jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Sun Jul 08, 2018 1:29 pm Post subject: Re: Welcoming Arándano: a 1975 single cab |
TomWesty wrote: |
It's not necessarily oil pressure, but rather crankcase gases pressurizing and pushing the oil out. In my case I had to enlarge the hole that the gases initially exit through. On my type one, this was a hole in the side of the aftermarket oil filler. |
Isn't the crankcase breather box on top of the crankcase open to the crankcase?
Where else would gases be building up?
Tcash wrote: |
Its leaking from where? |
It's leaking from the bell housing. I am trying to find the thread where I discussed this at length, but the short version is that I have checked and replaced the main front sea and O-ring about 4 times now, using the good SABA seals and graphite-impregnated O-rings. I have a new flywheel (leaking happened before this, and the flywheel was one of my attempts to fix it) and clutch parts.
More recently, I have replaced the oil gallery plugs that had been put in there, sealing the new aluminum ones with JB weld as a sealant. Those suckers can't be leaking now.
So, where else could the leak be coming from?
My current line of inquiry has been suggested by Tom Westy: There is crankcase pressure building up as the engine gets up to temperature and highway speeds, and this is forcing oil out through the main seal. Sounds plausible, but I need to understand more about how and where this pressure could be building up. _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
SGKent Samba Member
Posted: Sun Jul 08, 2018 3:17 pm Post subject: Re: Welcoming Arándano: a 1975 single cab |
test the breather box, breather, and hose.
I found on mine that the oil weep is right at the juncture of the seal and case part lines. I suspect that all the engines that leak love to leak at that spot. Once oil gets in that spot it is hard to get a sealer to plug that area. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
jtauxe Samba Member
Posted: Sun Jul 08, 2018 5:27 pm Post subject: Re: Welcoming Arándano: a 1975 single cab |
Are you talking about this breather box? The soap bar sized black box held down with the bale, to the right of the distributor, right?
It's empty, and the lines to the collector box and to the air filters are clear.
Isn't that ventilating the crankcase?
If that is all clear, then where would crankcase pressure be building up that would cause a leak in the bell housing (ostensibly through the main seal)... ? _________________ John
http://vw.tauxe.net
Tcash Samba Member
Posted: Sun Jul 08, 2018 5:36 pm Post subject: Re: Welcoming Arándano: a 1975 single cab |
jtauxe wrote: |
I am trying to find the thread where I discussed this at length |
Control panel>View Profile>Find All Topics Started By jtauxe
Sudden severe oil leak -- blown oil gallery plug, now fixed
GD
Tcash |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51155 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Jul 08, 2018 5:43 pm Post subject: Re: Welcoming Arándano: a 1975 single cab |
Did you happen to take any pics of the front of the case while the flywheel was off?
Since you've done the flywheel seal and gallery plugs maybe there's a crack or flaw in the case that only opens when it's hot?, and likely with access to pressurized oil opposed to case cavity pressure, if it was a breather issue it'd probably be puking it out from all the seals and gaskets equally. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Tcash Samba Member
Posted: Sun Jul 08, 2018 5:55 pm Post subject: Re: Welcoming Arándano: a 1975 single cab |
This is all I could find on Crankcase breathing. It mentions a double lip main seal.
https://newsite.hamheads.com/2016/12/10/type-4-crankcase-breathing-system-tests-analysis/
There was a write up on testing crankcase pressure. But I can't find it.
Hook up a pressure gauge to your dipstick and post the readings.
Next time you have the Flywheel off. Put some Dykem layout ink on the mating surface and bolt it back on and look for any uneven spots on the crankshaft.
Or use some Plastigauge. |
Tcash Samba Member
Posted: Sun Jul 08, 2018 6:14 pm Post subject: Re: Welcoming Arándano: a 1975 single cab |
busdaddy wrote: |
Since you've done the flywheel seal and gallery plugs maybe there's a crack or flaw in the case that only opens when it's hot?, |
Sometimes you can not see the crack with the naked eye.
