Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Tue Nov 20, 2018 11:37 am Post subject: Re: Welcoming Arándano: a 1975 single cab |
so let me get this right. You have a huge oil leak coming from what you presume to be the rear main seal. And you think it is because of your case pressure. But you have removed your breather box all together, and tried routing it to the negative pressure of your air intake. And you still think it is case pressure being too high? ... sounds like a bad seal to me... why do you think it isn't just a bad seal? am I missing something? _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Tue Nov 20, 2018 12:30 pm Post subject: Re: Welcoming Arándano: a 1975 single cab |
To be clear, it is the front (towards the front of the car) main seal that I believe is leaking oil into the bell housing. I have replaced the seal several times with the best seals I can find.
Perhaps there is a reason besides crankcase pressure that the seals always leak...
Could it be that the new flywheel / pressure plate / clutch assembly that I installed would make it leak? If so, how? _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
Posted: Tue Nov 20, 2018 2:26 pm Post subject: Re: Welcoming Arándano: a 1975 single cab |
jtauxe wrote: |
Could it be that the new flywheel / pressure plate / clutch assembly that I installed would make it leak? If so, how? |
Strange. You're sure the case is smooth where the seal sits? and I assume the seals are installed correct (tough to put them in wrong... idk how you would manage that.) seems strange... If it were just a drop here or there, I'd believe crank pressure. What weight oil? What oil pump? hmmm... _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
jtauxe Samba Member
Posted: Tue Nov 20, 2018 3:06 pm Post subject: Re: Welcoming Arándano: a 1975 single cab |
Stock oil pump. 20W 50 oil. Maybe I should switch to a lighter weight? _________________ John
http://vw.tauxe.net
Posted: Fri Nov 23, 2018 10:39 am Post subject: Re: Welcoming Arándano: a 1975 single cab |
jtauxe wrote: |
Stock oil pump. 20W 50 oil. Maybe I should switch to a lighter weight? |
You may have already said this, but what oil pressure do you have? And I'd run something thinner, unless your engine is really old and worn out. But if you have good tolerances there is no reason to force 20w50 through your engine. I use valvoline vr1 30weight. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
jtauxe Samba Member
Posted: Mon Dec 31, 2018 9:57 am Post subject: Re: Welcoming Arándano: a 1975 single cab |
I had inadvertently added a comment on lighting here, but meant to do it in my build thread on this truck:
https://www.thesamba.com/vw/forum/viewtopic.php?p=8967202
I moved the general discussion to that thread.
We can keep this thread for the engine issues. _________________ John
http://vw.tauxe.net
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Tue Jan 01, 2019 10:16 am Post subject: Re: Welcoming Arándano: a 1975 single cab |
My favorite repairs are lighting nice work!! Very cool. Can you take a pic of the wiring to the driving lights through the nose? I thought only headlight washers ran wires through the nose...hmmm. Cool fact to learn! _________________ Stuart Zickefoose
206-841-7324
[email protected] |
jtauxe Samba Member
Posted: Tue Jan 01, 2019 5:39 pm Post subject: Re: Welcoming Arándano: a 1975 single cab |
Stuartzickefoose wrote: |
My favorite repairs are lighting nice work!! Very cool. Can you take a pic of the wiring to the driving lights through the nose? I thought only headlight washers ran wires through the nose...hmmm. Cool fact to learn! |
Oops. I meant to post that bit on lighting in the build thread, and will answer your question here:
(Please use that build thread for more talk about this single cab, aside from the engine issues). _________________ John
http://vw.tauxe.net
Posted: Wed Jan 02, 2019 12:20 am Post subject: Re: Welcoming Arándano: a 1975 single cab |
jtauxe wrote: |
(Please use that build thread for more talk about this single cab, aside from the engine issues). |
Sure thing! good catch. _________________ Stuart Zickefoose
206-841-7324
[email protected] |
jtauxe Samba Member
Posted: Sun Sep 06, 2020 5:45 pm Post subject: Re: Welcoming Arándano: a 1975 single cab |
OK. I can't stand it. The only thing that I did not ACTUALLY check last time was the tightness of the oil gallery plugs. It must be that one of those was loose even though it looked fine. Time to pull the engine yet again... Sad
This time the focus is on the gallery plugs. I removed all the steel plugs and switched them out for aluminum plugs, so that they enjoy the same coefficient of expansion as the block. The two on the right seemed fine. The one on the right had poorly cut threads which I blame on the builder who cut them. But I cleaned all the threads with acetone and used JB Weld as a sealant. These are going nowhere.
This time, I added a new pilot bearing (which curiously left no room for the felt washer), cleaned and lightly resurfaced the faces of the pressure plate and flywheel, and torqued it all up to spec. Got it all back together again, and ... no change. Still dumps oil. Double crap.
But the truck drives so fine! It is smooth and has power and is bouncy as heck.
So, what else could cause the oil leak? My double cab builder suggested crankcase overpressure, and that I could route the breather box to an oil trap and them into the carburetor air cleaners. I already had that, but I suppose I could really try to get the air intakes to suck on the pipes. So, I tried that, with replacement intake horms and some plumbing to the the oil breather pipes right down in there.
No change.
Someone suggested ventilating the valve covers. I got some nice new ones and outfitted them with the ventilation kit sold by EMPI, with hoses over a meter long, run up forward under the body. That should do it!
No change.
In Spring 2020, I removed the valve covers with the ventilation hoses and reverted to the original ones. And that is where things stand. _________________ John
http://vw.tauxe.net
