Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22396 Location: Kimball, Mi
Posted: Wed Apr 11, 2018 12:57 pm Post subject: Re: Type 3 Swing axle to IRS conversion. (Plus Kafer bars) |
I want to Thank Critter for posting his pics to the Samba, so we can actually see them. I really hate photobucket when looking at older posts. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Critter1 Samba Member
Joined: August 04, 2004 Posts: 1575 Location: Sacramento
Posted: Thu Apr 12, 2018 9:57 am Post subject: Re: Type 3 Swing axle to IRS conversion. (Plus Kafer bars) |
Bobnotch wrote: |
I want to Thank Critter for posting his pics to the Samba, so we can actually see them. I really hate photobucket when looking at older posts. |
Whats funny is they are from Photobucket! I guess I got lucky... either that or I pay them a few bucks a month...I don't even remember... _________________ Justin |
Yabbadubbadoo Samba Member
Posted: Mon Jul 29, 2019 3:47 am Post subject: Re: Type 3 Swing axle to IRS conversion. (Plus Kafer bars) |
Finally got around to fixing the Photobucket pics in this thread. I downloaded all my files and deleted the dodgy Photobucket account. Re-uploaded to The Samba like I should've done from day 1.
Also did my build thread.
Only one more thread to go. _________________ Sydney, Australia.
66 Type 3 Fastback |
PlacerPuma Samba Member
Posted: Sun Sep 13, 2020 9:55 am Post subject: Re: Type 3 Swing axle to IRS conversion. (Plus Kafer bars) |
Yabbadubbadoo wrote: |
Only one more thread to go. |
Thank you for spending the time and fixing the pics.
I just purchased the the SoCal Imports IRS conversion jigs, knowing they might need to be modified, to fit the Type 3 rear, to clear the shock towers.
First test fit of the jigs to my donor Bug Type 1 Rear IRS.
They do not align, angles seems off. Binding before any of the 4 bolt holes ever line up to even start. |
Posted: Mon Sep 14, 2020 10:14 pm Post subject: Re: Type 3 Swing axle to IRS conversion. (Plus Kafer bars) |
PlacerPuma wrote: |
It might need some cold setting with a big adjusting tool. (large hammer.). Im guessing it may have shrunk out of alignment during their welding process and they forgot or did not bother to cold set it back to spec. _________________ Sydney, Australia.
Clatter Samba Member
Joined: September 24, 2003 Posts: 7533 Location: Santa Cruz
Posted: Tue Sep 15, 2020 7:56 am Post subject: Re: Type 3 Swing axle to IRS conversion. (Plus Kafer bars) |
Mine needed hot set.
After they were clearanced for the type 3 subframe they were gusseted.
This caused a bit of movement from the heat (inevitable).
Bolted them to an IRS sub i had handy, and heated them cherry red near the pivots.
Once cooled off, they go on/off a straight factory IRS sub easily. _________________ Bus Motor Build
What’s That Noise?!? |
Posted: Sun Sep 20, 2020 1:33 pm Post subject: Re: Type 3 Swing axle to IRS conversion. (Plus Kafer bars) |
Thank you for the advise Clatter and Yabbadubbadoo.
I had figured as much, as the jig needing to be straightened and adjusted.
I do have to wonder how many people purchase these, and use them to install their IRS pivots, without ever checking them first.
Did reach out to the vendor and let them know, as well.
Posted: Sun Sep 20, 2020 1:39 pm Post subject: Re: Type 3 Swing axle to IRS conversion. (Plus Kafer bars) |
Here is the Passenger side of the So Cal Imports Jig tool fitted.
That side is totally satisfactory in fit.
I would trust the right hand side jig to align the pivot point correctly.
Posted: Tue Dec 01, 2020 7:14 pm Post subject: Re: Type 3 Swing axle to IRS conversion. (Plus Kafer bars) |
Update on Vendor - Never resolved issue and wasted a lot of time.
I was told these are made outside the United States - Unable to verify
Would highly recommend buying from reputable source, like Ron Lummus, which I was unaware even sold IRS jigs, otherwise I would have ordered from him. |
Posted: Wed Dec 02, 2020 6:59 pm Post subject: Re: Type 3 Swing axle to IRS conversion. (Plus Kafer bars) |
This may help someone down the road, when trying to convert to IRS.
If need a reference measurement
