atomatom Samba Member
Joined: May 15, 2012 Posts: 1867 Location: in an 84 Westy or Bowen Island, BC
Posted: Wed Mar 11, 2015 8:51 pm Post subject: |
Wildthings wrote: |
rsxsr wrote: |
Luckyphil wrote: |
Thanks for the reply but its the other way around. I am removing the flex plate and installing a flywheel. |
Same deal. Ideally they would interchange, but that is why there are quite a few shim combinations. On a used engine, I'd want to maintain the endplay, not tighten it up if it is close to spec. Assuming it was setup correctly prior if the endplay is out of spec, something is wearing out and overshimming, could aggravate the problem. |
This is very important. A lot of Type 1 engines have been killed by people trying to tighten up the end play on an old engine. If the endplay was once correct you can not change the shims to reduce it or you risk locking the crank to the thrust bearing. The WBXer engines don't have as much problem with excessive end play as the Type 1 engines, but you still need to think twice about trying to reduce endplay on a used engine. |
X3.
the reason to adjust endplay is because you've added new bearings or altered the case/crank somehow. boston bob was finishing up a rebuild, not just throwing some shims in.
the reason to measure it is to let you know how much life is left in those bearings. if it is getting sloppy, then you may need a full rebuild and replacement of the main bearings.
mine was cracked: http://www.thesamba.com/vw/forum/viewtopic.php?t=589769&highlight= _________________ 84 Vanagon Westy, 1.9L, California raised but defected to Canada. |
wehrbüchse Samba Member
Posted: Wed Mar 11, 2015 10:38 pm Post subject: |
Well I guess it's all moot what I've asked. I've spent hours trying to lineup this transmission. I couldnt get this thing back in if my life depended on it. Something is hanging up and no matter what I do it just will not budge. |
Posted: Wed Mar 11, 2015 11:12 pm Post subject: |
wehrbüchse wrote: |
Did you try slipping the disc onto the tranny input shaft before bolting clutch to the flywheel? Assuming the disc will fit onto the shaft and that the disc is aligned properly with the pilot bearing then the tranny and engine should mate up readily once you get them well aligned with each other. Did you try rotating the engine (tranny in gear, P. brake on) while applying moderate force to mate the tranny and engine? |
kjono09 Samba Member
Joined: April 03, 2014 Posts: 191 Location: Seattle, WA
Posted: Thu Oct 27, 2016 4:15 am Post subject: |
Pascal wrote: |
The big diameter endplay shim is still available in Europe. I was not able to find any in North America last year. |
Question about endplay:
On a 1.9L how much is to much? (Would this require the large shims)
Is .005-.006 too much?
How do you fix endplay in a 1.9L?
Anyone have a recommended mill/drill for engine machine work?
I am looking at a 1.9L to turn into a oxyboxer. _________________ 84 Retro-Westy GW 2.2L (Vincent)
67 Bug 2007cc (WBX in progress) (Davey)
Submariner |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Thu Oct 27, 2016 3:59 pm Post subject: Re: Adjusting flywheel endplay |
Spec is .003-.005
According to well-circulated video, on a run-in (not rebuilt) engine, guru Bob Donaldson (RIP) always aimed for
.005 endplay. Outside of that spec, adjust by selecting a different assortment of shims to give the desired result;
check and double-check everything dry (no oil) with no seal or o-ring in place which would skew results.
Unfortunately, "new" shim packs are unavailable but they <occasionally> come up in classifieds or private sellers online.
Keep your eyes peeled, or maybe we'll hear from some van hoarder/builder out there with some parts to spare...???
Oh yeah...and tell us more about this "O2-boxer" rebuild...???
Good luck...keep us posted!
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
MayorMcCheese Samba Member
Joined: October 07, 2009 Posts: 660 Location: Lancaster PA
Posted: Thu Oct 27, 2016 5:02 pm Post subject: Re: Adjusting flywheel endplay |
Vancafe sells shims |
Posted: Thu Oct 27, 2016 6:38 pm Post subject: Re: Adjusting flywheel endplay |
You want three shims, not one or two. |
Posted: Thu Oct 27, 2016 7:19 pm Post subject: Re: Adjusting flywheel endplay |
MayorMcCheese wrote: |
There ya go then...
Sorry if I misspoke - when I did my tranny work in 2012 they were NLA.
Happy to say my endplay was still within spec at the time.
Still, I wouldn't tighten it up too much. Keep it closer to .005 than .003.
"The WonderVan"
lucianosanchez Samba Member
Joined: May 04, 2016 Posts: 212 Location: Ventura County
Posted: Mon Jun 12, 2017 11:05 am Post subject: Re: Adjusting flywheel endplay |
Does anyone have a valid link to Boston Bob's flywheel video. I cannot find it anywhere and all the links that are posted do not seem to work. _________________ 1983.5 Aussan Brown Westfalia | 2016 to 2020
1983.5 Beige Westfalia | 2019 to Current |
T3 Pilot Samba Member
Joined: January 10, 2011 Posts: 1507 Location: Deep South of the Great White North
FL-Frank Samba Member
Joined: August 08, 2015 Posts: 823 Location: Jupiter, Florida
Posted: Thu Oct 17, 2019 10:05 am Post subject: Re: Adjusting flywheel endplay |
This link is dead. Anyone have a current link to this video that works? _________________ “Tinker Toy” 1967 Savannah Beige Beetle Sedan...........Mostly Original Survivor
“Fritz” 1964 Gulf Blue Karmann Ghia Coupe...Complete Pan-Off Restoration SOLD |
Posted: Thu Oct 17, 2019 9:46 pm Post subject: Re: Adjusting flywheel endplay |
Fresh upload, w/archival assist by Jake de Villiers...
"The WonderVan"
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
