Engine Build - 54
txoval
txoval is offline
PostPosted: Mon Apr 29, 2013 7:12 pm    Post subject: Reply with quote
Yes, the front beam is narrowed 4" w/ adjusters...
If I did it again, I'd install a 3" narrowed beam
txoval
txoval is offline
PostPosted: Wed May 01, 2013 6:22 pm    Post subject: Reply with quote
UPDATE:
Like a big idiot I must have bent/kinked a rod bearing...#2 rod will not seat properly. A big thanks to my buddy at Aircooled Research for sending me another rod to verify that the rod was ok. Crank journal is dead nuts, I just need to be more careful when cleaning the bearing before installing it on the rod.
Below is a project I've been working on for awhile, and I was going to wait until the end caps came in, but here they are...solid rocker shafts
I milled the ends of the original rocker shafts, tapped them, and then polished the shaft. The solid spacer is made of 9Chrome alloy and shims are hardened (shims). It was a bit of a learning experience and I actually went thru 4 shafts. I'm happy with the end result, hopefully they will work great.
PANZERVW
PANZERVW is offline
PostPosted: Fri May 03, 2013 1:20 am    Post subject: Reply with quote
txoval wrote:
Engine Specs:
Standard Bore and Stroke
DPR CW Crank with 14lb flywheel
Aircooled Research Stage 2 Cam with straight cut gears
Ported/Polished stock heads (33mm Intake and 30mm exhaust)
Full Flow, with 1.5 qt sump
Speedwell Blower w/ 31 pict 1 carb
header with baffled stinger
More pictures to follow
How much HP will this set up yield once its finished?
Also this so far is a great vintage speed run. Very Happy
txoval
txoval is offline
PostPosted: Fri May 03, 2013 2:23 pm    Post subject: Reply with quote
I really wish I could answer your question...I think the torque increase will be the most noticeable difference
I have been told is should react as good or better than a 1600DP. I'm hoping the torque will be better than that...
54ovsemi
54ovsemi is offline
PostPosted: Sat May 04, 2013 11:54 am    Post subject: Reply with quote
Looking really good txoval!! Keep the pics coming, check your PM box.
txoval
txoval is offline
PostPosted: Sun May 05, 2013 5:15 am    Post subject: Reply with quote
UPDATE:
Case halves together,waiting on pistons/cylinders and heads
HUBCAP DEBATE: Let me know what you think
RareAir
RareAir is offline
PostPosted: Sun May 05, 2013 7:45 am    Post subject: Reply with quote
txoval wrote:
UPDATE:
What's the Aluminum spacer for on the oil plate area?
1947 Typ 11a
1954 Typ 117
1955 356A
1956 Typ 151
1959 Typ 117
1961 356B
1966 Typ 151
1966 Typ 241
Kjell Roar
Kjell Roar is offline
PostPosted: Sun May 05, 2013 11:01 am    Post subject: Reply with quote
RareAir wrote:
txoval wrote:
UPDATE:
For a deep sump.
I got a historic car, every scratch got a history...
My car, Aug. 4th, 1955 / an early 56: http://www.thesamba.com/vw/forum/album_page.php?pic_id=610438
RichardinNZ
RichardinNZ is offline
PostPosted: Sun May 05, 2013 6:52 pm    Post subject: Reply with quote
I like the caps, but would also look good with no caps or with chrome caps! It'd be good to see how it looks once you have all the body trim on.
My caps are chrome with stainless 'hot rod' trim rings...also on black wheels....but my car isn't anything like as clean as yours!
Richard
Richard
'58 Beetle; NZ Assembled
Dual Carb 36hp
View user's profile Send private message AIM Address Instagram Gallery Classifieds Feedback
txoval
txoval is offline
PostPosted: Thu May 09, 2013 6:18 pm    Post subject: Reply with quote
Just a few notes...
When checking the clearance from the cam bolts to the oil pump, I was out of tolerance (.060") and had to grind a bit on the oil pump housing
The sump plate adapter hit the "humps" on the bottom of case where the case bolts are on each side of the adapter...had to grind them down.
Just items you should check before you getto the stage I'm at...it stinks having to take stuff apart to clean again. Lesson learned
txoval
txoval is offline
PostPosted: Fri May 10, 2013 7:55 pm    Post subject: Reply with quote
Ordered the supercharger!, I'll take some pics once it arrives
One day my heads will be done and I'll start this dang thing!
Slow progress until then
henry roberts
henry roberts is offline
PostPosted: Sat May 11, 2013 1:18 am    Post subject: Reply with quote
loving this thread. i hope your heads turn up soon.
personally i don't really understand the all black wheel look, but have you considered something like these to give a little more definition if you run hubcaps?
txoval
txoval is offline
PostPosted: Sat May 11, 2013 4:20 am    Post subject: Reply with quote
I'd love to try those...where can you find them?
I was thinking of adding a white "pin stripe" around the perimeter of the rim...but these may work better
txoval
txoval is offline
PostPosted: Sat May 11, 2013 6:02 pm    Post subject: Reply with quote
1.5 Qt Sump installed
First, Scat's sumps are extremely nice, but if anyone is going to install a sump on a 36HP please contact me. This way you can learn from my mistakes.
Scrapping off Gorilla Snot is a major pain in the butt. The studs on the adapter do not work with Scat sumps because the clearance between the holes and sidewall. 6mm nuts are too big, which is why Scat supplies (nice) hex head screws. Unfortunately, they are a major pain to install in such a tight space. I had to modify an allen wrench (dramatically) to make this work
54ovsemi
54ovsemi is offline
PostPosted: Thu May 16, 2013 4:51 pm    Post subject: Reply with quote
Nice!!!
PANZERVW
PANZERVW is offline
PostPosted: Fri May 17, 2013 8:30 pm    Post subject: Reply with quote
Gene Berg Has A 36HP sump that looks old school but that scat one looks Shiny...
The oil pump is it stock or an aftermarket?
Been searching all the site for one that would improve the flow on the 36HP.
Not going full flow like you since I'm going with a dual carb set up and one of those Fram Oil Canister set ups with the oil coil cooler behind the Fan housing.
txoval
txoval is offline
PostPosted: Sat May 18, 2013 5:55 am    Post subject: Reply with quote
The Scat sump is really top notch...
The oil pump is a 6mm stud with 26mm gears
Look up Steve-o, Central Texas Autoworks
I'm sure there are other sources though
PANZERVW
PANZERVW is offline
PostPosted: Sun May 19, 2013 11:01 pm    Post subject: Reply with quote
Great build eagerly await your post. Smile
txoval
txoval is offline
PostPosted: Mon May 27, 2013 10:01 am    Post subject: Reply with quote
UPDATE:
Supercharger on hand, had to make modifications to the Carb Linkage since I'm using a 30 Pict 1 carb in lieu of the 28 PCI carb the kit is designed for.
Quality is excellent, instructions could be better, but Ray has responded to my questions.
One note, the Main Jet does not come with the kit...there is also a ton of hardware, the belts, etc that I did not take a picture of. The kit really does come complete, and if you run the 28PCI carb, it would be a very simple add on
Heads should be done by the end of this week...supposedly
tatersgravy
tatersgravy is offline
PostPosted: Mon May 27, 2013 10:51 am    Post subject: Reply with quote
Like the hub caps but, I think it might also look nice if you went with just a bit lighter color of black instead of the white "VW" maybe even a dark gray color.
Page 2 of 4
