allihjelm Samba Member
Joined: April 29, 2009 Posts: 231 Location: Akureyri, Iceland
Posted: Mon May 20, 2013 2:38 am Post subject: Transporting my VW, in gear or not? |
Hi guys.
Today I'm transporting my old 67 Bug on a small car transport trailer from Reykjavik in Iceland to Akureyri in north Iceland, about a 6 hour journey over mountains and through tunnels.
My question for you guys is should I put the Bug in first gear and have it in hand break or am I risking damaging the gearbox as the Bug will probably be pushed around putting strain on the gearbox and brakes?
What is your recommendation on this? Would you recommend a special way to fasten the Bug as well, any weak points that may take damage?
Thanks, Al _________________ 1967 European 6V Volkswagen 1300 Beetle |
Fishynos72 Samba Member
Posted: Mon May 20, 2013 4:11 am Post subject: |
If it can be 'shunted' by other cars on the trailer, having it in gear could result in teeth on the gears being smashed off, depending how heavy the other cars are of course.
If your handbrake is adjusted and combined with proper tie downs you shouldn't have an issue,
Just my 2c _________________ Collector of all things Volkswagen, Hazet and Matra.
1972 1302
1973 type2a
1957 type11
2005 Caddy panel van
2006 Golf R32 |
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Mon May 20, 2013 9:26 am Post subject: |
Put it in gear and set the parking brake.
If the gearbox was delicate enough to get damaged towing like this, you would never be able to drive it out of the garage! _________________ Mother Nature is a Mean Evil Bitch! |
Posted: Tue May 21, 2013 6:48 am Post subject: |
Thanks for your help here guys.
The transportation went well. I fastened the car thoroughly with straps had it in handbrake and had no problems whatsoever.
Went like a charm.
- Ali _________________ 1967 European 6V Volkswagen 1300 Beetle |
