inkysocks Samba Member
Joined: April 13, 2010 Posts: 8 Location: New Orleans, LA
Posted: Mon Jul 15, 2013 1:46 pm Post subject: |
8/3/2007 46,349 miles First GoWesty engine: 2.5 purchased $9,608.32
9/7/2007 48,849 miles Second GoWesty engine: 2.5 warranty replaced
6/16/2010 77,546 miles Third GoWesty engine: 2.4 purchased at 35% discount $5,284.80
5/7/2012 Third engine totalled after 10k miles and < 2 years. Cause: Warped case and cracked crank, bearings shot. (Also, bad piston from overheat.) |
r39o Samba Polizei
Posted: Mon Jul 15, 2013 2:10 pm Post subject: |
Inkysocks, what do you have now? _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
Posted: Mon Jul 15, 2013 2:12 pm Post subject: |
GoWesty gave me an unrebuilt donor engine, and Karmakanix slapped new heads on it. Not much power, but holds together. Likely going to sell the vehicle. |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 5772 Location: Portland OR
Posted: Mon Jul 15, 2013 2:18 pm Post subject: |
It seems so odd to me that one customer has blown three engines in a short period of time. There is a second common denominator that needs investigation here too that no one has mentioned; either the van or the driver. These things just don't "happen" for no reason.
Three vans in 18 years and I've never had an engine problem. I know many others that haven't had problems with GW engines too. I'm just saying, everything needs to be looked at closely. _________________ 89 Westy 2.1 Auto |
Posted: Mon Jul 15, 2013 2:37 pm Post subject: |
PDXWesty wrote: |
Three vans in 18 years and I've never had an engine problem. I know many others that haven't had problems with GW engines too. I'm just saying, everything needs to be looked at closely. |
I knew someone would put it either on me, or on the van. I probably would, too.
Call up or email GoWesty and ask about me, if you like. I'll email them permission to talk about my customer history, but I doubt for legal reasons they ever would. Just give me your name first.
Or maybe it's the vehicle; I could have a questionable cooling system, or an oil system. Both have been tested; they're fine.
I'm the first to admit my circumstances aren't common, but the question is how uncommon they really are. |
madspaniard Samba Member
Posted: Mon Jul 15, 2013 2:38 pm Post subject: |
PDXWesty wrote: |
It seems so odd to me that one customer has blown three engines in a short period of time. There is a second common denominator that needs investigation here too that no one has mentioned; either the van or the driver. These things just don't "happen" for no reason. |
But even GoWesty has honored warranty of these blown engines so if they don't blame driver or van why would you? They did not happen for "no reason", GoWesty gave him the reason in each case. _________________ 1991 Westy auto w/ Peloquin TBD
"The only difference between me and a madman is that I'm not mad” - Salvador Dali |
Posted: Mon Jul 15, 2013 3:17 pm Post subject: |
madspaniard wrote: |
PDXWesty wrote: |
But even GoWesty has honored warranty of these blown engines so if they don't blame driver or van why would you? They did not happen for "no reason", GoWesty gave him the reason in each case. |
Only one warranty and reason was mentioned for the first engine. The last engine was allowed to overheat voiding warranty. It's just too coincedental for me to say it's "only" the engine. What other mods have been done to the van? _________________ 89 Westy 2.1 Auto |
Posted: Mon Jul 15, 2013 4:10 pm Post subject: |
PDXWesty wrote: |
PDXWesty wrote: |
Only one warranty and reason was mentioned for the first engine. The last engine was allowed to overheat voiding warranty. It's just too coincedental for me to say it's "only" the engine. What other mods have been done to the van? |
You have a lot of faith in a company so widely panned. And you're right, they didn't just "happen"; they failed because GW has poor quality control and tries to get too much power of out of their engines, imo. Notice how many times they've changed their pistons or added oil squirters or otherwise mucked with the design. At GW, the customer is the beta tester.
