BluBus Samba Member
Joined: October 06, 2003 Posts: 376 Location: Fort Walton Beach, Florida
Posted: Sun Nov 02, 2003 9:04 pm Post subject: self cancelling turn signals |
I have a 74 Rivera and want to know if the turn signals are suppose to self cancel mine never have and its a pain in the a##. |
Paulie Samba Member
Posted: Sun Nov 02, 2003 9:38 pm Post subject: Re: self cancelling turn signals |
BluBus wrote: |
want to know if the turn signals are suppose to self cancel |
Yup... mine don't either. I haven't got around to replacing the switch... |
ratwell Samba Member
Joined: April 26, 2003 Posts: 8717 Location: Victoria, BC
Posted: Sun Nov 02, 2003 11:41 pm Post subject: |
How do they cancel on the 74 and earlier busses? I know it's different from the later ones.
On the later ones there is a cancelling ring with a tab that hangs down and wears from age failing to cancel the signal. _________________ '78 Westfalia CDN
'76 Doublecab
Read the Baywindow FAQ |
Ian Samba Moderator
Posted: Sun Nov 02, 2003 11:47 pm Post subject: |
I think that there is a ring in the steering wheel which manually cancels the signals by hitting a switch in the signal switch. _________________ All your Buses are belong to us.
Love and good roads!
IN LOVING MEMORY OF ROB CRESS 1968-2012
**ACHTUNG DO NOT USE AA BRAND PRODUCTS OR BUY ANYTHING FROM PACIFIC PARTS INTERNATIONAL IN CALIFORNIA** |
Randy in Maine Samba Member
Posted: Mon Nov 03, 2003 6:38 am Post subject: |
On the later ones there is a cancelling ring with a tab that hangs down and wears from age failing to cancel the signal.[/quote]
So where would I get a cancelling ring? Would the dealer have something like that? |
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
Posted: Mon Nov 03, 2003 9:14 am Post subject: |
Just an observation, with the dual turnsignal/wiper combination switches on the '73 and later buses, the assembly has a tendency to creep down if the clamping screws loosen. The clearance between the steering wheel lower edge and the switch assemblies should be about 1/16". Any more than that and the cancelling ring will miss the little self-cancel tit on the switch.
Colin |
wgargan Samba Member
Joined: September 21, 2002 Posts: 871 Location: Dreaming of the Rockies
Posted: Mon Nov 03, 2003 9:48 am Post subject: |
yup thats what happend to mine, put back up and it worked. _________________ Current ride:
1983.5 Watercooled Vanagon 'L' Automatic transmission |
BluBus Samba Member
Posted: Mon Nov 03, 2003 12:00 pm Post subject: |
Thank you guys I readjusted the housing sliding it up and walla it works!!! |
79BayCruiser Samba Member
Joined: August 29, 2003 Posts: 52 Location: Hickory, North Carolina
Posted: Mon Nov 03, 2003 8:09 pm Post subject: |
Could ya'll post some instructions for fixing the turn signals? I have a 79 transporter, are the signals susposed to cancel on mine? I was under the impression that they weren't :-/
Chase _________________ I don't measure a man by his worth, but by his heart ...... or how much he's willing to pay me. |
Posted: Mon Nov 03, 2003 10:00 pm Post subject: |
79BayCruiser,
Take off the steering wheel. Use a 22mm socket, offset box wrench etc otherwise be careful not to strip the nut with a crescent wrench.
Underneath you'll find a black ring like this. On the bottom of it is a plastic tab that wears out and fails to cancel the turn signal. This is what happens in 95% of cases. If it's worn either get a new ring or one in better condition. As a workaround you can wrap the tab with electrical tape a couple of times which will fatten it up and get the turn signals cancelling again.
Try this first. _________________ '78 Westfalia CDN
'76 Doublecab
Posted: Tue Nov 04, 2003 9:45 am Post subject: |
OrangeWesty'73 Samba Member
Joined: October 17, 2003 Posts: 377 Location: Chicago Area
Posted: Tue Nov 04, 2003 9:59 am Post subject: |
Here is another turn signal related question.
Are botht the left and right interior signal lights on the dash supposed to go on when you signal for a turn.
Thanks _________________ -------------
'73 Westy |
Posted: Tue Nov 04, 2003 10:26 am Post subject: |
yes they are. _________________ Current ride:
