Danwvw Samba Member
Posted: Sun Oct 28, 2018 12:52 pm Post subject: Automatic Fuel Line Shut-Off Solenoid Valve and Circuit |
My Dell 36's are sometimes leaking gas through overnight and the engine will be hydro locked with gas the next morning, one time it filled the crankcase with gas. This problem started about a year ago and I got it cleared up by changing a float but the problem has returned.
The CB-Performance 3 psi Rotary Electric fuel pump does not shut-off the gas from the tank when stopped so I have an Idea here to solve the problem.
Cheap $10 Solenoid Valve from eBay:
Current Limit circuit to keep the valve from overheating during driving.
Prototype:
_________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Danwvw Samba Member
Posted: Sun Jan 27, 2019 7:56 pm Post subject: Re: Building a 74 mm Stroke by 88 mm bore with 042 or 044 heads? |
Installed it finally, and it works!
Also rewired the fuel pump and all to run directly off the battery.
Updated Schematic:
Danwvw Samba Member
Posted: Tue Feb 04, 2020 5:03 pm Post subject: Re: Building a 74 mm Stroke by 88 mm bore with 042 or 044 heads? |
Built in 2013:
Miles on the engine as of Feb. 4th 2020 is 24637 and STILL GOING!
1800cc Type 1 Engine Build Sheet: Special thanks to everyone here on the Samba that participated.
Machine Work: Local shops,
Misc: Parts and service: Bug Germinators, North Bend OR and 2nd Street Foreign Car Service Coos Bay Oregon.
Engine Case: 1971 VW Bus AS-41 Magnesium, Inserted for 10mm studs, Full Flow oil return and block off, Stock 1600 Cylinder Openings.
88mm Bore, 74mm Stroke,
Dual 36 DRLA Dellorto Carburetors, May 2017 Removed and cleaned new gaskets and orings clean and lube bearings
Cam Web-Cam 163 with 284' 250' at .050" and .422" Valve Lift with 1.1:1 Rockers, Web-Cam 163 Profile
Heads German 113 Dual Port cut for 90.5mm cylinders (with step), 3 angle valve job and port matched using stock VW 35.5mm(used german intake) x32mm(new exhaust valves) with new Single HD Valve Springs,
Solid Rocker shaft from CB-Performance, 1.1:1 Ratio stock VW rockers,
CB-Performance Elephant Feet Adjusters,
Bug Pack Aluminum Push Rods (Stock Length)
Push Rod Tubes are CB Performance 1565 Large ID Racing,
Lifters are cb-performance 1537 UltraLightWeight 28mm,
Valves Springs Single HD Racing. Valve guides Stock VW
CR 8.5:1
Rods 5.325" H Beam Racing Rods from Aircooled.Net,
Crankshaft: 74mm Counterweighted 4340 Forged from Aircooled.Net,
Piston and Cylinders 88mm AA ThickWall from Aircooled.Net
Flywheel Stock VW Surfaced and drilled for 8 dowels,
Pressure Plate: Sachs 200mm Porsche style 1971 and up CB-1324, Clutch is starting to slip on take-offs unless babied
Throw Bearing OEM,
Disc Kush Lock Solid,
Scat Aluminum degree pulley, Everything Balanced by part and Dynamically with clutch and flywheel mounted to the crank,
Electric 12 volt Fuel Pump: 3 1/2 lb Rotary CB-Performance 3193,
Oil Pump 26mm Schadek with Empi Steel Full Flow Cover Plate,
Oil lines and remote filter CB-Performance 1732,
Oil Filter VW Rabbit Type Mann W719/5 Others I have tried include WIX 51342, HASTINGS LF493F, WIX 51515, (ECOGARD Synthetic oil filter S4670), Bosch 3400
Castrol GTX 5W30 motor oil with Lucas TB Plus Zinc Oil Additive, Mobile 1 full synthetic 0W40,
German Bosch .009 with points, Mechanical Advance Distributor set for Max advance of 33', 30',
Bosch Blue Coil,
Empi Spark Wires, New old stock Bosch Spark Wires
Spark Plugs are Bosch Super Plus WR8AC+ 14mm X 1/2", Changed twice except for #2 just once
Motorola 12 volt Alternator with Aftermarket External Regulator, I think one phase of the Alternator has burned out 02/04/2020
Intake Manifolds: CB performance off-set with hex bar linkage Linkage wore out and had to be up-dated using rocker arm parts for bearings in it. CB Performance air-cleaners.
