DirtyBlueVan Samba Member
Posted: Thu May 16, 2013 6:52 pm Post subject: Mechanical cause for craptastic cold idle? |
The issue(s): when cold, it starts, but runs like complete garbage. It sounds like a cylinder is dead. It may or may not die without throttle input. Once it starts to warm up it starts to smooth out and eventually runs and idles well enough. I noticed that holding it at 2k (while bleeding the coolant engine warm) It pops like it is backfiring with small +\- 50-100 rpm fluctuations. The plugs are black from running rich(I think) and burning oil (258k)
I'm still battling this issue, all sensors check well and are within parameters. Re adjusted the TPS and hear audible clicks at full and idle.
Things I still need to do:
-Check for vaccum leaks with propane, I found one small one but it made no difference after I fixed it. no high idle, so I'm not holding my breath.
-Check fuel pressure, I don't have a way to test this so this will happen last resort
-take apart the cold idle valve and check it in depth
Someone obviously tinkered with the AFM.
My main question is, the seemingly dead cylinder when cold started. Are there any mechanical issues that would show during a cold start but not when warm? It does smoke upon starting and goes away almost in time with the engine smoothing out. It's not a serious amount of smoke.
Thanks for all the help so far everyone. What a great resource. _________________ 1989 Syncro Westfalia 2.5 smallcar subie |
0to60in6min Samba Member
Joined: November 27, 2006 Posts: 3416 Location: OR & CA (Oregon/California)
Posted: Thu May 16, 2013 8:19 pm Post subject: |
there are many things that lead to the problem you described.. since you mentioned mechanical.. I would say that you have at least one leaking injector. The injector(s) leaks and flood the cylinder(s). When you start the engine it will run very rich in one or 2 cylinders until the excess of gas is gone - the fouled/black spark plugs is the clue.. - and once the excess of gas is gone it runs normally... till you park the car overnight...
other than that anything from AFM, Temp2 sensor, coil, bad grounds etc etc. |
vandam Samba Member
Joined: September 05, 2012 Posts: 116 Location: Oregon
Posted: Thu May 16, 2013 9:48 pm Post subject: |
check engine compression. _________________ 84 GL, 2.1 rebuilt |
Posted: Thu May 16, 2013 10:06 pm Post subject: |
150,150,130,120. No complete leak down done _________________ 1989 Syncro Westfalia 2.5 smallcar subie |
Posted: Fri May 17, 2013 6:32 am Post subject: |
The TSII sensor is what enriches the mixture during cold running. I would start there. |
Westified Samba Member
Posted: Fri May 17, 2013 9:32 am Post subject: |
I had a problem with cold idle on my 1984 1.9 Westy, replacing the Auxiliary Air Regulator solved the problem. Good luck. |
Posted: Tue May 28, 2013 8:42 am Post subject: |
just to update, replaced temp 2 still no good, checked aux air per bently, rpms fluctuate appropriately.
I have gas in the oil, found an exhaust leak and patched it.
Any other ideas out there? _________________ 1989 Syncro Westfalia 2.5 smallcar subie |
