randywebb Samba Member
Posted: Sat May 18, 2013 2:47 pm Post subject: blue foil speedo query |
I see that my 1986 Vanagon has 6 (!) contacts from the blue foil going into the mechanical speedometer. There is also a pcb in there with some devices on it - hard to see as they mounted it where you cannot look at the top of the pcb.
This makes no sense to me - what are they all doing?
I looked at an earlier speedometer and it has no pcb on it and no provisions for all those contacts.
any ideas? _________________ 1986 2.1L Westy 2wd Auto Trans. |
rc3 Samba Member
Posted: Sat May 18, 2013 3:44 pm Post subject: |
it is the dynamic oil pressure warning system control unit. |
Posted: Sat May 18, 2013 3:55 pm Post subject: |
thx - weird place to hide it... _________________ 1986 2.1L Westy 2wd Auto Trans. |
Haynestj Samba Member
Joined: November 20, 2016 Posts: 1 Location: Michigan
Posted: Sun Nov 20, 2016 2:45 pm Post subject: Re: blue foil speedo query |
randywebb wrote: |
any ideas? |
How do you remove the foil with these contacts? |
jereandjess Samba Member
Joined: January 09, 2005 Posts: 563 Location: Massachusetts
Posted: Tue May 29, 2018 6:28 am Post subject: Re: blue foil speedo query |
Also curious how to remove the foil from the 6 contacts on the speedometer. Are they spades that slide on/off? I don't want to try too hard for fear of damaging the foil!
Also, what's a pcb?
And what part is the oil pressure unit? My oil pressure light flashes intermittently which I have started to get used to, but would rather fix it! I am pretty confident that it is a wiring/connection issue, not actual low pressure.
_________________ ~Jeremy (and Jessica)
77 Sage Green Westfalia 2.0 FI - since May 2004
78 Blue Landmark camper 2.0 FI - since April 1998
69 Beetle - In the family since new
86 Wolfsburg Vanagon Camper "Weekender" since July 25, 2015 |
Paulbeard Samba Member
Posted: Tue May 29, 2018 6:53 am Post subject: Re: blue foil speedo query |
jereandjess wrote: |
Also, what's a pcb?
Printed circuit board.
How did it look last time you changed it? It could be low pressure (worn pump or overused oil). _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers |
wesitarz Samba Member
Joined: August 20, 2012 Posts: 1477 Location: Victoria,B.C.Canada
Posted: Tue May 29, 2018 10:30 am Post subject: Re: blue foil speedo query |
Also curious how to remove the foil from the 6 contacts on the speedometer. Are they spades that slide on/off? I don't want to try too hard for fear of damaging the foil! |
The whole plastic connector slides out. Don't pull on the foil. There is a fix to disable the buzzer by unsoldering one of the connections but it's been many years since I did it. |
