karu Samba Member
Joined: November 11, 2008 Posts: 229 Location: Cross Lanes, WV
Posted: Wed Jun 21, 2017 5:37 am Post subject: Re: Rebel wiring harness questions thread |
Does anyone know where I can find the wire gauges for wires in the rebel wire kit? I have the vw bug universal harness and it is for a buggy. This is to make sure I have correct type of connectors. |
Hank22 Samba Member
Joined: March 16, 2004 Posts: 452 Location: Inside the pizza oven
Posted: Tue May 24, 2016 9:45 am Post subject: Re: Rebel wiring harness questions thread |
Thanks Joe! |
joescoolcustoms Samba Member
Posted: Mon May 23, 2016 6:11 pm Post subject: Re: Rebel wiring harness questions thread |
The Green Horn wire is power to the horn from the horn relay. Needs to be run out and under the fuel tank to the horn, or where ever you choose to mount it. The horn will also need a good ground run to it.
The Black wire with horn switch runs to a ground to trigger the horn relay. The VW designed horn is a normally open ground and closes to make ground when the horn button is pushed on the steering wheel. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Hank22 Samba Member
Posted: Mon May 23, 2016 5:36 pm Post subject: Re: Rebel wiring harness questions thread |
Another question if you don't mind. I was expecting to wire the horn as typical by switching the ground. I have Two horn wires, one labeled "Horn" the other labeled "Horn Switch" any Idea which one should go to the Horn?
I am assuming "Horn" but not sure and I hate poking and hoping when it come to wiring.
I sent an e mail to the Rebel folks a week ago but no response. very disappointed. |
Lo Cash John Samba Member
Joined: February 06, 2004 Posts: 2246 Location: Jacksonville, FL
Posted: Mon Apr 18, 2016 7:51 pm Post subject: Re: Rebel wiring harness questions thread |
I'll post some in a few days. It's 90% done and owner has been driving it. I still need to wire hazards, interior light and rear window defrost grid and it'll be 100% _________________ www.LoCashRacing.org
More brains than bucks...Believe it or not!!
If you actually drive your VW, you need www.AirMapp.com
My boss told me I need to work on my mutli-tasking. So now when I use the bathroom at work I surf The Samba on my iPhone. |
VTghia73 Samba Member
Joined: November 23, 2014 Posts: 27 Location: Florida
Posted: Mon Apr 18, 2016 6:07 pm Post subject: Re: Rebel wiring harness questions thread |
LoCash John, keep those wire up pictures coming! _________________ 1973 Karmann Ghia Convertible Autostick Stock |
Dale M. Samba Member
Posted: Thu Apr 07, 2016 6:29 am Post subject: Re: Rebel wiring harness questions thread |
As a guess.... I would say fuse-able link is to be inserted between terminal on starter solenoid (same place as battery cable as Locash John suggests) and the "main hot lead" going forward to power fuse block and ignition switch... Personally I do not use them... Yes they may be a good idea but I do not see need (maybe short sighted on my part) ... My feeling is if you have a failure of fuseable link some where on the road the only solution is to find what has caused it to blow, and bypass link with solid wire till link can be replaced.... Many cars and VW 's have had solid wire for main supply for many years and never had a problem....
For me it would be a matter of your preference If you feel better with it in line, use it, if you are not worried about having it, forget it...
Hank22 Samba Member
Posted: Wed Apr 06, 2016 9:28 pm Post subject: Re: Rebel wiring harness questions thread |
Thanks Lo Cash the picture below shows what I am talking about it was in a separate bag marked Fuse Link.
6 inches of wire with connector crimped on
a Connector
and a piece of shrink tube
Posted: Wed Apr 06, 2016 8:27 pm Post subject: Re: Rebel wiring harness questions thread |
If you mean the very heavy gauge red wire (8awg or 10awg I think) then yes it goes on the 8mm stud with the 4awg (typical size) battery cable.
Not sure what you're asking about "fusible link". _________________ www.LoCashRacing.org
Hank22 Samba Member
Posted: Tue Apr 05, 2016 6:37 pm Post subject: Re: Rebel wiring harness questions thread |
I've been away from my buggy for quite some time. Finally back into it. I have the Rebel VW deluxe harness and Im sitting here staring at wire. Does the Red Solenoid power wire go to the same lug on the starter as the battery cable? Thanks for your help
Edit Also where does the fusible Link go
Thanks Again |
Posted: Wed Mar 09, 2016 11:47 am Post subject: Re: Rebel wiring harness questions thread |
Just keeping this thread fresh.
It's not a buggy but I am installing a Rebel Deluxe Harness in a friend's Squareback. He started the job himself but I had to pull it out and take over...
Before I started...
First thing I did was make a mounting bracket for the harness. I like the idea of spacing it up and off the body some.
Then I attached the fuse panel to the bracket with stainless machine screws. From there I dressed the wires out in 2 groups. One group is all the stuff going to the rear of the car and the dash stuff that's to the left of the steering column. The other group is the dash stuff going to the right of the steering column.
