Door 'Click'- Check Rod Pin
elise111
elise111 is offline
PostPosted: Sat Apr 27, 2013 8:40 pm    Post subject: Door 'Click'- Check Rod Pin Reply with quote
Anyone with the later splits that has door check rods found a cure for the loud click these make when opening and closing the doors.
I haven't found replacement pins, although I'm not sure that this would fix the noise since I think the pin and the bores both wear. I've tried to find the thickest grease I can, but haven't found anything thick enough. Curious to hear if anyone has found a good fix.
zozo
zozo is offline
PostPosted: Sat Apr 27, 2013 8:58 pm    Post subject: Reply with quote
Hmmm....I've never noticed a click from mine.
Bruce Amacker
Bruce Amacker is offline
PostPosted: Sat Apr 27, 2013 9:11 pm    Post subject: Re: Door 'Click'- Check Rod Pin Reply with quote
What year bus?
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211837253
'66 Deluxe Bus
'65 Standard Bus
Build threads:
'66- http://www.leakoil.net/forum/viewtopic.php?f=23&t=2888&sid=54d8dedfb3822f99c7f2ea430cb4e856
'65- http://leakoil.net/forum/viewtopic.php?f=23&t=4263
hitest
hitest is offline
PostPosted: Sat Apr 27, 2013 9:23 pm    Post subject: Reply with quote
Is the "click" you describe the 'breakover' the check rod makes when it engages in the locked-open position? I know my '66 doors got incredibly louder when the panels came off for interior work. Are your panels on or off?
FU#5
elise111
elise111 is offline
PostPosted: Sat Apr 27, 2013 11:41 pm    Post subject: Reply with quote
Bruce, thanks for the link, I never found it before on WW- I must not have tried hard enough!
The click is with the door panels on, and is as you describe- when the cam/bump on the check rod cause it to transition from tension to compression.
