NJ John Samba Member
Joined: September 21, 2007 Posts: 2224 Location: HdG, MD & NJ
Posted: Thu Apr 18, 2013 5:54 pm Post subject: Do ICT's fit Kadron manifolds? |
Or can they be made to fit? Just looking for taller intakes. Thanks _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
OLD VW NUT Samba Member
Joined: February 23, 2011 Posts: 2776 Location: High Desert of Washington 98823
Posted: Thu Apr 18, 2013 6:35 pm Post subject: |
Since there is only 6mm difference in the throttle size the ICT might be a close fit to the Kadron manifolds. Your throttle linkage will be raised as well which could cause problems. _________________ 71 Ghia Coupe - stock body - no rust! Powered by a 2110 W/Dual HPMX 44's - Rancho Pro Street Transaxle - A/C by Gilmore
Other car - 2013 VW Golf TDI |
jefftrish Samba Member
Posted: Thu Apr 18, 2013 6:51 pm Post subject: |
The bolt holes on the top of the kadron intakes is about 1/2 an inch wider. Bolt to bolt ICT 2 1/2: apart. Bolt holes Kadrons 3" apart
Regards,
Jeff |
Posted: Thu Apr 18, 2013 6:58 pm Post subject: |
I was thinking,You could make a adapter plate if you don't have access to the ICT intakes.
The best way is to buy the proper intakes.
Jeff |
Posted: Fri Apr 19, 2013 6:11 am Post subject: |
Thanks for the input and the measurements. Just tossing ideas around. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Fri Apr 19, 2013 9:42 am Post subject: |
I have seen a picture of what you're thinking about. A new plate with the ICT pattern was welded to the top of the steel manifold. |
Rome Samba Member
Joined: June 02, 2004 Posts: 9653 Location: Pearl River, NY
Posted: Sat Apr 20, 2013 8:32 am Post subject: |
Look at these two photos and captions. Though they pertain to single-port intake manifolds, the carb flange dimensions are what you need. I don't have an ICT manifold to measure, but you do- so this may help you.
Comparison of manifolds for carburetors (left to right) Solex 32PDSIT (Type 3), Dell'Orto 34FRD (Type 1), Kadron (Solex/Brosol 40EIS).
PDSIT and 34FRD mounted on wood so that all have approx. the same flange height.
Carburetor stud/hole spacing, approx. center to center:
PDSIT 2 3/8" (60mm)
34FRD 2 11/16" (68mm)
Kadron 2 7/8" (73mm)
Carb flange hole diameter:
PDSIT 1 3/8" (35mm)
34FRD 1 1/2" (38mm)
Kadron 1 9/16" (40mm)
Balance tube outer diameter:
PDSIT 5/8" (17mm)
34FRD drilled for 3/8" hole (9mm)
Kadron 5/16" (8mm)
Comparison of manifolds for (left to right) Solex 32PDSIT for Type 3, Dell'Orto 34FRD (Type 1 application), and Kadron (Solex/Brosol 40 EIS).
Height of carb flange to manifold mounting flange (simulates the vertical height above the head), measured to underside of bottom flange at attachment holes:
PDSIT 3.0" (76mm)
34FRD 3 3/4" (95mm)
Kadron 5 3/4" (146mm)
Runner length, along "inner" side of manifold pipe (facing the engine), from top of carb flange surface to bottom outlet of manifold:
PDSIT 3 3/4" (95mm)
34FRD 4 5/8" (117mm)
Kadron 6 1/4" (158mm)
All have the manifold base "shoulders" extending 1/4" (6mm) downward into the head's intake port.
Most likely you are working with dual-port heads. The DP Kadron manifolds are similar in height to the SP ones. |
Posted: Sat Apr 20, 2013 9:39 am Post subject: |
wokokow Samba Member
Joined: August 13, 2012 Posts: 27 Location: Nairobi, Kenya
Posted: Wed Dec 30, 2020 9:40 am Post subject: Re: Do ICT's fit Kadron manifolds? |
Digging around some ideas I have and thus landed on this old post. So sorry in advance.
I'm intending to start building a 1200cc motor but would like to dual carb it. So I bought a nice set of 1300cc heads because I knew getting manifolds that would bolt on the 1200cc heads is next to impossible. This was because I had been planning to use 34ICTs on it.
Then I also acquired a pair of 32PDSITs and thought I can save the ICTs for another 1776cc build. Now I've been searching for single port manifolds that can take the PDSITs married to the 1300cc heads on a type 1 application. Are they available anywhere? Or if not, can I fab something for manifolds? |
Rome Samba Member
Posted: Wed Dec 30, 2020 4:06 pm Post subject: Re: Do ICT's fit Kadron manifolds? |
Easy: These: https://www.cbperformance.com/product-p/3261.htm I bought a pair, and the carb flange hole pattern is the same as for your 32 PDSIT's which I tried myself. And the manifold attachment spacing at the head is same for a 1300 as for a 1500/1600 SP head. |
Posted: Sun Jan 24, 2021 6:20 am Post subject: Re: Do ICT's fit Kadron manifolds? |
Thanks so much @Rome. Problem solved. |
