourceful Vanagon owners.
For instance, the original South African brake upgrade had mystery ATE calipers until someone realized that the replacement pads were the same as a Merkur Scorpio and the calipers were also very similar with the exception of the carrier.
The Smallcar ad for years didn't say anything about where the calipers were from, but Vanagon owners who are familiar with Audi 5000 Turbos, 200s, and Audi V8s recognize them as the dual piston G60 calipers that were marginal on these cars from 1986 to 1993.
The Eurospec Sport kit that Van Cafe sells says they are Audi based, but does not go into detail about which Audi they are from. But once again, those of us who have owned A4s and A6s recognize them.
In spite of that, these have all been valid brake upgrades that many people have gotten reliable use out of. I think the GoWesty kit will be the same way. Once it becomes known what brake pad part number these use it won't be hard to figure out which vehicles share the calipers. I like the fact that the GoWesty kit uses caliper carriers that were made for the Vanagon bolt spacing and the unusually large mounting bolt size. To me this is a better solution than carriers that had the mounting holes offset bored and then opened up to a size that the original forging may or may not have been engineered for.
Also, the rotors included in the GoWesty kit are not necessarily universal fit just because of the extra lug bolt holes. The factory original rotors on my mom's Audi A6 4.2 and my old Audi S4 also have this double drilled pattern and those are actual Audi parts.
I like what I see with the new GW brake kit. It looks like a good value to me, and I'm not worried about getting stranded far from home with shot brake pads and shot calipers and shot rotors. Maybe I'm wrong and they will all end up being one off parts that only GoWesty sells, but I doubt it. I think only the caliper carriers will end up being unique.
David |
photogdave Samba Member
Joined: April 05, 2004 Posts: 3053 Location: Vancouver Island, B.C.
Posted: Thu Apr 11, 2013 7:58 pm Post subject: |
D Clymer wrote: |
....... the dual piston G60 calipers that were marginal on these cars from 1986 to 1993. |
If these calipers were marginal on the vehicles mentioned, wouldn't it be more so on a Vanagon?
Thanks,
Miguel |
madspaniard Samba Member
Posted: Thu Apr 11, 2013 8:52 pm Post subject: |
photogdave wrote: |
VWhead wrote: |
Will the rotors change ET difference on a Syncro? I'm curious how thick the rotor is where it mates to the hub. It would be nice if it didn't effect stock ET. |
What is ET?
No alien jokes please. |
Well, you must be from another planet if you don't know what ET is
ET=Wheel Offset
ET from German word Einpresstiefe _________________ 1991 Westy auto w/ Peloquin TBD
"The only difference between me and a madman is that I'm not mad” - Salvador Dali |
Posted: Thu Apr 11, 2013 9:03 pm Post subject: |
D Clymer wrote: |
I like what I see with the new GW brake kit. It looks like a good value to me, and I'm not worried about getting stranded far from home with shot brake pads and shot calipers and shot rotors. |
Any of those items would make driving dangerous or impossible, a combination of all bad items is not needed
D Clymer wrote: |
Quote: |
This GoWesty kit does not rely on any parts from another production vehicle—this is not an "adaptation" of any other brake system. We went straight to the manufacturer for these components and had them made specifically for the Vanagon: |
According to them it is all custom. I have a sneaking suspicion that you are right about them coming from some existing car but their ad specifically says not. |
insyncro Banned
Posted: Fri Apr 12, 2013 7:51 am Post subject: |
I appreciate the thickness of the rotor, plus venting.
Let me know if they will work with Ronal R9 15" ET23 rims on a Syncro? |