The first two threw rods, as I said. The overheat on the third was because I had a coolant hose replaced by a mechanic who didn't know to jack up the front of the van to flush the coolant, and I was in a 100+ degree place where that mistake is all it takes. But that only explains a bad piston (according to *both* GoWesty and Karmakanix) for which I take full responsibility, and not the warped case, cracked crank or blown bearings, which totalled the third engine, and for which GW takes zero responsibility.
Note that my first two engines also had bad cranks and bearings too. Noticing a pattern here?
Tellingly, GW did give me a free donor engine (plus a discount on parts), and also offered half off a GW rebuilt engine (provided I replaced the *entire* cooling system). It's appreciated, but why eat crow on a technically voided warranty if you don't have to? You be the judge.
Modifications: GW 16" wheels, GW larger brakes, GW second battery kit, Bilstein shocks, GW rebuilt automatic transaxle. Everything sold and installed by GW themselves.
Actually, the most modified component on my van was what catastrophically failed three times in a row: the GW rebuilt engine. |
Posted: Mon Jul 15, 2013 4:33 pm Post subject: |
Also, when GW honored the first two warranties, they, in effect, admitted fault. Perhaps not in a legal manor, but as far as anyone should be concerned.
For the third failure, Lucas at GW could offer no causative link connecting the overheat with the cracked crank, shot bearings and warped case, despite my repeated questioning. Yet, a master mechanic -- who's rebuilt over a 1000 VW engines-- did have an explanation: GW most likely rebuilt the third engine using a warped case. Remember, all the cases are at least 20 years old!
These are pros talking here, not me. It wasn't strange mods or owner negligence or anything else.
nemobuscaptain Samba Member
Posted: Mon Jul 15, 2013 4:42 pm Post subject: |
No way (for me) to know what GW's quality control is inside their engines. A machinist could check the engines but who's going to pay $10,000 just to do that. Is their quality control poor? Or are they doing the best they can with a flawed engine design? Remember that VW factory waterboxers or rebuilds often failed by 30k also.
I can however see other examples of their quality control, such as their bodywork which commonly features the stuff on the bottom commonly used to hide poor bodywork and door jams that are left the stock color. That doesn't inspire even the slightest faith in their abilities.
These monthly reports of their engine failures don't either. _________________ Ohio Valley Tribe, Full Moon Bus Club https://www.facebook.com/groups/294422277314227/
https://www.facebook.com/groups/FullMoonBusClub |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9071 Location: Mt Lemmon, AZ
Posted: Mon Jul 15, 2013 6:58 pm Post subject: |
inkysocks wrote: |
...Tellingly, GW did give me a free donor engine (plus a discount on parts), and also offered half off a GW rebuilt engine (provided I replaced the *entire* cooling system). It's appreciated, but why eat crow on a technically voided warranty if you don't have to? You be the judge... |
Well they are pretty much in a 'no win' situation at that point. They could have sent you packing after the warranty was voided but instead made concessions which 'tellingly' imply guilt.
My GW engine has been great so I like 'em. Yeah, if it had grenaded just outside of warranty I would feel differently.
inkysocks wrote: |
...Not much power, but holds together. Likely going to sell the vehicle. |
Just a tip -- you probably don't want to list it in the Samba classifieds. |
Posted: Mon Jul 15, 2013 7:21 pm Post subject: |
Ahwahnee wrote: |
inkysocks wrote: |
You're right, being nice alone looks like guilt, I see the conundrum.
Yet if I had wrapped my van around a telephone pole, and then complained that the engine didn't work, do you think they would've given me half off of a new one? Thousands of dollars off a new engine is very nice indeed.
Anyway, three similar engine failures along with the evidence and argument provided by an experienced mechanic is enough for me to render judgment on GW, especially in the complete absence of any counter arguments from the part of GoWesty. |
16CVs  Samba Member
Joined: February 22, 2004 Posts: 3310 Location: Redwood City, California
Posted: Tue Jul 16, 2013 1:34 am Post subject: |
So mine is now apart . Aside from looking like the oil was never changed ,it all looks nice. The crank and rods wee black .
