levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Posted: Mon May 06, 2013 2:24 pm Post subject: trailing arm differences, year to year? |
that pretty much sums it up.
I'm on the hunt for a rear left trailing arm, wheel bearing housing, and the wheel hub,
Since the insurance co. *will not* take care of that, I'll just have to do it.
So, since the fire at my house also claimed my Bentley, I can't check.
Are these 3 items all identical, all the way from 1980 through the 91 ?
I'm guessing they are the same, but just in case there's a difference like there is with the stamped front...... _________________ One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40 |
Vango Conversions Samba Member
Joined: October 04, 2010 Posts: 1054 Location: Seattle, WA
Posted: Mon May 06, 2013 2:28 pm Post subject: |
They're all the same, unless of course you have a rare 16" syncro, those are longer. I'm also pretty sure that the left and right are the same too, they're just flipped over. |
levi Samba Member
Posted: Mon May 06, 2013 3:31 pm Post subject: |
Thanks, Vango!
(Never thought that they might even be reversible), although that probably won't come into play, but you never know.
wait a minute, if you flip em, then the stub that retains the spring would be on the bottom! _________________ One of these days I'm gonna settle down,
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12005 Location: Santa Cruz, CA
Posted: Mon May 06, 2013 3:32 pm Post subject: |
levi wrote: |
if you flip em, then the stub that retains the spring would be on the bottom! |
yup |
levi Samba Member
Posted: Mon May 06, 2013 3:48 pm Post subject: |
well, I guess that would also work down in Australia. _________________ One of these days I'm gonna settle down,
gl98115 Samba Member
Joined: April 22, 2011 Posts: 263 Location: Seattle, WA
Posted: Mon May 06, 2013 4:42 pm Post subject: |
syncrodoka wrote: |
levi wrote: |
yup |
Unless you get a VW replacement arm which has stubs on both sides. _________________ '87 faux-Syncro Westy w/ 2.3l GoWesty WBX |
Posted: Mon May 06, 2013 4:55 pm Post subject: |
Oh yeah, the divot is there for the spring on both sides but the stub isn't. Best to get the correct side but if you needed to, you could cut the stub off and weld it back on the other side. |
Posted: Mon May 06, 2013 5:03 pm Post subject: |
gl98115 wrote: |
syncrodoka wrote: |
levi wrote: |
yup |
Unless you get a VW replacement arm which has stubs on both sides. |
Yeah you can get one of those for $900+ shipping each from the fatherland and lop off the unused spring nub or just get the correct side stateside.
Tough decision eh? |
erdonline Samba Member
Posted: Mon May 06, 2013 5:27 pm Post subject: |
The length and/or thickness of the spacer in the wheel bearing housing changed around '85, didn't it?
Ed _________________ '85 Vanagon Westfalia
'84 Vanagon 7-passenger
'98 Mexican air-cooled Beetle |
