bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4332 Location: United States, Iowa
flomulgator Samba Member
Joined: March 07, 2013 Posts: 950 Location: Leavenworth, WA
Posted: Mon Oct 09, 2017 11:52 am Post subject: Engine Going Cold? |
Hi all, on my way home from DoB last night my EG33 got colder and colder when cruising flat ground at a high freeway speed. At 75 mph it was down at the white bar part of the VW gauge. When I slowed down off the freeway the temp went back up. The VW guage reads from the VW temp sender, which is lodged into the reversed coolant manifold on the EG33. I have an aftermarket temp sensor with a digital readout, it was reading 166 F the whole time. The aftermarket temp sensor is inline on the hose between the manifold and the coolant bottle. The engine was full of coolant and giving off plenty of heat when I checked on it after pulling over. Thermostat is a relatively new stock Subaru unit.
I've never seen this before, any idea what might be going on?
Also, 4 of us SVX'ers were camping together at DoB! _________________ She's built like a steakhouse, but she handles like a bistro! |
Posted: Mon Oct 09, 2017 1:48 pm Post subject: Re: SVX community |
You are saying you've got a stock VW Temp 1 sensor that is correctly hooked to the stock VW cluster gauge? If yes, then here is something funny that I just remembered from my Temp 1 sensor, sounds like yours:
First couple years I had my '87, the temp always looked right on the needle gauge, and also the digital readout of the aftermarket always showed similar readout (like 170-190, depending on how I was running her). Then, slowly, over about 3 weeks, the needle just got lower and lower. Finally if lay on the bottom like a fish in winter on the bottom of the pond. The digital readout always said the normal range just like always. I had the luck to have a spare engine, and pulled the Temp 1 and stuck it in my hole, just to test. Bingo, worked exactly correctly again... The fun, of course, was the face full of coolant.
I also found the test method for the needle gauge using some Radio Shack 100 Ohm resisters, and made sure it was not the cluster FIRST.
https://www.thesamba.com/vw/forum/viewtopic.php?t=464113&highlight=temp+gauge _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch
Posted: Mon Oct 09, 2017 2:12 pm Post subject: Re: SVX community |
bobbyblack wrote: |
You are saying you've got a stock VW Temp 1 sensor that is correctly hooked to the stock VW cluster gauge? |
Yes.
bobbyblack wrote: |
...pulled the Temp 1 and stuck it in my hole, just to test.
That's some real dedication to diagnostics. So it read a stable 98.6?
What, in the end, caused the issue? _________________ She's built like a steakhouse, but she handles like a bistro! |
Posted: Mon Oct 09, 2017 2:18 pm Post subject: Re: SVX community |
Not real sure the exact cause, but have heard that sometimes Temp 1 just slowly die.
Funny on the 98.6 thing... Hadn't meant THAT hole...
But, I edited my post above with the cluster gauge test link, I really had a good time with that part. Super easy, super re-ass-uring, and like $2
reassuring .. no butt jokes .. maybe _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Mon Oct 09, 2017 3:26 pm Post subject: Re: SVX community |
flomulgator wrote: |
bobbyblack wrote: |
That's some real dedication to diagnostics. So it read a stable 98.6? :lol:
Best laugh of the day .. thanks, flom (except for the tea all over my keyboard ;^) _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
Posted: Fri Nov 17, 2017 10:33 am Post subject: Re: SVX community |
This SVX appears to have a turbo H-6. Not real sure what all comes with it, might have another donor sitting somewhere? Anyway, I don't know what to make of this one, but perhaps some in the SVX Community will be interested.
https://minneapolis.craigslist.org/hnp/cto/d/92-svx-ls-for-sale/6373738157.html
Joined: April 29, 2015 Posts: 704 Location: Berkeley Ca
Sodo Samba Member
Joined: July 06, 2007 Posts: 9517 Location: Western WA
Posted: Wed Oct 24, 2018 8:07 am Post subject: Re: SVX community |
Bobby you are like a crack dealer.... _________________
....KTMs, GasGas, SPOT mtb |
