Cptn. Calzone Samba Member
Joined: June 27, 2007 Posts: 1855 Location: S>E>Alabama
Posted: Mon May 20, 2013 4:00 am Post subject: 356 pulley |
Hello everyone, i haveca 71 westy stroker motor ,all tin full flowed ext cooler and the head temps are a little warm.Oil is always cool however i have a welded and balsnced fan so i know it can doba little more rpm and live, i am putting on the 356 pulley to get more cfms.Anyone have any good or bad to say about this?I am in L.A (lower Alabama) so we are very hot here in summer months.Thanks all _________________ 71 westfalia
67 912 Porsche Quintilla
67 Single Cab aka my work horse |
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4536 Location: Arizona Highways
Posted: Mon May 20, 2013 6:55 am Post subject: |
I have been using one for years without issue.
I have seen some problems w/ the new ones available from pelican, etc.
they are cast, not stamped like the OGs.
The main problem I have w/ mine is I can never remember the belt size
if you have an alternator you will need to do a little grinding and you will need the special shims to get the front part of the pulley off the gen/alt. _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
Posted: Mon May 20, 2013 4:51 pm Post subject: pulley |
I do have the alternator,What shims are needed? Where can i get them?Thznks for the reply _________________ 71 westfalia
Posted: Tue May 21, 2013 1:27 pm Post subject: |
i found them @ Stoddard:
http://www.stoddard.com/shop/shopdisplayproducts.asp?Search=Yes
being that you are in AL you may want to try Auto Atlanta.
you will only need one or two to space the FRONT of the pulley off the hub a bit.
you can use VW shims between the two pulley halves. _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
Jeff Geisen Samba Chaplain
Joined: December 21, 2004 Posts: 1881 Location: N.W. Georgia
Posted: Mon Apr 19, 2021 6:18 pm Post subject: Re: 356 pulley |
Can anyone provide a belt size for 356 Porsche fan pulley w/stock VW 1600 crank pulley? _________________ I Corinthians 4: 1 thru 5
‘63 ragtop - ‘68 single cab |
Posted: Mon Apr 19, 2021 6:31 pm Post subject: Re: 356 pulley |
I have it Ill get to the bus tommorrow really helps with cooling _________________ 71 westfalia
Posted: Mon Apr 19, 2021 6:51 pm Post subject: Re: 356 pulley |
Right on, thanks. _________________ I Corinthians 4: 1 thru 5
aeromech Samba Member
Joined: January 24, 2006 Posts: 16956 Location: San Diego, California
Posted: Mon Apr 19, 2021 10:14 pm Post subject: Re: 356 pulley |
Can someone post a pic of this 356 pulley? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Tue Apr 20, 2021 3:32 am Post subject: Re: 356 pulley |
Posted: Tue Apr 20, 2021 5:23 am Post subject: Re: 356 pulley |
It is a much smaller diameter get a true Porsche pooley if you can because they are very high quality I will post up tonight the whole set up the shims and everything it makes it big difference the vehicle runs a lot cooler especially in a bus _________________ 71 westfalia
74 Thing Samba Member
richparker Samba Member
Joined: November 24, 2011 Posts: 6979 Location: Durango, CO
Posted: Tue Apr 20, 2021 10:49 am Post subject: Re: 356 pulley |
Would going small on the crank pulley produce the same effect as the 356 pulley? I’m a bike guy and if I think of it like the gears on a bike, going smaller on the big ring would allow you to spin faster. Thoughts?
I’m asking b/c I went with a 6 3/4" CB Equalizer pulley to replace my 7” stock pulley. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Posted: Tue Apr 20, 2021 11:13 am Post subject: Re: 356 pulley |
The smaller crank pulley spins your fan slower. If anything you’d want a bigger pulley down low to raise fan speed. I don’t think there’s room to spare around the crank tin for a bigger wheel.
I understand the smaller crank pulley reduces engine drag by slowing down the fan. _________________ I Corinthians 4: 1 thru 5
Posted: Tue Apr 20, 2021 11:26 am Post subject: Re: 356 pulley |
Jeff Geisen wrote: |
I understand the smaller crank pulley reduces engine drag by slowing down the fan. |
Makes sense as I do feel like acceleration is better with the 6 3/4” pulley. 🤷♂️ I haven’t taken many trips since I had the 6 3/4” pulley installed. But this weekend we are headed to Canyon Lands and my eyes will be on the temps.
Now, has anyone actually come up with numbers on the 356 pulley? How much faster does your fan actually spin? what percent lower temps have been recorded? Does this lower head temps, oil temps or both ? Maybe I’ll venture over to the performance forum sometime and see what I can dig up. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Posted: Tue Apr 20, 2021 1:41 pm Post subject: Re: 356 pulley |
Thank you RP _________________ I Corinthians 4: 1 thru 5
Posted: Tue Apr 20, 2021 7:18 pm Post subject: Re: 356 pulley |
After reading every thread in the performance forum with “356 pulley” in the title I learned, that it’s really not that much of a difference. Most say it’s loud, robs HP and should only be run with a welded fan. They say that the 356 also used a small crank pulley so the fan did not run faster in a 356. I also learned this:
Stock crank pulley 7” with a stock 4.25” alt pulley = 1.647 ratio
Stock crank pulley 7” with the 356 3.75” alt pulley = 1.866 ratio
Aftermarket pulley 6.75” with stock 4.25” alt pulley = 1.588 ratio
Aftermarket pulley 6.75” with stock 3.75” alt pulley = 1.8 ratio
Aftermarket power pulley 5.75” with stock 4.25” alt pulley = 1.352 ratio
Aftermarket power pulley 5.75” with 356 3.75” alt pulley = 1.533 ratio
A power pulley adds HP but then it’s robbed again if you pair it with a 356 alt pulley. I don’t know, seems like it could be worth trying if you can find an affordable one. Seems like the “new” one are like $100 or so, although it seems the recommendation is to find a nice OG used one.
I’m currently running the 6.75/4.25 combo, I’m only off by .059 from stock. Would it be worth it to me to increase the speed by .212 with the 356 pulley? 🤷♂️ _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Wed Apr 21, 2021 5:12 am Post subject: Re: 356 pulley |
I had one on my Bus 2110cc and It did cool the heads better , got it from Pelican parts and it finally wore out , belts won't stay tight, so back to stock size ,and yea my head temps went up _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Posted: Wed Apr 21, 2021 10:11 am Post subject: Re: 356 pulley |
richparker wrote: |
I’m currently running the 6.75/4.25 combo, I’m only off by .059 from stock. Would it be worth it to me to increase the speed by .212 with the 356 pulley? 🤷♂️ |
Pulley size is not the only variable in pulley/fan ratio. The belt is a key factor as well since you can use a smaller belt that fits lower in the upper pulley thus turning the fan faster. The best thing to do is find out what your current crank pulley to fan ratio is by turning your crank pulley 1 rotation and counting the number of turns the upper pulley makes. |
