vaughn bros. Samba Member
Joined: October 13, 2003 Posts: 2395 Location: Hickory, NC
Posted: Wed Sep 25, 2019 11:18 pm Post subject: Re: Vaughn Bros Fenderless Bug Build |
Joined: August 31, 2013 Posts: 12861 Location: North Carolina
Posted: Thu Sep 26, 2019 6:38 am Post subject: Re: Vaughn Bros Fenderless Bug Build |
Before you get too much further, it looks like you need to go for some of those MG triple wiper arms to get enough sweep to clear the windshield. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11056 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Thu Sep 26, 2019 6:55 am Post subject: Re: Vaughn Bros Fenderless Bug Build |
Rain X...
Volksrods don't need no stinkin wipers. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
Posted: Sat Sep 28, 2019 9:50 am Post subject: Re: Vaughn Bros Fenderless Bug Build |
VOLKSWAGNUT wrote: |
Rain X...
Volksrods don't need no stinkin wipers. |
So, what yall are saying is, this is shaping up to a cool narrowed 40 Ford dash.
Posted: Sun Sep 29, 2019 6:30 am Post subject: Re: Vaughn Bros Fenderless Bug Build |
Posted: Sun Sep 29, 2019 6:50 am Post subject: Re: Vaughn Bros Fenderless Bug Build |
vaughn bros. wrote: |
Yep....
If had your skills ... I would have went 49 Merc inspired dash on Op X.. but Im biased and have all the parts ..
BTW who are you using to cut your glass?... my local cutter has laid down on me..
She's had my good used windshield for a month .. and I missed my planned Dub Day despider webbing run
Posted: Mon Sep 30, 2019 10:50 am Post subject: Re: Vaughn Bros Fenderless Bug Build |
Yep....
Haven't decided 100% on glass yet. A local place called Allglass in town claims they can cut and edge polish flat laminate.
Posted: Wed Oct 02, 2019 4:27 pm Post subject: Re: Vaughn Bros Fenderless Bug Build |
Stink bug...yeah..that time of year.
Good luck...I'd recommend my glass gal...but she just broke #2 replacement windshield for Op X.
But ..in her defense done. ..its not flat glass.
She said it was fine until it cooled down from the laminate melt and sanding.
From a family of local glass cutters..who has served our family well over 40 years both in rental and auto Kustom stuff its hard to really be mad about it..
I have one more used ..but..
....its getting expensive.. and frustrating..
Posted: Thu Oct 03, 2019 10:56 am Post subject: Re: Vaughn Bros Fenderless Bug Build |
Back and forth, over and over, bondo and sand.
Gauge pods next.
Posted: Fri Oct 04, 2019 6:19 pm Post subject: Re: Vaughn Bros Fenderless Bug Build |
Front fuel lines ready to layout. Being aware of dissimilar metals reacting, it's just a layout.
Last edited by vaughn bros. on Tue Oct 08, 2019 10:34 pm; edited 1 time in total |
Posted: Sat Oct 05, 2019 12:09 am Post subject: Re: Vaughn Bros Fenderless Bug Build |
Just on a side note, your fenderless Bug having a corvair engine and all that applies, is wild as hell. It touches off on early hot rod history, Chevrolet, all kinds of stuff. Glad your out there. |
Posted: Sat Oct 05, 2019 12:24 pm Post subject: Re: Vaughn Bros Fenderless Bug Build |
Well I'm certainly appreciative of the nice words.. ..and nudge of encouragement,..
That whole cross over old school red headed step child American GM flat 6 to hot rod powered VW was my whole love for hacking it together.... as I noted in the build .. it was like it was meant for me as a lifer GM tech.. to do..
I just wish I had your metal mending work skills.. : .. it would have turned out much more refined.. ...
Windshield #3 now at the hands of das butcher . all . .well most appendages crossed.
... _________________ aka Ken {o\!/o}
Posted: Sun Oct 06, 2019 12:38 pm Post subject: Re: Vaughn Bros Fenderless Bug Build |
Fuel line is 5/16" OD. From front bulkhead to frame horn.
Posted: Sun Oct 06, 2019 12:42 pm Post subject: Re: Vaughn Bros Fenderless Bug Build |
Last look at Brake Pedal Stop before being dolly'd up and called pretty.
Posted: Fri Oct 11, 2019 7:07 am Post subject: Re: Vaughn Bros Fenderless Bug Build |
Brushed, painted.
Posted: Fri Oct 18, 2019 6:47 am Post subject: Re: Vaughn Bros Fenderless Bug Build |
Now all aluminum, as much as possible, no stainless steel aluminum mix. From tank to rear horns. 100 micron before pump hopefully.
Posted: Sat Oct 19, 2019 4:45 pm Post subject: Re: Vaughn Bros Fenderless Bug Build |
3 fiberglass gauge pods coming soon.
Posted: Mon Oct 21, 2019 1:34 pm Post subject: Re: Vaughn Bros Fenderless Bug Build |
nbturbo Samba Member
Joined: August 26, 2004 Posts: 184 Location: Australia
Posted: Mon Oct 21, 2019 8:01 pm Post subject: Re: Vaughn Bros Fenderless Bug Build |
Brushed, painted.
My floor pan is still away with the body,but you have inspired me to change the brake pedal/master cylinder set up.I got a booster and cylinder from a Mazda 3 to adapt.I will put it all under where the fuel tank would normally sit. At right angle to pedal movement like yours.I will make a new fuel tank to fit low in the tray.I may be able to use the 22mm VW master cylinder as well.Keep the pics coming. |
Posted: Tue Oct 22, 2019 8:49 am Post subject: Re: Vaughn Bros Fenderless Bug Build |
Brushed, painted.
Be aware ours might be flawed 😀
