randywebb Samba Member
Posted: Wed Apr 17, 2013 9:56 pm Post subject: check valve |
For a 2.1L engine, does the vacuum hose to the brake power booster have a check valve in it?
Bentley shows one near the intake runners but their pic must be for a 1.9L engine (?) _________________ 1986 2.1L Westy 2wd Auto Trans. |
kamzcab86 Samba Moderator
Posted: Wed Apr 17, 2013 10:15 pm Post subject: |
I seem to recall there one being on my 2.1L, right after a short (like 1-2" long) hose off the intake. I can verify tomorrow, if no one else confirms by then. _________________ ~Kamz
2016 Golf GTI S
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12007 Location: Santa Cruz, CA
Posted: Wed Apr 17, 2013 10:23 pm Post subject: |
Driver's side just at the firewall under the black box with the vacuum diagram on it. |
Posted: Wed Apr 17, 2013 10:43 pm Post subject: |
thx - Bentley 47.10 - they say to check it out periodically _________________ 1986 2.1L Westy 2wd Auto Trans. |
Posted: Thu Apr 18, 2013 11:56 am Post subject: |
Dug up an old photo, in case anyone else needs an image to reference. Red arrow is pointing to the check valve:
(Disregard the filth. This was taken shortly after buying the van and just before the engine got cleaned... probably for the first time in its life.) _________________ ~Kamz
2016 Golf GTI S
Posted: Thu Apr 18, 2013 12:53 pm Post subject: |
Thanks - now I won't be searching in vain by the firewall...
Does it really need to be checked as per Bentley, or would a malfunction be obvious from some other behavior of the Van? _________________ 1986 2.1L Westy 2wd Auto Trans. |
Posted: Thu Apr 18, 2013 1:04 pm Post subject: |
Ha, i moved it for the conversion and forgot about it. |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Thu Apr 18, 2013 1:07 pm Post subject: |
I think if you start the engine and run it for about a minute and then shut it off, depress the brake pedal a few times. You should have more resistance with each application of the pedal until there is no assist. That would indicate the valve is working and there are no other vacumn leaks. I think you get about 5 assisted applications with the engine off. Sort of a fail safe for long downhills if the engine quit. _________________ ☮️
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Thu Apr 18, 2013 1:10 pm Post subject: |
randywebb wrote: |
Does it really need to be checked as per Bentley, or would a malfunction be obvious from some other behavior of the Van? |
I just check the brake booster function once in a while on start-up. If the check valve failed, there'd be no draw down on the brake pedal. _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
Posted: Thu Apr 18, 2013 3:32 pm Post subject: |
Jake de Villiers wrote: |
randywebb wrote: |
I just check the brake booster function once in a while on start-up. If the check valve failed, there'd be no draw down on the brake pedal. |
And FWIW, my Bentley manual does not say to check the valve, it merely lists a procedure for checking the valve (i.e., "if you suspect it's faulty, here's how to check it"). _________________ ~Kamz
2016 Golf GTI S
dasilva Samba Member
Posted: Fri Nov 05, 2021 3:41 pm Post subject: Re: check valve |
Is there a trick for getting the check valve on the brake booster line re-installed?
I'm doing a Bostig conversion on my 1989 Westfalia. Getting the valve re-installed seems...tricky! Too much heat and the plastic on the check valve body melts. Not enough heat and the nylon line isn't widening enough the accept the valve.
Right now, I placed the valve in the freezer. Will try to warm the line tomorrow by placing under the escaping steam from the kettle.
Does anyone else have other tips I am unaware of? WD-40?? Dishwasher soap??
Any help appreciated.
the joker Samba Member
Posted: Sun Nov 07, 2021 8:38 am Post subject: Re: check valve |
Hot / Med hair dyer, or, low heat gun , leather gloves and patience |
DuncanS Samba Member
Posted: Sun Nov 07, 2021 9:10 am Post subject: Re: check valve |
Or dip in boiling water. |
