levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Posted: Fri Apr 26, 2013 9:37 pm Post subject: harmful to 2WD diff to run offsized diameter tires? |
And by offsize I mean more than a 2" difference in diameter in the rear.
I have 28" all around, and picked up a rear flat.
Spare 28" was also flat.
Only thing available was a stock sized 25.65, almost 2.5 over.
Not sure if that would be okay with the diff so I went through the process of switching out front and rear.
But I'm wondering, would that cause damage? _________________ One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40 |
Love My Westy Samba Member
Posted: Fri Apr 26, 2013 10:07 pm Post subject: |
Isn't that what a differential is all about, to allow the two sides to spin at different speeds? Kind of like turning in a circle. I don't think there should be any problem. I'm not a mechanic, but a 2WD Vanagon doesn't have a VC or a locking differential. What happens when you loose traction and one wheel spins? I don't think there is any harm to the differential, again, that's what it is designed to do. I don't know what would happen with a limited slip differential. |
Syncromikey Samba Member
Joined: September 19, 2012 Posts: 463 Location: Calgary, Alberta, Canada
Posted: Sat Apr 27, 2013 5:25 am Post subject: |
Yup the diff is made to adjust the speed of the tires when turning corners which is a short period of time and is typically a small around of change. Here you're looking at 10 percent over a constant time. The diff isn't meant to handle that. If you're just running it for a very short period to get you to a place to fix a flat then ok but if you are thinking about running it for extended periods I would definitely NOT do it. Personally I wouldn't even put a warn tire on one side and a new one on the other and run it constantly. This is just talking about issues regarding the diff. There are safety and control concerns when running different sized tires as well. It's your call but I wouldn't do it.
Mike _________________ Love my Westy ...
My build: http://www.thesamba.com/vw/forum/viewtopic.php?t=528954 |
rubbachicken Samba Member
Posted: Sat Apr 27, 2013 5:26 am Post subject: |
short term it should be OK, but you should change it ASAP _________________ lucy our westy
lucy's BIG adventure
meet 'burni'
619 201 0310 or 617 935 4182 |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
dobryan Samba Member
Joined: March 24, 2006 Posts: 16508 Location: Brookeville, MD
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10252 Location: N. Idaho
Posted: Sat Apr 27, 2013 7:54 am Post subject: |
Switch it out for safety whenever you can, but X3 it was right to move it to the front vs heat stress on the rear differential.
DougM _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
Crankey Samba Member
Posted: Sat Apr 27, 2013 2:48 pm Post subject: |
I'd go to my nearest convenience store and get a can of fix-a-flat and then straight to the tire store for a proper fix.
seems like a lot easier than changing wheels around and risking damage |
levi Samba Member
Posted: Sat Apr 27, 2013 9:17 pm Post subject: |
Thanks guys,I know nothing about this part of the van, so I appreciate all the thoughts on this.
By the way, fixing the flat was not an option, since it was in the sidewall.
End of that tire, which was too bad since it was only about 3 months old. _________________ One of these days I'm gonna settle down,