Current Air Correction are : 1.80
Mains: 1.32 1.35
Idle: .60 tried .55 Went back to .60
Venturi: 30mm
Extractor, BugPack 4 into 1 1 1/2" single Empi Muffler", Stock Heater boxes New Muffler Feb 2018
New Battery Sept 2019
calvinater Samba Member
Joined: September 06, 2014 Posts: 3330 Location: 802 The Pointless Forrest
Posted: Wed Feb 05, 2020 5:02 am Post subject: Re: Building a 74 mm Stroke by 88 mm bore with 042 or 044 heads? |
Are you using a doghouse shroud? Any fitment issues with the manifolds/ carbs? _________________ "Albatross"! |
Danwvw Samba Member
Posted: Wed Feb 05, 2020 11:25 am Post subject: Re: Building a 74 mm Stroke by 88 mm bore with 042 or 044 heads? |
calvinater wrote: |
Are you using a doghouse shroud? Any fitment issues with the manifolds/ carbs? |
Yes it's the 1971 year with the DogHouse based 1600 DP and yes when I put the IDF manifolds on I had to do some grinding on the manifolds however longer intake manifold studs would eliminate that. They kind of force fit into the Head tins I did grind the IDF intake manifolds down some, also I drilled and tapped the Left Manifold for a Vac Line for the Brakes.
It's hard to change spark plugs in on cylinder #1 and #3 the longer type 4 spark plug receptacle may help. It's important to make sure the 8mm nuts that fasten the intake manifolds down aren't so big they are in the way of the sparkplug socket wrench, also a skinny sparkplug socket wrench helps. I like the Steel 10mm 12 point 8mm nuts best to secure the manifolds.
In a VW Bus there is plenty of room for whatever carbs you may want to use however on my bus I have all the wiring in the way of changing the #1 plug. I need to do that differently if I ever pull the engine.
Danwvw Samba Member
Posted: Wed Jun 17, 2020 7:12 pm Post subject: Re: Building a 74 mm Stroke by 88 mm bore with 042 or 044 heads? |
The 74mm X 88mm Engine is still running perfectly.
Made my own Turn Signal Relay: Running Stock Turn Lamps etc LED Indicators though. Works Great!
This is my own design feel free to use it!
Prototype 2:
A Trench Mosfet is gated at 19 Volts to work as a solid state relay between +12-14 VDC and the Turn and Emergency Flasher Lamps to ground.
Danwvw Samba Member
Posted: Sun Oct 03, 2021 1:49 pm Post subject: Re: Building a 74 mm Stroke by 88 mm bore with 042 or 044 heads? |
Oct 3 2021 Still Running, No problems at all. 27217 miles on the engine so far.
UTube link to Fuel Pump Safety override switch: https://youtu.be/HzBVho5b-Xc
Danwvw wrote: |
Built in 2013:
Last Valve Adjust and oil change done in October 2021 at 27K plus miles:
CR 8.5:1
Throw Bearing OEM,
Oil Filter VW Rabbit Type Mann W719/5 Others I have tried include WIX 51342, HASTINGS LF493F, WIX 51515, (ECOGARD Synthetic oil filter S4670), Bosch 3400 now running the next generation of Fram Ultra Synthetic XG-16 with excellent results
Bosch Blue Coil,
Mains: 1.32 1.35
Venturi: 30mm
Saul Koll Samba Member
Joined: September 28, 2008 Posts: 191 Location: Portland
Posted: Sun Oct 03, 2021 2:21 pm Post subject: Re: Building a 74 mm Stroke by 88 mm bore with 042 or 044 heads? |
Cool stuff!
Danwvw wrote: |
Prototype 2:
_________________ "I wish you could smell the smell that's coming from the bus"... |