Aluminum crack detection kit
https://www.google.com/search?client=safari&rl...fwd-pPPulw
Forsaken1 wrote: |
this one happened to me last week.
jtauxe Samba Member
Posted: Mon Jul 09, 2018 6:58 am Post subject: Re: Welcoming Arándano: a 1975 single cab |
Tcash wrote: |
jtauxe wrote: |
GD
Tcash |
Yeah... that one was about another bus, the 1978 double cab. Maybe the thread I'm looking for was over on Colin's site.
Yes, I have photos of the front of the engine with the flywheel off. Everything looks fine... but after seeing these examples...
...could be a cracked crankcase? Oh, my, yuck. After all this work, money, and aggravation...
I guess I should not be so quick to sell the wrecked '74 Westy with the working engine and dual Solexes... _________________ John
http://vw.tauxe.net
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Mon Jul 09, 2018 11:14 pm Post subject: Re: Welcoming Arándano: a 1975 single cab |
Your positive it’s oil and not gear oil? Easy mistake to make...transmission input shaft seal. Just tossing the idea out.
Do you seat the rear main flush or in the case a bit? _________________ Stuart Zickefoose
206-841-7324
[email protected] |
jtauxe Samba Member
Posted: Tue Jul 10, 2018 7:07 am Post subject: Re: Welcoming Arándano: a 1975 single cab |
Stuartzickefoose wrote: |
Do you seat the rear main flush or in the case a bit? |
Definitely engine oil. I also have to add a quart after 100 km (this Mexican truck only does km).
And... main seals. I replaced it the first time after the top end rebuild, when I replaced the flywheel, pressure plate, clutch parts, and everything else replaceable in there. I used a [brand name temporarily escapes me -- common manufacturer, blue and white box] seal. After reading the missive on GoWesty about main seals (http://www.gowesty.com/tech-article-details.php?id=60, where they mistakenly call this the rear seal, though it is definitely the front seal), I bought a bunch of SABO seals, and have been using those since. Like 4 times since. I've put them in flush with the crankcase, just proud of the crankcase, and I even tried a 12-mm seal for a Vanagon, as suggested by raygreenwood. None of these made any difference whatsoever.
Replacing the gallery plugs has made no difference.
The most recent suggestion is that there could be a crack in the case. I would have to yank the engine out again to check, but what could even be done about that, anyway? _________________ John
http://vw.tauxe.net
Posted: Tue Jul 10, 2018 8:33 am Post subject: Re: Welcoming Arándano: a 1975 single cab |
You need to pull it, clean behind the flywheel, and reinstall, then pull in 100 miles to see where the oil marks are _________________ Stuart Zickefoose
206-841-7324
[email protected] |
jtauxe Samba Member
Posted: Wed Jul 11, 2018 7:07 am Post subject: Re: Welcoming Arándano: a 1975 single cab |
You need to pull it, clean behind the flywheel, and reinstall, then pull in 100 miles to see where the oil marks are |
I've done that a few times now. I guess I need to put some UV dye into the oil and try it, since I could not see anything unusual in terms of oil previously. It all just looked clean -- no streaks or anything. _________________ John
http://vw.tauxe.net
Posted: Wed Jul 11, 2018 11:45 am Post subject: Re: Welcoming Arándano: a 1975 single cab |
jtauxe wrote: |
I've done that a few times now. I guess I need to put some UV dye into the oil and try it, since I could not see anything unusual in terms of oil previously. It all just looked clean -- no streaks or anything. |
Pics?
Is the back of the flywheel what’s getting wet? Or the whole bellhousing? _________________ Stuart Zickefoose
206-841-7324
[email protected] |
jtauxe Samba Member
Posted: Fri Jul 13, 2018 9:16 am Post subject: Re: Welcoming Arándano: a 1975 single cab |
jtauxe wrote: |
Pics?
Is the back of the flywheel what’s getting wet? Or the whole bellhousing? |
It's hard to tell. My oil is too clean -- I need some dirty brown oil to see where things are coming from. Or, better, use the UV dye.
But, for now, this is on hold as I catch up with other things in life. My current plan, once I get back into this, is to add UV dye, drive my favorite loop around the County, and then pull it to inspect for the source of the leak.
I may pull the 1800 engine with original Solexes from the parts bus and put it in the pickup. That would give me a chance to try out that somewhat unknown engine, too. If it works, and doesn't leak, then I may leave it in.
