ernie norley Samba Member
Joined: September 27, 2009 Posts: 170 Location: nambour australia
Posted: Mon Jul 14, 2014 10:35 pm Post subject: |
old beam out spread beam in just has to have the tubes rotated in the end plates to set the height. Also set up left rear spacer lift plate to get ride height set
ernie
plenty of room for tyres
Posted: Fri Jul 25, 2014 12:59 am Post subject: |
G'day all. how are you in the states & beyond. spent some time this week on front beam still have to centre the bottom tube & finish off the spindles but this will give an idea of where it's heading
1st is sitting at standard height against milk crate
after the spread beam & rodeo spindles are fitted up
the cause of the severe camber the bottom tube has to move across to centre
Once I have it lined up I can start to make the front differential mounting cage |
Brian Samba Moderator
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Fri Jul 25, 2014 7:31 am Post subject: |
YOU got those front brakes off that missing airliner didnyou _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
Posted: Fri Jul 25, 2014 11:32 pm Post subject: |
G'day all. sorry Brian only speak Australian mate but thanks for what you said in Spanish it must good. Hi williamM no to far away to get stuff the front spindles are Holden rodeo looking at updating callipers to 4 pot Hilux or similar. wait and see how these stop It
ernie |
Posted: Fri Jul 25, 2014 11:38 pm Post subject: |
I said I like it. its going to be very fun when its done, cheers mate. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Posted: Sat Jul 26, 2014 3:04 am Post subject: |
Thanks for that Brian. WilliamM a mate has just travelled thru Arizona he bought me back t shirt with split bus on it from Sedona Arizona he said it was a nice place. I have never been to the states he goes every year. Wants me to go over with him next year. Wait & see how things go on the money front being a VET I don't have a lot of cash to splash. All the best to you all
ernie |
Posted: Sat Jul 26, 2014 5:27 am Post subject: |
Sedona is full of great red rock cut like central Auzzi- but they can find you here if you fu-
Make sure you visit Quartzsite in the winter.- (summer down under) as we have a big rock/junk show going on. Lots of your countryman flogging Opals and scrap rock from the iron ore from round the NWT.
Give us a call can show you the sights and Pizza n beer. _________________ some days I get up and just sit and think. Some days I just sit.
jmmj Samba Member
Joined: December 13, 2005 Posts: 246 Location: Brasil / New Zealand
Posted: Fri Sep 05, 2014 10:41 am Post subject: |
Gidday Ernie,
Solid work bro, i'm enjoying it! Keep the updates rolling...
For those wondering Holden = rebranded Chevrolet for Australia/ New Zealand.
Cheers,
mike |
Posted: Thu Sep 11, 2014 2:43 am Post subject: |
G'day all. Thanks to all out there following my build hope your enjoying ECLECTIC slowly coming together. Due to lack of space I have to build custom headers so this is a couple of hours work still to fit collectors. This is the left side. due to pulse of firing order it's the harder side to make.
ernie
Posted: Thu Sep 18, 2014 2:50 am Post subject: window winders converted to BMW series 3 motors |
Gday all. window winders converted to BMW series 3 motors now to put it back together. got the idea off the thread on the forum good helpful information
ernie
Posted: Sun Sep 28, 2014 5:06 am Post subject: |
G'day all spent some time sorting out the speedo drive I have to put the Toyota electronic drive into the Nissan transfer case. to do this I need to machine down the Nissan shaft to fit in the Toyota housing then machine the Nssan housing to create a sleeve to allow the Toyota drive to fit into case. this will give me the VSS for the motor and hi ace speedo
ernie
Posted: Tue Sep 30, 2014 2:44 pm Post subject: |
G'day all. Solved another mechanical issue. The McLeod concentric bearing uses a flat contact area on p/plate the Daihatsu. so I had some time searching parts book for a replacement everything I looked at had to have a sleeve made to mount to the unit. so given the cost I decided to have a sleeve made to go over the original unit here's what I come up with
this is the original unit
this is the profile of the Daihatsu unit note the rounded face
this is the front of the sleeve
this is the rear
this is both before being pressed home the unit next to it's the Daihatsu
Posted: Sun Dec 07, 2014 2:24 am Post subject: |
G'day all. bit of progress on front differential. bolted the front beam in & started locating the rack & pinion
ernie
The parts required to put the Toyota electronic speedo drive into the Nissan transfercase
the red drive is Nissan it had to be machined down & a slot cut into both sides to fit onto the Toyota shaft. The aluminium ring is to allow the drive to sit in tight
The ring going on
stever70 Samba Member
Joined: October 30, 2009 Posts: 302 Location: california
Posted: Sun Dec 07, 2014 3:04 pm Post subject: |
Looking great!!! Sorry I didn't respond to your question earlier, mine is coming along, working on wiring right now. Keep it up, I am enjoying watching someone else do this _________________ my build log
http://offroadvwbus.blogspot.com/ |
Posted: Tue Dec 30, 2014 9:32 pm Post subject: |
G'day steve70. all the best for the new year new years eve here now 2 30pm so not much of this 1 left what other build are you following like to have a look at their work& ideas
ernie |
busyguyfish Samba Member
Joined: November 10, 2010 Posts: 26 Location: Doyle, CA
Posted: Tue Jan 13, 2015 8:44 pm Post subject: 4 by bay |
I guess it's time to get started on my own 71 Ernie.
Went out yesterday with my die grinder and had a go at the front where the Radiator will be. Got a good start and then came the problems. Decisions-Decisions. I had started the cut to install a 84 Vanagon radiator that I had laying around, but it is way deeper than the one from the Subaru. The Subie also has 2 fans but is a bit wider and shorter than the VW one. I'll post pictures once it's installed.
Have most of the harness for the engine done and will get an adapter to the type 3 automatic in a few weeks and should have the engine in the bus within the month.
I'm going to use as much Subaru stuff as possible. I had already decided to use the Subi fuel pump but to simplify that part and few measurement later I'm just going to install the entire tank in place of the 71's. Need to do a little metal surgery but much less then modifying the bus tank.
I'm putting the basic's in now so I can drive it as I collect soda cans to save the money to get the kit from Todd to put the 5 speed Subi trans an SVX motor in. and during that time I'll build the front end with the hub carriers. I wandered the junk yard today looking at hub carriers to use. I drug home hubs from a 97 jeep wagon for some R&D. The bus spindle seems to be 6" inside and the jeep is 7 1/2". What were the ones your using and the mount plate you emailed me increases the width from original by how much?
Thank's again and I guess I should start my own thread so the arm chair builder and supervisors can point out my faults and tell me how it should be done.
Steve |
Posted: Thu Jan 22, 2015 3:39 pm Post subject: |
G'day busyguyfish The beam spread is 80mm's difference between mine & stock
ernie |
Posted: Tue Mar 24, 2015 2:51 am Post subject: |
G'day all. Out there. I pulled the front beam today to do the final fitting off diff & power rack & pinion plus sort out the length of axles. The diff had to be offset to go beside the sump not under it. I think it will have 2 shafts minimum possibly 3 sections. 3 sections will have a standard universal joint & diff flange on both ends the centre section will have a centre bearing joint on each end of it.
