DirtyBlueVan Samba Member
Posted: Sat May 11, 2013 7:06 am Post subject: Transmission coming out, anything extra I should do? |
I haven't really ever wanted to light a Jiffy lube on fire before I tried removing the transmission fill plug. I took heat to it, a chisel to it, and finally an extractor to it. So now all I have is a mangled fill plug stuck in the trans.
The transmission is about ready to come out, I just need to get that 8mm 12 point tool for the axles. Is there anything else I should change before I put it back together? I already have the oil seal for the input shaft, clutch has about 20k on it. the car has 258k miles so anything that's easy enough I will do.
At least the previous owner gave me receipts so I wouldn't be blaming him for the 4000ftlb torque on the fill plug. |
insyncro Banned
Posted: Sat May 11, 2013 7:17 am Post subject: |
I have had 100% success removing fill plugs with the Snap On 17mm plug wrench. |
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Sat May 11, 2013 6:36 pm Post subject: |
I have to agree that many shops over tighten these for no good reason. I've been using teflon tape for years. Lower torque, no leaks, easy removal. _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
rlamb Samba Member
Joined: March 26, 2012 Posts: 211 Location: Sweet Home, OR
Posted: Sat May 11, 2013 9:35 pm Post subject: |
insyncro wrote: |
Ar those still available new? (haven't checked the classified ads here yet). _________________ 1984 Westfalia - Ford Cologne 2.8L conversion
2003 Passat GLX Wagon (4Motion) |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12008 Location: Santa Cruz, CA
Central Syncronizer Samba Member
Joined: November 19, 2008 Posts: 302 Location: Vancouver
Posted: Sat May 11, 2013 10:44 pm Post subject: |
Check the oil slinger on the input shaft before you put the new seal in. If its loose, now is the time to fix it.
There is a great thread on it with a step by step repair. The search should turn it up.
Oh, yeah and tack weld the nuts on the bottom of the clutch slave bracket. It will make it a lot easier removing and replacing the clutch slave. _________________ Ongoing restoration/maintenance of my syncro double cab (and soon Westy):
http://88syncrodoka.blogspot.com/ |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10251 Location: N. Idaho
Posted: Sat May 11, 2013 11:01 pm Post subject: |
Always a good idea to tell us what trans/vehicle we are talking about - year, etc. There will be different recommendations if you have a manual trans vs the automatic trans.
Are you pulling the trans just for the fill plug issue? If so, I'd recommend before you do that take it to a welder who can weld something stout onto the plug, such as a large bolt so you can get it out. $20 well spent.
DougM _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
Posted: Sun May 12, 2013 12:55 am Post subject: |
You can always just weld be piece of bar stock to the drain plug. The heat alone might make it unscrew easily. |
chojinchef Samba Member
Joined: February 17, 2011 Posts: 1539 Location: Central Massachusetts
Posted: Sun May 12, 2013 6:08 am Post subject: |
Leftover mercedes SL lug bolt, misc VW lug nut. Weld would have been better if I bothered removing some of the chrome.
Works great
X2 on modifying the clutch slave bracket.
LP _________________ Its a mistress; an expensive, whiney, needy bitch of a mistress. She is a chunky, dirty girl with bad skin, little motivation and yet she always makes me smile. She sure has been around before shacking up with me. She has a direct line to my wallet, plays with my emotions, is consistantly jovial yet with a sarcastic and sardonic side, is consistant in her inconsistancy, and every once in a while gives me a great ride and a fantastic memory. |
rlamb Samba Member
Posted: Sun May 12, 2013 9:48 am Post subject: |
Thanks! _________________ 1984 Westfalia - Ford Cologne 2.8L conversion
Posted: Sun May 12, 2013 9:50 am Post subject: |
IdahoDoug wrote: |
DougM |
1985 1.9l manual.
I already pulled it. The plug is mangled up pretty badly so I'm going to let professionals take care of it. I already busted a welded up bolt for a tool, I didn't try welding something to the plug. The plug no longer has any semblance of it's former self.
In the middle of me removing the transmission (solo, that was difficult in a gravel driveway) I found a coolant hose without a clamp...Now I just need to get the fuel line changed out. I need to get the van back together to go get some tires I ordered put on.
I'll be happy when this is all over. Then it's time to enjoy it until it explodes....then bye bye wbx.
I am concerned about the strain I put the engine through, I didn't support it before lowering the transmission. I got a hockey stick and ratchet strap holding it up now. |
bdcain Samba Member
Posted: Sun May 12, 2013 9:58 am Post subject: |
i got a set of big allen sockets for 10$ from
princess auto
if you are canadian
princess auto is the place for you
cheap prices
they take will take back any mangled tool
with a 17mm i think and a breaker bar easy as pie
also if you are taking transmission off
maybee leave fill plug alone
and turn upside down to fill via drain plug as its out !
just do a precision fill
also when you do the oil slinger you can clean the magnetic plug at that time
just a thought |
Posted: Sun May 12, 2013 10:04 am Post subject: |
bdcain wrote: |
princess auto
if you are canadian
cheap prices
just a thought |
Yea I thought about that, I even thought about tapping my extractor hole and putting a plug in that. But I think a decent machine shop can make it good as new for a decent price. _________________ 1989 Syncro Westfalia 2.5 smallcar subie |
