stevespeirs Samba Member
Joined: June 10, 2008 Posts: 310 Location: Virginia Beach, VA
Posted: Sat Apr 27, 2013 8:23 am Post subject: Fuel pump push rod length? |
Have had problems with no fuel getting to the carb. Bus starts if I pour a capful of gas into the throat of the carb, but otherwise, it justs turn over without starting.
Figured it could be a fuel pump issue, so just removed the pump and measured the push rod. Looks like it's a fraction under 100mm.
Any way to test the pump (it's an Airtex 1109 installed by the PO)? Think it could be time for a new push rod?
I have a fuel line kit on its way from Scott at German Supply - figured it was a good time to replace all the old fuel lines and get the pump thing sorted at the same time.
First time messing with the fuel lines, so a bit apprehensive to be honest. Thanks in advance for the advice. _________________ 1979 Microbus |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51155 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Apr 27, 2013 8:35 am Post subject: |
Nothing wrong with that, 4" is correct for an alternator pump like you have.
Try disconnecting the line to the carb and pumping into a bottle while cranking, sometimes the needle and seat in the carb will stick in the closed position and act like a bad pump. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
germansupplyscott Samba Member
Posted: Sat Apr 27, 2013 8:36 am Post subject: |
it looks right in the photo, the pump seems to be the alternator type (i am judging by the angle that pump is tilted off vertical, alternator pump is more tilted than generator pump) and the pushrod is 4" which is a match to that pump. _________________ SL |
Posted: Sat Apr 27, 2013 8:39 am Post subject: |
Thanks busdaddy/Scott. Probably should have tried the pumping into a bottle before pulling the pump. I'll give that a go and see what happens. _________________ 1979 Microbus |
Posted: Sat Apr 27, 2013 8:47 am Post subject: |
i had an issue not long ago where i had a pump that seemed to work by hand, PR was correct length, everything seemed fine, but on the car the pump didn't pump. i farted around with it for hours and finally gave up and put a different pump on the engine. this was an engine that was super original so i really wanted the original pump on there instead of something newer style. i never figured out the issue. what i am saying is sometimes everything with the pumps will seem OK and yet they do not work on the engine. _________________ SL |
Posted: Sun Apr 28, 2013 5:14 pm Post subject: |
Spent the afternoon removing the old fuel lines and draining the tank.
Guess I should have checked the fuel lines before second guessing the fuel pump. What a mess! Can't wait to receive & install Scott's fuel line kit. Need to order a new copper tank fuel filter/sock by the looks of things too...
From what I can tell, inside the tank doesn't look *too* bad. Any tips on flushing through any remaining gunk before installing all the new stuff?
Feels SO good to be getting this done. Thanks as always for the support and advice. _________________ 1979 Microbus |
Posted: Sun Apr 28, 2013 5:32 pm Post subject: |
I hope those are all "before" pictures, yuk, looks like time well spent to deal with that mess.
You can flush with a gallon of gas, put a coffee filter in the funnel when you recover it so you can repeat as necessary. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Apr 28, 2013 5:38 pm Post subject: |
Great idea with the coffee filter, busdaddy. Job for tomorrow after work... _________________ 1979 Microbus |
Posted: Sun Apr 28, 2013 5:44 pm Post subject: |
stevespeirs wrote: |
. Job for tomorrow after work... |
Do invest a few minutes Googling plastic funnels/gascans and static electricity just to get a handle on the potential risks, better safe than sorry, fires are no fun unless you are camping _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu May 09, 2013 11:24 am Post subject: |
Time for an update...
Well, the new fuel hose arrived from germansupply.com and was pretty easy to install, even for a novice like myself.
Also fitted a new screen/sock inside the tank after flushing it through a couple of times per busdaddy's suggestion, and changed the oil as it was definitely overdue.
Tried starting her up, but the engine would just turn over and not catch. The only way I could get it started was the pour a capful of gas down the carb throat trick. Not ideal, but I knew I was getting closer.
Found this thread about the idle adjust on a 34 PICT-3 --
http://www.thesamba.com/vw/forum/viewtopic.php?t=56411
and discovered the idle jet was blocked. Still wouldn't start after blowing through the jet with air, so after more research went through the automatic choke adjustment procedure on Rob and Dave’s Aircooled Volkswagen Pages --
http://www.vw-resource.com/choke2.html
With the choke refitted and screwed in place, I turned the key and she fired right up. Idled for quite a while too. Couldn't believe it really.
So, what's next? Make sure the timing is spot on? Like I keep saying, I'm a total novice with regards to this stuff, but feel like I have a fair grasp of what's going on after lots of reading and searching online.
My current setup -- 231 178 009 distributor with compufire ignition module and a Bocar 34 PICT-3 which I realize is probably not ideal. As ever, thanks everyone for getting me this far, any advice/comments will be greatly appreciated. _________________ 1979 Microbus |
