HappyHippie Samba Member
Joined: March 18, 2009 Posts: 14 Location: Orange, CA
Posted: Wed Apr 24, 2013 7:10 pm Post subject: 72 VW bus exhaust manifold questions. |
OK so first off no idea if I loaded the images right?
so I have been fixing the exhaust one piece at a time and now I'm looking to fix the last piece.
obviously I need new ones of these? I believe they are the manifolds...
where do I get them I can't seem to find new parts just old ones that look almost as bad as mine....any suggestions?
also don't see how it will help to get new ones unless I cap or do something with the giant hole at the end that looks like it should connect up a little farther towards the front of the bus (part of the heater maybe? witch is caped inside the bus but I live in So-Cal I don't need it anyway) whats the best way to take care of that?
Thanks any help would be awesome! [/img] |
Posted: Wed Apr 24, 2013 8:49 pm Post subject: |
If the pipes inside are in good condition you can just strip the outer shell off and run without it or better you can get a set of heat exchangers off of a 411/412 and use those, with or without the cover intact, which basically leaves you with the Type 4 equivalent of Type 1 "J" pipes. |
Posted: Wed Apr 24, 2013 8:50 pm Post subject: |
there are pipes inside?
Posted: Wed Apr 24, 2013 8:52 pm Post subject: |
maybe i should take it apart and look at it. |
Posted: Wed Apr 24, 2013 8:56 pm Post subject: |
Yes the exhaust header pipes are inside. On a bus they are covered the the fins for the heat exchangers, but on the 411/412 ones there are just plain Jane pipes inside.
The inner pipes will usually be in the worst condition right at the flange where the heat exchangers bolt to the muffler. No holes or serious erosion there and you are probably good to go. |
SGKent Samba Member
Posted: Wed Apr 24, 2013 8:57 pm Post subject: |
you can have a local welder weld some sheet metal patches over those areas and patch them up until you can find local new ones. The outside is just a shell that holds the air from escaping. Don't take them apart. Besides summer is coming and you won't need heat again until winter. Do get the valves that go on the end though as they help control how much air passes thru and you don't want to overheat your engine. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Wed Apr 24, 2013 9:52 pm Post subject: |
https://www.thesamba.com/vw/gallery/pix/1053802.jpg
OK so if I understand correctly there is a valve that gos on the end shown here...dose the valve let the air in or out?
dose anyone know the name of the valve?
And just to clarify my pics this in not the hole where the header attaches its the other end that is closet to the front of the bus. |
Posted: Wed Apr 24, 2013 10:05 pm Post subject: |
HappyHippie wrote: |
That is where the booster fan was plumbed into the heater box. Closing the holes off may make a bit of difference in how hot the engine runs, but probably not much. What you do want to do is close off the hole in the cylinder surround tin above them, as the holes in the cylinder tin make a big difference in how hot the engine runs. |
