pig-pen Samba Member
Joined: December 04, 2012 Posts: 570 Location: United Kingdom
Posted: Sun Apr 21, 2013 4:29 pm Post subject: Clutch |
can anyone suggest the definitive uprated clutch setup for a fast 36?
using 6v starter and 8 dowel WW crank.
cheers
M |
avus Samba Member
Joined: November 11, 2005 Posts: 268 Location: Drain, Oregon
Posted: Sun Apr 21, 2013 5:18 pm Post subject: Re: Clutch |
pig-pen wrote: |
cheers
M |
Here's my vote: http://www.kennedyenginc.com Go to "Porsche clutches", and at the very bottom of the page there is a 180mm that I believe will fill the bill. Planning to put my money where my mouth is... |
txoval Samba Member
Joined: January 23, 2004 Posts: 3540 Location: The Woodlands, TX
Posted: Sun Apr 21, 2013 7:17 pm Post subject: |
For me it depends on the HP and use of the vehicle.
The stock clutch is good for normal driving up to ~90hp.
If you like popping the clutch go with a stock disk and Stage 1 Kennady Pressure Plate |
Posted: Mon Apr 22, 2013 12:45 am Post subject: |
really? stock is good for 90hp??
I must say I am surprised... will be running a charger on a 1500cc 36hp case.
until that is built the same charger will be on my 1200cc, I estimate about 55hp
so, considering the extra torque... do you think the stock clutch will be good enough? |
AirCooledClassics Samba Member
Joined: August 20, 2004 Posts: 292 Location: Saskatoon, Sk Canada
Posted: Mon Apr 22, 2013 9:24 am Post subject: |
The stock 211 bus clutch will hold up to 90 If driven with respect. Not the 113 clutch. Im sure I could slip a 113 bug pressure plate with 45hp. The new chinese 211 pressure plates are strong but very grabby compared to a 211 f&s. If I remember right the 113 holds 900lbs and the 211 holds 1100lbs.Ive used the 211 on a 1641 85hp engine for years but it was never used in a drag race launch. _________________ 2010 Bonneville record holder Type 2, 36hp
NHRA Divisional Sports Compact Champion
My You-tube video
http://www.youtube.com/watch?v=GJoq3MtsPmc
My National Dragster article
http://www.dragracecentral.com/DRCStory.asp?ID=231552 |
txoval Samba Member
Posted: Mon Apr 22, 2013 6:58 pm Post subject: |
pig-pen wrote: |
I'm getting old, 90 hp for a stock 200mm clutch...
For a 180mm use the stock disc with a Kennedy Stage 1 pressure plate if you are between 50 and 90 hp
http://vwparts.aircooled.net/180mm-Kennedy-Engineering-Racing-Pressure-Plates-p/kep180.htm |
Posted: Wed Apr 24, 2013 4:59 am Post subject: |
great... thanks all. much appreciated |
grueni Samba Member
Joined: November 03, 2008 Posts: 582 Location: Germany
Posted: Thu Apr 25, 2013 11:57 am Post subject: Re: Clutch |
avus wrote: |
pig-pen wrote: |
cheers
M |
does not work in a 36 split gearbox without changing alot with the lever arm. and this is a about 220nm clutch.
i recomand a porsche 356 180mm 9 spring. or changing the flywheel to 200 mm und use a typ1 200 std.
i had a stock dirk and a 9 spring in my superchargend 36. at the end with over 80 hp and about 170nm. i loved that pressure plate.
and hp is not what a clutch make slit its torque...and i made a stpock and new 36hp clutch and disk slit with only 0,5 bar of boost. maybe about 100-110nm.
wisches _________________ 1960 1584cc turbocharged, 35,5/32 (11,117s 1/4mile ) |
Posted: Thu Apr 25, 2013 7:38 pm Post subject: |
thats what I though... torque will kill me.
any idea where I can get a 356 9 spring? My google is turning up nothing.
