Engine Build - 54
gimmesomeshelter
gimmesomeshelter is offline
PostPosted: Mon May 27, 2013 3:12 pm    Post subject: Reply with quote
Nice supercharger!
BTW, do know how big of an engine it will support?
Cheers,
Paul
My dog's vet has all my car money (http://sagecenters.com/)
txoval
txoval is offline
PostPosted: Thu May 30, 2013 8:05 pm    Post subject: Reply with quote
Unfortunately I have no idea what size engine it would support (over 1200cc)
I can try asking Ray at Speedwell
txoval
txoval is offline
PostPosted: Mon Jun 03, 2013 5:39 pm    Post subject: Reply with quote
Quick question:
If you've read through my post you know my setup, but a few questions
1) would an 1-3/8" merged header (from CB Performance) be okay?
2) I'm running a 30 pict 1 carb instead of the stock 28pci, I've bought 120, 125, and 127 main jets...I'm thinking about starting with the 127, thoughts?
cedricv
cedricv is offline
PostPosted: Wed Jun 05, 2013 1:54 am    Post subject: Reply with quote
Ray told me don't go over 1200cc for the charger...nice bild!
thomas.
thomas. is offline
PostPosted: Wed Jun 05, 2013 5:01 pm    Post subject: Reply with quote
The judson supercharger uses a 135 jet. Although that is for a 28pict carb .127 jet might be too lean and you could smoke a valve. Cheaper to try bigger 1st.
txoval
txoval is offline
PostPosted: Wed Jun 05, 2013 5:46 pm    Post subject: Reply with quote
The Speedwell SuperCharger instructions recommend a 125...for the 28PCI
I'll go ahead and buy a few more jets
txoval
txoval is offline
PostPosted: Sun Aug 25, 2013 7:47 pm    Post subject: Reply with quote
My heads and pistons (Thank you Mr. Motorhead) came in and the long block is almost complete...just need new valve adjusters.
Heads came out perfect, a set of NOS 36hp heads, 43cc chambers, 33mm intakes, 3 angle valve job, port and polish, exhaust ports are beautiful for boost
Ended up with a .050" deck height for a little over 7:1 compression
Mr. Motorhead balanced the pistons for me, all exactly 300 grams
Fitted up the merged header, major pain in the ass, but in the end worth it. Going to ceramic coat tomorrow.
I'll get some pics up shortly
RichardinNZ
RichardinNZ is offline
PostPosted: Mon Aug 26, 2013 11:13 pm    Post subject: Reply with quote
What merged header did you use in the end?
Thanks
Richard
Richard
'58 Beetle; NZ Assembled
Dual Carb 36hp
View user's profile Send private message AIM Address Instagram Gallery Classifieds Feedback
txoval
txoval is offline
PostPosted: Tue Aug 27, 2013 4:19 am    Post subject: Reply with quote
1-3/8" merged header from AJ Sims (lowbugget.com)
The tubes (4 loose pieces which attach to heads) needed to be trimmed for width, which was expected.
The bolt holes on the flanges had to be drilled a few sizes larger, once again expected due to the slight difference in bolt pattern.
The pain was having to cut the flanges off the rear j-tube pieces...which had to be rotated and re welded.
Luckily I'm a welder by hobby, so it was easy, but unexpected. Of course this is why I ordered the header raw, I knew there would be modifications. It's now off to the ceramic coater
Overall I'm happy though, $140 for the header and now I have a wide assortment of mufflers to choose from.
This is one area where Vintage Speed stinks...muffler choices are slim and they cost big $$$
Once I get the header back, I'll post pics
RichardinNZ
PostPosted: Wed Aug 28, 2013 12:51 am    Post subject: Reply with quote
Thanks; be good to see some pics.
Richard
Richard
Dual Carb 36hp
txoval
txoval is offline
PostPosted: Sun Sep 22, 2013 6:38 am    Post subject: Reply with quote
Updated pictures...supercharger is just sitting there for mock up.
Getting close to startup, hopefully next weekend.
The stinger is also loose, please ignore it being a little crooked
RareAir
RareAir is offline
PostPosted: Sun Sep 22, 2013 8:08 am    Post subject: Reply with quote
Is there room for an air cleaner?
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1961 356B
1966 Typ 151
1966 Typ 241
John Moxon Premium Member
John Moxon is offline
PostPosted: Sun Sep 22, 2013 8:29 am    Post subject: Reply with quote
Don't think I've ever seen a Pepco with an aircleaner....certainly not with a downdraft carb.
John.
Judson Information on The Samba
Superior "Supercharged by Judson" badges
Flying Scotsman & '58 Karmann Ghia Wall Poster
Steven G.
Steven G. is offline
PostPosted: Sun Sep 22, 2013 8:33 am    Post subject: Reply with quote
too cool!!!! Cool
~Steven G.~
1954 117 Deluxe Sunroof
•Click Here→ My 1954 Ragtop Deluxe Build Thread
•Click Here→ My Okrasa TSV 1300 Build Thread
txoval
txoval is offline
PostPosted: Sun Sep 22, 2013 11:53 am    Post subject: Reply with quote
Air cleaner is basically window screen and a hose clamp
I've worked awhile on building one, but it's too tight
Even with the carb spacer it's shorter than the stock 28PCI would be.
The spacer is tapped for methanol injection, but currently have a plug in the port.
Fan shroud is a stock 36 hp, I just filled in the coil mount holes for a cleaner look. I also modified the oil filler cap, I have the stock 54 still in original form, but took a later 36hp unit and modified it to accept the breather line.
The 009 dizzy will be replaced with a 019 soon. Need to finish interior first...
thomas.
thomas. is offline
PostPosted: Sun Sep 22, 2013 5:08 pm    Post subject: Reply with quote
I've seen this low profile one used before but with your carb spacer would be tight. Awesome bug BTW.
RichardinNZ
PostPosted: Sun Sep 22, 2013 9:40 pm    Post subject: Reply with quote
Engine and car are both looking good!
Richard
Richard
Dual Carb 36hp
txoval
txoval is offline
PostPosted: Sat Sep 28, 2013 6:55 am    Post subject: header and full flow installed Reply with quote
Pictures from beneath showing the merged header installation and full flow setup
txoval
txoval is offline
PostPosted: Sat Oct 12, 2013 1:21 pm    Post subject: Straight cut Cam gears Reply with quote
Well, blower plus straight cut cam gears equals one loud ass engine.
I hate to say it, but I'm almost regretting the cam gears. They are Louder than the blower, hopefully after a few hundred miles they quiet down.
Looking forward to switching from my 009 to a 019 from Glenn, but the engine runs well currently. No oil leaks.
Time to finish the interior!
RichardinNZ
PostPosted: Sat Oct 12, 2013 10:23 pm    Post subject: Reply with quote
That merged header looks good and sits nicely on the car. Hope you either get used to the sound or it gets a bit quieter. However it is still a small price to pay for such a cool engine!
Richard
Richard
Dual Carb 36hp
Page 3 of 4
