sam_w Samba Member
Joined: March 07, 2002 Posts: 1479 Location: Petaluma, CA
Posted: Wed May 29, 2013 10:05 am Post subject: |
It is now fixed. A used lightened 8 hole flywheel, balanced and installed with the good dowels and JB welded on bad dowels.
I looked at my videos and you ,can hear noises in the last one. I will edit my pics and videos, but gotta go and get the Thingster home.
So happy that I did not need an engine rebuild and a new crank!
_________________ 63 singlecab
73 thingster
74 Thing |
sam_w Samba Member
Posted: Wed May 29, 2013 3:47 pm Post subject: |
Well I made a 4 minute video, here you are.
73 thingster
74 Thing |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Thu May 30, 2013 4:34 am Post subject: |
sam_w wrote: |
When I had my stroker motor built i said I wanted bottom end torque.
They put a standard 4 dowel flywheel on an 8-dowel crank. I will find out today if a flywheel can be connected to the crank after the bumps have been ground off.
Searching , I see all sorts of extra fancy gland nuts, but I think my mechanic is using a standard one. |
That was not a smart idea. Stroker engine with a 4 dowel crank will lead to exactly this issue. The jig to drill the 4 extra holes in a stock flywheel is cheap, they should have at least done that and run an HD gland nut and larger diameter washer torgued down with loctite. Glad it is back up and running! I'm wondering now if you have the stock gland nut with stock diameter washer trying to hold 8 dowels from moving? |
euromog Samba Member
Posted: Fri May 31, 2013 7:04 am Post subject: |
You are going to have to replace that crankshaft. I use a Gene Berg forged gland nut and washer with an 8 dowell crank and flywheel. Then torqued to 350ft lbs. After decades of drag racing turning up to 7000rpm no issues. |
sam_w Samba Member
Posted: Sun Jun 02, 2013 5:50 pm Post subject: |
Well John et alia,
I respect your opinions .
I had planned to take the Thingster down to the Classic & back, 1,000 miles.
I then planned to go to seer Clara, of split bus fame, in Olympia WA, the on to Vintage Meet in Seattle, and on to see relatives in Vancouver BC, about 2000 miles.
These trips both take me far from home.
The Thingster ran well for 12,000 miles with four dowels. The flywheel is now balanced and it should be as good if not better than the original installation.
Am I crazy to consider these trips. or should I take my 63 singlecab with a standard 1600 Miximotor?
It runs just fine and I can't see why it broke the gland nut, I know it would have made sense to put in a Chromemoly one, but it is installed and the Thingster runs great. _________________ 63 singlecab
73 thingster
74 Thing |
Posted: Sun Jun 02, 2013 6:17 pm Post subject: |
Way back in the 60's when VW air cooled engines were modified for drag racing they started using 8 dowell cranks and flywheels because 4 was not enough to hold the HP. Porsche 356 engines use 8 dowels but they are smaller.
You have a 2 liter engine that is making a lot more torque than stock that 4 dowel pins are trying to hold. The dowels moved in their holes because of more torque than they were engineered for. Once the flywheel twisted from it's original position from the loose dowels the gland nut became loose. That was the noise you heard. Eventually the shock loads broke the gland nut.
The work you had done is a good field patch. I personally would not drive far from home expecting a trouble free trip. I would be shopping for a new crankshaft with a match 8 doweled flywheel. IE the extra dowels are drilled with the flywheel mounted to the crankshaft so they are a precision matched set. Then use a forged gland nut. This does entail a complete rebuild of the engine but the only way to have it be reliable for off-road excursions in the desert.
Although slower the single cab would be a better choice for the trips. Enjoy the scenery. |
sam_w Samba Member
Well I have made a decision, right or wrong.
I will order a Heavy Duty Gland Nut, and the next time the engine comes out replace the standard one that is there.
I expect that I will have to replace the clutch sometime, because I have to slip it a bit to climb over rocks, so it will not last 50,000 miles.
I will also carry it with me in case I get into trouble away from home. _________________ 63 singlecab
73 thingster
74 Thing |
Metal Twister Samba Member
Joined: January 24, 2013 Posts: 405 Location: licking, MO.
Posted: Wed Aug 05, 2015 10:38 am Post subject: |
So with the problems fixed when are we going to go again? _________________ Change is Opportunity!
Instagram=metaltwister |
sam_w Samba Member
Posted: Wed Aug 05, 2015 10:51 am Post subject: |
Yes indeed,
I can't wait for Memorial Day weekend 2016. _________________ 63 singlecab
73 thingster
74 Thing |