M |
gimmesomeshelter Samba Member
Joined: May 08, 2004 Posts: 1468 Location: San Carlos, CA
Posted: Thu Apr 25, 2013 9:53 pm Post subject: |
The 9 spring versions show up in the classifieds from time to time.
I purchased a 6 spring pressure plate from WW several years ago, but sold it and purchased a diaphram style pressure plate instead (they're much easier on the foot).
BTW, how much stiffer is the Kennedy than a stock PP? Many years ago I installed a regular Kennedy PP on an engine. The pedal assembly was already very worn, and the heavy duty clutch sent it over the edge. I would like to avoid repeating that situation.
CHeers,
Paul _________________ "I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman |
splitpile Samba's Worst Speller
Joined: May 03, 2000 Posts: 5927 Location: back to living where hell meets the suface
Posted: Fri Apr 26, 2013 12:41 am Post subject: Re: Clutch |
pig-pen wrote: |
cheers
M |
I will have 200 mm clutch, 356/36hp (8 dowel) 6 volt ring gear new chromolly lightened flywheels available soon if after I check the one I have now to see that it fits and spins good _________________ Stocking distributor of "The Funky Green Panels"
"no more hacking my sig line" |
Mr. Motorhead Mad Scientist
Joined: January 06, 2004 Posts: 717 Location: Practitioner of 36hp alchemy
Posted: Fri Apr 26, 2013 9:36 am Post subject: |
If you can afford the upgrade to a larger clutch, sure, go for it. But it's really not needed in most cases for a mild 36hp (stroker or not) that everyone seems to be building at the moment. I base that opinion largely on what I have run so far. I've had no slippage with just the plain ol' generic 180mm clutch kit. I do balance it along with the flywheel, but other than that it's straight out of the box. With the stroker engine I ran in my bus, no problems. Anybody who saw it run can attest to the fact that it hooked up really good. Remember, a bus is a good bit heavier than a beetle. I've said it once and I'll say again, don't over think your 36hp build. You don't have to re-invent the wheel to make it work good and be reliable. _________________ 30 years experience in the sales of new and used auto parts!
36 horsepower parts for sale at http://www.aircooledresearch.com/
Or the new site at http://www.bugparts.com
Check out the Bonneville project:
http://aircooledresearch.com/docs/thebonnevilleproject.html#
"All limitations are self imposed."
Some Chinese guy |
Posted: Fri Apr 26, 2013 2:15 pm Post subject: |
lol... I am not over thinking! All I am doing is bolting on an AMR300 charger, straight onto the carb manifold, and sticking the carb on top of that....
thanks for the advice though, much appreciated. I think maybe I will just shove a stage 1 sumfink or other in there and see what happens.
toodle pip!
Martin |
JeeWee Samba Member
Joined: February 05, 2011 Posts: 120 Location: Garijp, the Netherlands
Posted: Thu Jul 19, 2018 3:25 am Post subject: Re: Clutch |
I do have a 9 spring 180mm pressure plate and a NOS clutch disk fitted, but it doesn't hold.
like the 2nd from left, 9spring type
However I bought it second hand. it looks very good but hey... it is used. Is it possible to rebuild these plates with new springs?
Or should I replace it with a 211 bus clutch and will do the job as well? Currently run 58hp at flywheel with my 1192cc 36hp WW okrasa unit but will upgrade to 1448cc with zenith NDIX. So maybe 65-70hp?
I am not a big fan of the kennedy pressure plate as I heard you need a lot of force to operate the pedal, and the wife also wants to drive the beetle.
kind regards,
Jan Willem _________________ 1192CC WW okrasa
48,2 DIN PS (58SAE HP)@4430rpm - 83Nm@3610rpm |
Robert Chambers Samba Member
Posted: Thu Jul 19, 2018 11:23 am Post subject: Re: Clutch |
How about this. From what I read about Houseman clutches, they were used in Formula Vs and early 356 engines:
https://www.thesamba.com/vw/classifieds/detail.php?id=2157872 _________________ '63 OG 117 Herbie Replica
'56 Euro Oval Deluxe
'52 Standard Zwitter
'63 OG 117 |