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Wed Dec 23, 2015 10:40 am Post subject: Re: Rebel wiring harness questions thread |
This is what my buggy wiring looked like when I first got it .
The first time I wired my buggy I used a 10 position fused box and all the lights and parts from a 1967 VW Bug. and a 8 position screw terminal.
The engine wires run along the tunnel on the passenger side to the engine compartment
It was the simplest diagram to follow and worked well.
I knew very little about wiring but just doing that job made me intimate with the workings of my buggy and I understood exactly what was happening when I was all done and could drive it.
I kept the engine and buggy lighting separate. All the lighting was attached to the body and never had to be disconnected to remove the body except for the two wires to the master cylinder and one wire to the horn that was mounted on the pan.
Almost every winter I would pull the buggy completely apart and do some sort of upgrade. Lucky for me the first wiring job allowed me to remove the body by unhooking just 8 wires from a screw terminal that ran all the engine wiring only.
Over the years I kept adding more and more stuff to it and as I came up with a better idea with wiring I would change it in the winter.
To say I have grown would be an understatement due to the fact my wiring has been changed so many times I can't count.
I love wiring now and keep messing with it every winter.
This is what it looks like now.
Engine compartment
Don't be afraid to wire it just to get it going. You can and probably will want to modify or add to it down the road.
After all a buggy is never done.........
You can make it as simple or complicated as you want.
Mine has creature comforts, reliability and power........ _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
Posted: Tue Dec 22, 2015 9:33 pm Post subject: Re: Rebel wiring harness questions thread |
My first buggy, I bought the $ 50.00 EMPI Buggy wiring harness, good enough, simple basic buggy.
After buying additional wire because they were either too short, or not enough circuits, then buying more circuits because the basic kit did not have enough, then mixing it up do to too much the same color, crappy fuse block that kept coming loose, cheap wire insulation. No relays, no labeling.
My guess is I tripled my initial investment by the time I was done. Not to mention the time involved to figure it out, plan, re-route over and again.
Yes, the initial outlay appears a lot for a wired, labeled harness. But the time it now saves me is tremendous. Very little thought with all the wires labeled every 8 inches. Hardest part is figuring how I want to route the looms to look neat. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Wyntand Samba Member
Joined: December 29, 2013 Posts: 37 Location: South Africa
Posted: Tue Dec 22, 2015 8:57 pm Post subject: Re: Rebel wiring harness questions thread |
Hi everyone,
Is it cheaper to buy an already made wiring harness than trying to measure the total lengths of each colour wire I need to rewire my entire SWB buggy?
Has anyone ever calculated the amount of wiring needed?
Cheers _________________ Wynand
1970 SC
1969 DC
1964 Beetle |
greggy Samba Member
Posted: Thu Nov 19, 2015 1:27 pm Post subject: Re: Rebel wiring harness questions thread |
Read you loud and clear Dale. Thank you. And thanks to everyone else too. |
Posted: Thu Nov 19, 2015 12:51 pm Post subject: Re: Rebel wiring harness questions thread |
That is a GENERATOR.... Requires a external regulator (VW Specific- Not something adapted from off the shelf) ....
Wired as ....
greggy Samba Member
Posted: Thu Nov 19, 2015 12:34 pm Post subject: Re: Rebel wiring harness questions thread |
im at work at the moment, so i stole this picture from the web. behind that hose is another terminal..so i assume its the motorola 4-wire jobby.
which answers one of my questions--i think--i need to use an external
regulator. if so, i have a new ford style with the 4 plugs. labled I S A F.
anyone ever use one of those for your bugggys? just a thought since i already have it on hand
[/img] |
Posted: Thu Nov 19, 2015 11:31 am Post subject: Re: Rebel wiring harness questions thread |
If 2 wire alternator (Bosch AL82 style and some "white box" regulated Motorola's).....
IF Motorola AL 78 style (4 wire) external regulated...
These are ultimately how its works.... You will have to translate "Rebel" into "VW" speak... Notice the terminals on both types of alternators are labeled D+ and goes to Idiot Lamp whose other side is connected to key switched 12 volts...
Another issue may be "run on", but you should not worry about that unless you experience it...
Posted: Thu Nov 19, 2015 11:03 am Post subject: Re: Rebel wiring harness questions thread |
greggy wrote: |
Great thread everyone. I am installing a basic 8 circut rebel kit. The generic hot-rod kit. i have all switches and lights ready to roll. in my wiring the alternator wires are not labled -save 2- one BIG red one marked "alternator"-it goes to the starter solenoid-but does it run off D+F or the D+M on the alternator? I have a white "alternator excitor" wire, no clue where it goes. I assume opposite of the big red one? What goes on the far back single terminal on the alternator?? and I do not have a resistor at the moment. Is that a must have as well?? Thanks |
A picture of your alternator showing the electrical hook ups would help a bunch. From your description, it sounds like you have an external regulated alternator. If so, the wiring will be different and part of it will connect to the external regulator and not direct into the wire harness. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
greggy Samba Member
Posted: Thu Nov 19, 2015 10:31 am Post subject: Re: Rebel wiring harness questions thread |
