Tobias Duncan Samba Member
Joined: January 15, 2013 Posts: 1390 Location: Taos NM
Posted: Sat Apr 13, 2013 9:00 am Post subject: Air conditioning fan will not come on. |
1988 Westie converted to R134 back in 2004
Things I have checked:
Fuses are good
There is power to the wiring in the closet.
System is properly charged.
Tried to check the switch itself but cant figure out how to get at it.
I am kinda hoping there is a list of usual suspects. Did some searching but have not found anything yet.
Anyone have any ideas? |
Posted: Sat Apr 13, 2013 12:50 pm Post subject: |
I just tried jumping the pressure switch on the off chance the fan was connected into all of that but no dice.
Also it does not look like my compressor is engaging. |
JPrato Samba Member
Joined: December 15, 2006 Posts: 791 Location: Livonia, NY
Posted: Sat Apr 13, 2013 2:07 pm Post subject: |
Time to get the Bentley manual out with your volt/ohm meter and work backwards from the fan leads. They will be in one of the connectors on the left rear pillar along with the rest of the AC wiring. _________________ Joe
87 Syncro Tin Top project
84 Westy, 2.5L Subaru power
06 Subaru 2.5 turbo in waiting
46 Cessna 140 |
stubear334 Samba Member
Joined: August 24, 2009 Posts: 152 Location: Montgomery, AL
Posted: Sat Apr 13, 2013 8:03 pm Post subject: |
I had a similar problem, the fan wouldn't turn on at all. Turns out the motor connections were corroded. Think about it....the front of the van gets all the nice rain & moisture pressure fed into the front grill. Disassemble every connector from the motor to the resistor & clean it. Then, jump the temp sensor connector plug & test. |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9798 Location: Mt Lemmon, AZ
Posted: Sun Apr 14, 2013 6:56 am Post subject: |
I took it to mean he was having a problem with the blower fan (in the rear with the evap).
If that is the case I would test the switch as that is the part that the fan (not running) and compressor (also not working) have in common. |
Posted: Sun Apr 14, 2013 7:45 am Post subject: |
Ahwahnee wrote: |
You make a strong case.
Does anyone know how to access that switch? I looks like it should just pop out but I cant seem to get it loose.
I sure hope I dont have to pull the dash to get at it. |
Posted: Wed May 29, 2013 11:31 am Post subject: |
Still wrestling with this one.
No power to switch.
Clutch does engage when jumped to the alternator.
System is charged more or less.
Nothing comes on. |
kuleinc Samba Member
Joined: August 10, 2007 Posts: 1604 Location: East Bay Area, California
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17115 Location: Retired South Florida
Posted: Wed May 29, 2013 12:12 pm Post subject: |
I am sorry, but what is actually not working? Jumping the AC compressor clutch to power only tests the clutch is pulling in. There should be a switch to keep the compressor from turning on when it is low on freon. There is also a switch to cut the compressor off if the pressure is too high. Your subject is "Air Conditioning fan will not come on". Am I to assume that the interior blower does not blow when the AC is turned on? Does the radiator fan run on low when you turn the AC on? It should. The factory AC circuit on the Vanagon has a lot of points to check for power loss. There is no magic bullet. You need to determine where you are loosing power. As suggested a good manual and a test light are all you need. _________________ ☮️ |
Posted: Wed May 29, 2013 12:36 pm Post subject: |
kuleinc wrote: |
As long as fuses are good and big red wire to alternator has power fans for evap should come on. My van is not charged ATM. Fans come on. My brothers van has no fan action currently. My next thing to check are the fuses behind left vent on dash... |
Fuses behind the left vent on dash?
You dont just mean the fuse panel right?
How do you access these? I have only checked the fuse panel under the steering wheel and the fuses behind the closet. |
Posted: Wed May 29, 2013 1:01 pm Post subject: |
Good god! How the heck do you keep all 4 tabs depressed long enough to remove the vent? |
Posted: Wed May 29, 2013 1:36 pm Post subject: |
Never have removed the vent to access the fuse panel. Isn't it easier to remove the mounting bolts for the fuse box and drop it down or am I miss understanding. To remove the vent you do one side at a time applying slight pressure from behind while you unclip the opposite two. _________________ ☮️ |
denwood Samba Member
Joined: July 29, 2012 Posts: 1047 Location: Thunder Bay, Ontario, Canada
Posted: Wed May 29, 2013 1:58 pm Post subject: |
Page 3:
http://www.lakoautoklub.hu/archivum/letoltes/tartalom/van_4_89.pdf
Your van has AC in the rear with relays etc. The clutch will not engage if the low pressure switch is active, and will also disengage if the pressure is too high.
That said, if the AC clutch won't engage with 12Volt fed to it directly, then your problem begins there. The fans should come on regardless if all is OK in the cabinet. I would start confirming that temp thermostat "switch" is working. _________________ Cheers,
Dennis Wood
The Grape |