Then I would need to decide what to do with the current engine, which runs fine and powerfully, but leaks oil like crazy.
This may be on hold for several months, honestly, even though I do want to drive the truck back to San Antonio and take all the previous owners out to dinner to get stories. I suppose that as long as I take enough oil, I could make the trip. Just keep oil in it and there would be no harm, right? _________________ John
http://vw.tauxe.net
Posted: Fri Jul 13, 2018 4:58 pm Post subject: Re: Welcoming Arándano: a 1975 single cab |
Keep oil in it and worst case you soak a clutch disc. I say go for it! And when you get back the oil will be plenty dark for diagnosis. _________________ Stuart Zickefoose
206-841-7324
[email protected] |
jtauxe Samba Member
Posted: Tue Oct 09, 2018 7:46 am Post subject: Re: Welcoming Arándano: a 1975 single cab |
I'm back to the high crankcase pressure theory.
Adrian Audirac (Headflow Masters), who built the new 1800 heads and provided them with new pistons and cylinders, also supported the idea that crankcase pressure could be the cause. He suggested just taking off the breather box entirely, for testing purposes, and running it open (with a piece of foam on it or something to keep stuff from going in). So that is my next test.
I have heard two other suggestions for relieving pressure, if in fact that is the problem. One is to add relief ports to the valve covers. The other is to tap into the cylinder head relief ports.
Has anyone here done either of those approaches? _________________ John
http://vw.tauxe.net
Volswagon Samba Member
Joined: December 29, 2009 Posts: 299 Location: Knoxville, TN
Posted: Tue Oct 09, 2018 9:23 am Post subject: Re: Welcoming Arándano: a 1975 single cab |
From what I read a while back, possibly on Raby's old site, venting the valve covers basically draws more oil up there instead of having it drain back to the case. Stuffing a couple of copper scrub pads in the breather tower cut down on oil getting in my filter (single Weber progressive). _________________ I know the pieces fit, cos I watched them fall away.
Wanna hear God laugh? Just talk about your plans.
'75 Bus https://www.thesamba.com/vw/forum/viewtopic.php?t=697183&highlight= |
jtauxe Samba Member
Posted: Tue Nov 20, 2018 8:04 am Post subject: Re: Welcoming Arándano: a 1975 single cab |
Seems to me that oil in the valve cover space would find its way back to the crankcase through the pushrod tubes... or am I missing something in how this is put together?
At any rate, I'm going to try the valve cover venting trick. I'll post results here. _________________ John
http://vw.tauxe.net
Posted: Tue Nov 20, 2018 9:06 am Post subject: Re: Welcoming Arándano: a 1975 single cab |
The point is to put the vents at the TOP of the valve covers to allow intake manifold suction to create negative pressure in the AIR of the crankcase. By routing a vacuum line from the valve cover into the air filter the air space inside the case is then put under a little bit of constant suction. If there’s not negative pressure, even a brand new seal could get blown out by a few psi of pressure. So, by having a vacuum inside the case, even with OIL PRESSURE (totally different) the seals should not leak because the exiting force is sending the pressure into the intake rather then out the oil seals. Path of least resistance
Someone correct me if I’m wrong, I don’t have all the answers just thought I’d spout off this one _________________ Stuart Zickefoose
206-841-7324
[email protected] |
jtauxe Samba Member
Posted: Tue Nov 20, 2018 10:01 am Post subject: Re: Welcoming Arándano: a 1975 single cab |
... even a brand new seal could get blown out by a few psi of pressure ... |
It is my understanding that this is how a main seal is supposed to work -- as a pressure relief valve. If there is high pressure in the crankcase, the spring in the seal allows oil to pass through. I believe this is what is happening in my case.
I tried getting more suction by connecting the breather box on the "chimney" (Hoffman's term) directly to the carburetor air intake stacks, through the air filters, in an attempt to tap into the low pressure region in the velocity stacks. This did not help.
I also tried a suggestion by Adrian Audirac: Remove the breather box from the chimney, leaving the chimney wide open. I stuffed a piece of foam over the open hole to keep dirt out, and drove it to test. No change. Heck, if that did not relieve pressure, I really don't know what would. _________________ John
http://vw.tauxe.net