I will get a report this week . this thing looks like it was not broken in and the rings never seated and it had no maintenance done to it .
it is an interesting combo how they get the increased displacement .
I hope it works out ,If not I'll build another DJ like my Tristar . _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
Jedi Samba Member
Joined: October 23, 2007 Posts: 731 Location: Cool California
Posted: Tue Jul 16, 2013 8:44 am Post subject: |
I love my GoWesty 2.2L Has been running great for years.  _________________ 1961 Westfalia SO34 T/BW
1961 Westfalia SO34 SWR
1964 Westfalia SO33 pearl white
1965 Westfalia SO42 Velvet green
1986 Syncro Wolfram grey with black int GL
1986 Syncro Doka
1987 Syncro Sevana beige Adventurewagen
1987 syncro Sevana beige GL
1973 Pumpkin orange Thing
2 1963 Rag top bug's
1965 Manx
1970 Single cab
1971 combi
1990 Vanagon GL
2007 Audi A4 3.2L quattro |
r39o Samba Polizei
Posted: Tue Jul 16, 2013 9:06 am Post subject: |
Anybody else see a trend here?
Earlier, years ago, the motors were better?
I can readily understand why the later engines are having issues, simply because the parts in the supply chain seem not to be that great theses days.
I have had Type I'V stroker cranks fail.
Valves snap off.
Face it, keeping these old beasts running is a challenge.
Add to the mix that hot rod engines are tricky to keep alive and you just have a poor mix. _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
insyncro Banned
Joined: March 07, 2002 Posts: 15087 Location: New York
Posted: Tue Jul 16, 2013 9:12 am Post subject: |
Jedi wrote: |
I love my GoWesty 2.2L Has been running great for years.  |
Thank you for sharing.
The 2.2 is going to be the most reliable of all displacements currently available from the various top rebuilders.
That is my opinion,
based on owning multiple Boston Bob motors, installing a Vanistan and maintaining a few others, including a GW 2.2.
Very smooth.
The power increase of the 2.2 is perfect to offset mounting 215/75/15 offroad tires on a Syncro with 4.86R&P |
tiicosyncro Samba Member
Posted: Tue Jul 16, 2013 9:44 am Post subject: |
insyncro wrote: |
Jedi wrote: |
I agree here, with this design anything above 2300 is pushing it, If you want big power your money is better spent on another conversion of some sort. In Jan. 2006 a 2300 GW motor was installed in a van I have and it was just given the once over and everything still looks good, great compression on all cyls. From reading many posts on GW engines the turning point seems to be 2007 where things took a detour? Those with engines before then seem to be doing good. I can tell you I have a stack of reciepts dealing with coolant issues prior to the engine being installed. So if that entire system has not been gone thru and checked/replaced at the time of install, your asking for trouble IMHO |
ThankYouJerry Samba Member
Joined: September 01, 2012 Posts: 2271 Location: Shakedown Street
Posted: Sat Jan 18, 2014 10:00 pm Post subject: |
Having read several threads, seems like GW 2.2s are the "best of what they do".
What are the BIG differences between a GoWesty 2.2 and a Vanistan 2.2 besides the fact that Vanistan only uses 2.1 blocks (instead of GW's 1.9s) to create 2.2s?
Is there a considerable performance/reliability difference?
What about warrantees/customer service? _________________ 1990 Multivan - "Ohana"
1.8T, Auto w/3.27 R&P + Peloquin TBD |
jberger Samba Member
Posted: Sat Jan 18, 2014 10:09 pm Post subject: |
ThankYouJerry wrote: |
What about warrantees/customer service? |
No contest... The vanistan 2.2 formula is different than the gw of the same displacement. I have posted before of the high compression 2.2 delivering more performance than even the gw 2.3. This comparison is offered through experience. |
Posted: Sat Jan 18, 2014 10:20 pm Post subject: |
Exactly what I wanted to know. Thanks. _________________ 1990 Multivan - "Ohana"
