77 will not start after being pulled into garage
duster73
duster73 is offline
PostPosted: Wed Apr 24, 2013 11:58 am    Post subject: 77 will not start after being pulled into garage Reply with quote
help, I have been working on my westy now and then, It starts up after 3 turn overs always. I recently pulled it out of my garage, worked on it and put it away, well today i went out to start and it just turns over. my van has been running great for a year with never having this problem. The only thing I could remotly see is that i was manipulating wires by fuse box to replace my HI/LOW beam relay, but it did not need replaced just jiggled it. My van started after i did that but the next day it did not start. Ive checked the coil connections and rolled all the fuses, it has fuel in it. Im stumped, can anyone tell me what simple thing im overlooking.
dugfresh
dugfresh is offline
PostPosted: Wed Apr 24, 2013 12:10 pm    Post subject: Reply with quote
I'd check I've your fuses one by one.. Clean confections... Look for any wires that could have popped loose
78 Riviera
http://flic.kr/s/aHsjDRJPa1
ncstagger
ncstagger is offline
PostPosted: Wed Apr 24, 2013 12:16 pm    Post subject: Reply with quote
Are u getting gas in the carb when throttle is pumped?
Do you have spark at the plugs?
What year/engine is your bus?
71 Westy Tintop - 1600 DP 34PICT3/009 - Pastel White
Resto thread here: http://www.thesamba.com/vw/forum/viewtopic.php?t=549162
"Take your most realistic time frame and dollar amount.. then add half of that amount. When you get that total... double it. Only then will you be in the ballpark." - sofaking
Randy in Maine
Randy in Maine is offline
PostPosted: Wed Apr 24, 2013 12:22 pm    Post subject: Reply with quote
I would start by having a pretty good look at the battery connections to the ground and to the starter and make those 100% clean and tight. Then go over and have a look at the chasiss ground strap and make that 100% also.
You might as weklll start there since it is easy and free to do. Stick your volt ohm meter on the battery and see if it has adequate voltage in it.
Report back if that doesn't work and we will tell you how to jump the solenoid to test it.
Stuartzickefoose
Samba Post Whore
Stuartzickefoose is offline
PostPosted: Wed Apr 24, 2013 12:52 pm    Post subject: Reply with quote
spin the fuses to create a clean contact area for the fuses to connect to. then wiggle all your wires again on the back. there should be a fat red wire, possibly with a black stripe, that connects to the back of the fuse block. if that wire has a loose connection, it wont get power where it needs to go.
if you take the center wire off the distributor cap, and hold it above a ground about a 1/16th of an inch and crank start it, does the wire spark? if so, what color? if not, is there power to the positive side of the coil with the key on? (terminal 15)
Stuart Zickefoose
206-841-7324
[email protected]
SGKent Premium Member
SGKent is offline
PostPosted: Wed Apr 24, 2013 1:04 pm    Post subject: Reply with quote
3 things are needed. Check each.
“Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin
Wildthings
Wildthings is offline
PostPosted: Wed Apr 24, 2013 1:44 pm    Post subject: Reply with quote
Your ignition and FI circuits are unfused so you shouldn't need to be worrying about your fuses. The power to the coil and the trigger for the FI does run through the box, but not through a fuse.
Check to see if you have power to the coil when the ignition is on and get back to us.
Stuartzickefoose
Samba Post Whore
PostPosted: Wed Apr 24, 2013 1:49 pm    Post subject: Reply with quote
i was pretty sure there is a fuse up front for either the starter or the ignition...Confused
Stuart Zickefoose
206-841-7324
[email protected]
Wildthings
PostPosted: Wed Apr 24, 2013 2:19 pm    Post subject: Reply with quote
Here is the wiring diagram, the route of the #15 circuit is kind of Rube Goldbergish (thanks VW) but you will find no fuse between the ignition switch and the double relay. There is also no fuse in the #50 circuit to the starter, nor in the main power supply to the double relay.
Click twice to enlarge
Stuartzickefoose
Samba Post Whore
PostPosted: Wed Apr 24, 2013 2:57 pm    Post subject: Reply with quote
got it. Thanks Smile
Stuart Zickefoose
206-841-7324
[email protected]
