VW The Thing Sun Visor
Jack Clifton
Jack Clifton is offline
PostPosted: Mon Apr 15, 2013 8:31 am    Post subject: VW The Thing Sun Visor Reply with quote
Would like to know what causes the sun visor on VW The Thing to fall and be loose? The visor is in good condition - do I need to replace the screws? holders-w screws? The visor never stays up..
tks
77kafer
77kafer is offline
PostPosted: Mon Apr 15, 2013 8:36 am    Post subject: Reply with quote
Jack, it has been a long time since I owned my thing, but if I remember correctly, there is a small screw that tightens up around the shaft that keeps it from being so loose.
Supposed to be 77käfer, but there are no umlauts on an american keyboard
Overheard on 27 June 07, one lady to another when they saw my Harli in a parking lot at West Point, "maybe he found it on the clearance aisle at the Volkswagen dealer"
NOVA Airhead
NOVA Airhead is offline
PostPosted: Tue Apr 16, 2013 7:25 am    Post subject: Re: VW The Thing Sun Visor Reply with quote
tks
On mine a groove wore into the metal rod over time to such an extanet that tightening no longer worked. Tried to wrap the area but it would not last. Finally purchased new visors from TTS which are very nice.
Ghia Owner Emeritus
billzer06
billzer06 is offline
PostPosted: Tue Apr 16, 2013 7:44 am    Post subject: Reply with quote
What is the metal? If your welding chops are good, you can weld it back up and get rid of the groove. My dad's AMX window gears were shot when he got it, so him and I welded it up and cut new notches in with a dremel tool. That was 5 years ago I think and it still works fine! With enough patience and persistence, I don't see why you wouldn't be able to get it to work that way, as long as its weldable.
CLXXXI
CLXXXI is offline
PostPosted: Tue Apr 16, 2013 3:35 pm    Post subject: Reply with quote
For anyone not bothered about original visors, early/mid 90's Wrangler Jeep visors fit good enough to do the job, in fact they are longer covering more of the window while not as deep which suits the Thing window better in my opinion.
Thought the fixing isn't pretty, if you offer a pair up to the screw points you'll see with a little manipulation (the thick "wires" on the visors slide slightly in & out) you can get a fixing screw in each side.
doublecanister
doublecanister is offline
PostPosted: Wed Apr 17, 2013 10:01 am    Post subject: Re: VW The Thing Sun Visor Reply with quote
Oiling them will cause this......guess how I found out! Shocked
Like an idjut, when I first got my THING the dern visors were very tight to adjust, I figured a lil' wd40 would help, It helped alright.
big Duh on my part, they just have finally started to grab again and hold position.
I dont think at the time I was aware of the adjustment screw....
T
2020 - Mustang Eco Boost [High Performance]
1973 - Thing
1966 - Mustang GT- Fastback
1951 - Ford F1 pickup Flathead V8
Zylinderkopf
Zylinderkopf is offline
PostPosted: Wed Apr 17, 2013 10:16 am    Post subject: Reply with quote
doublecanister - you're not the only one....I did the same exact thing! Rolling Eyes
Have been meaning to fix that... will see if I can find that screw everyone is talking about...
obus Premium Member
obus is offline
PostPosted: Sat Jun 25, 2022 8:51 pm    Post subject: Re: VW The Thing Sun Visor Reply with quote
running into mine flopping. Have to investigate. Its annoying AF
Semper_Dad
Semper_Dad is offline
PostPosted: Sat Jun 25, 2022 8:56 pm    Post subject: Re: VW The Thing Sun Visor Reply with quote
Yep, mine keep flopping down. Ended up jamming a screwdriver in the top latch to hold it up.
Walküre Restoration Thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=737492
jakauffman
jakauffman is offline
PostPosted: Sun Sep 28, 2025 5:08 am    Post subject: Re: VW The Thing Sun Visor Reply with quote
[img]So I know I’m probably over a decade past the party, but I had the same issue with my 1973 VW Thing sunvisor is falling down all the time, especially while I was driving which is definitely a hazard.
What I ended up doing is taking the visors out and putting the metal tips into a vice grip and bending them slightly, maybe 15 to 20°. I put them back in the clips and the pressure that is caused by them being slightly bent is enough to keep them from falling down.
I’ll post a picture. You can see in the picture that they are slightly bent a little bit outward which gives it just enough tension to keep it from falling.
Hope this helps someone in the future!
1978 VW Bus Sage Green Westy
1973 VW Thing
1991 VW Vanagon Carot Wolfsburg edition
